 1-17  …  278-297  298-317  318-337  338-357  358-377  …  1858-1859
7777.318
Pardon me Pilou, for replication .......
of course, in normal use could Moi
lineweb used to build the structured wire-
But here , we are in the n the "Parametric World"
the construction thus realized (from a glance at File)
It has many parameters manipulated,
therefore everything can be reconsidered, correct, etc. etc.
And this is the TRUE POWER ...........
On the other hand no one has yet implemented
lineweb Node in Elephant
Have a nice day
al
7777.319 In reply to 7777.318
Sure it's the power of the parametric world!
It was just a note! ;)
EDITED: 4 Apr 2017 by PILOU
7777.320
Hello Friends
Tired enough, but I succeeded
Low poly-giroid-
Minimal surf, obtained with Subdivide tool
best
al
http://www.mediafire.com/file/64v7y227uphe9nz/Minimal_Surf.rar
7777.321 In reply to 7777.320
Hello Al,
thanks for sharing. You are shooting in the right direction!
http://news.mit.edu/2017/3-d-graphene-strongest-lightest-materials-0106
http://advances.sciencemag.org/content/3/1/e1601536/tab-pdf
Have a nice day
Karsten
7777.323 In reply to 7777.320
Hi Al,
Your latest Gyroid nod file is brilliant.
However I can not get it to run.
I suspect it is my computer is hanging
because it cannot handle computational load.
I am confident that I have newer nodeeditor mod,
but just to check it is not a missing js file;
could you please upload your nodeeditor folder
zipped to mediafire.
Thank you
Yes because that is difficult to know if its the classic or modified Editor! ;)
7777.325 In reply to 7777.323
Hello James, Hello Pilou,
it's a modified one - this should hopefully work ...
http://moi3d.com/forum/index.php?webtag=MOI&msg=8197.7
Have a nice day
Karsten
THX for the efforts!
7777.327
Something to play ...
7777.328 In reply to 7777.325
Yes Karsten, that works
Thanks as always
7777.329
Hi James,thank you for appreciation , sorry but I forgot to specify
the version used in Nodeeditor ...( v.0.93 + Karst/tools)
In any case I see that Karsten has clarified the thing-
If not specified, my files are usually created
with the latest updates - Max , and Karsten tools
Good work at all
al
Not sure of what I must obtain but that works fine! :)
And quasi all in French! :D
Normal i have not yet translated all new nodes! :)
EDITED: 2 May 2017 by PILOU
7777.331
Hi to all Friends
I continue with the exploration of the Minimal Surfaces
Trying to make it happen with Elepphant-
I want to share with you the result obtained
To realize the Schwartz-P Surf-
.... One of the main bricks .......
In that regard I wanted to ask Karsten
If there is any way to enter
"Preserve Edges" in the SubD .node
Have a nice day
al
link-http://www.mediafire.com/file/pqv8zigfpgvqcaf/Schwartz_P.rar
7777.332 In reply to 7777.331
Hello Al,
<<If there is any way to enter
"Preserve Edges" in the SubD .node>>
for me unfortunately no - sorry. A while ago I've taken Max SubD-Script and wrapped it in a node function - without understanding the internal structure. I think that Max is able to do that, but I think that's a lot of work.
Nevertheless
have a nice day
Karsten
7777.333 In reply to 7777.332
Hi Karsten
Many Tnx for the info
al
7777.334
Hello Karsten
I hope everything is fine .....
I do not want to take advantage of your availability , but
It would be important to implement the " Mirror " node ;
actually working in the resolution Low Poly of
Minimal Surf, it is almost essential to use
the" Mirror" tool for all symmetries , in the repetition
of the basic element in the resolution polyhedron...
The use of simple Rotates becomes enough
heavy...
It is not so easy to locate the rotation axes
Inside the base structure of the polyhedron
I Hope, that without too much effort
You can meet this request-
Thanks for everything and have a nice day
al
7777.335 In reply to 7777.334
Hello Al,
here is a draft for a mirror node.
Have a nice evening
Karsten
7777.336 In reply to 7777.335
Sorry I nerver me remind!
It's for the classical, Modified or both Node Editor?
7777.337 In reply to 7777.336
Good morning Pilou,
it should work with the modified one. I hope that it solve Al's Problems or get proposals to improove it. Caused by private problems, it's a while ago, that I made some nodes. So I'm a little bit rusty at the Moment:-(
Have a nice day
Karsten
Show messages:  1-17  …  258-277  278-297  298-317  318-337  338-357  358-377  378-397  …  1858-1859
