 1-11  …  272-291  292-311  312-331  332-351  352-371  …  1852-1859
7777.312
Hi Friends
Some transformation test and Morph on Surfaces
using isocurves which shows instability in maintaining
the name chosen-
So if you launched the file the result will look different from the one
which you can see in the attached images ,
you have to set the right edges in tool Isocurve -
The second file Morph 3 , and skied with only the result Polygon
because despite many efforts to apply Sub I could not
It closes the program-
Maybe it depends on the power of my computer
Have a nice day to all
al
link:http://www.mediafire.com/file/ln2cit3mi3z1dwy/CP-Mod-Surf-Morph.rar
7777.313
Hi Friends
I want to share with us
this task :
an Helicoidal Staircase -
I hope it can help any of
you, as a start.......
best
al
file ( v.0.93 + Karst/tools)
link:http://www.mediafire.com/file/fsn5p48q33c7cao/CP_Helicoidal_Staircase.rar
Inspiration :)
7777.315
Hi Pilou
What show in the video, in a future ,
not too far , I think we can succeed
to do even with Elephant-
The important thing is that Max and Companions
implement a " Cluster Node "
as in Grasshopper , which allows to group
a series of operations , made with traditional nodes
they accept as various inputs (Slider)
those delegates to make the changes.....
for instance......
Scale, n ° pt, etc etc-
The Cluster will have as output the result
of all the manipulations carried out
through inputs into Entrance-
Grasshopper did you implement this system
from long ago
and I must say it works perfectly-
So we hope that Max & Co
create something similar, maybe improving it
We just have to hope-
best
al
7777.316
Hello Friends
I want to share with you, this......https://vimeo.com/66227736
I saw this video,very interesting, about the construction
Scenic for Dance, curated by architect, Calatrava
I rebuilt everything with Moi-Eleph-
I redid the same exercise with GH
aside the fewest number of nodes and the different
handling the result is the same-
I believe that the current level achieved despite
many improvements is remarkable.
Thanks again to Max, and others
are contributing to the improvement
of this fantastic tool-
best
al
File-http://www.mediafire.com/file/5oqw5ok25u6ffrd/Calatrava_Dance.rar
Excellent : i believe that you can make the same with LineWeb! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.10
else you can embeded the video! ;)
Architecture of Dance Santiago Calatrava Grasshopper Animation from qiaoqin on Vimeo.
7777.318
Pardon me Pilou, for replication .......
of course, in normal use could Moi
lineweb used to build the structured wire-
But here , we are in the n the "Parametric World"
the construction thus realized (from a glance at File)
It has many parameters manipulated,
therefore everything can be reconsidered, correct, etc. etc.
And this is the TRUE POWER ...........
On the other hand no one has yet implemented
lineweb Node in Elephant
Have a nice day
al
7777.319 In reply to 7777.318
Sure it's the power of the parametric world!
It was just a note! ;)
EDITED: 4 Apr 2017 by PILOU
7777.320
Hello Friends
Tired enough, but I succeeded
Low poly-giroid-
Minimal surf, obtained with Subdivide tool
best
al
http://www.mediafire.com/file/64v7y227uphe9nz/Minimal_Surf.rar
7777.321 In reply to 7777.320
Hello Al,
thanks for sharing. You are shooting in the right direction!
http://news.mit.edu/2017/3-d-graphene-strongest-lightest-materials-0106
http://advances.sciencemag.org/content/3/1/e1601536/tab-pdf
Have a nice day
Karsten
7777.323 In reply to 7777.320
Hi Al,
Your latest Gyroid nod file is brilliant.
However I can not get it to run.
I suspect it is my computer is hanging
because it cannot handle computational load.
I am confident that I have newer nodeeditor mod,
but just to check it is not a missing js file;
could you please upload your nodeeditor folder
zipped to mediafire.
Thank you
Yes because that is difficult to know if its the classic or modified Editor! ;)
7777.325 In reply to 7777.323
Hello James, Hello Pilou,
it's a modified one - this should hopefully work ...
http://moi3d.com/forum/index.php?webtag=MOI&msg=8197.7
Have a nice day
Karsten
THX for the efforts!
7777.327
Something to play ...
7777.328 In reply to 7777.325
Yes Karsten, that works
Thanks as always
7777.329
Hi James,thank you for appreciation , sorry but I forgot to specify
the version used in Nodeeditor ...( v.0.93 + Karst/tools)
In any case I see that Karsten has clarified the thing-
If not specified, my files are usually created
with the latest updates - Max , and Karsten tools
Good work at all
al
Not sure of what I must obtain but that works fine! :)
And quasi all in French! :D
Normal i have not yet translated all new nodes! :)
EDITED: 2 May 2017 by PILOU
7777.331
Hi to all Friends
I continue with the exploration of the Minimal Surfaces
Trying to make it happen with Elepphant-
I want to share with you the result obtained
To realize the Schwartz-P Surf-
.... One of the main bricks .......
In that regard I wanted to ask Karsten
If there is any way to enter
"Preserve Edges" in the SubD .node
Have a nice day
al
link-http://www.mediafire.com/file/pqv8zigfpgvqcaf/Schwartz_P.rar
Show messages:  1-11  …  252-271  272-291  292-311  312-331  332-351  352-371  372-391  …  1852-1859
