 1-13  …  254-273  274-293  294-313  314-333  334-353  …  1854-1859
7777.294 In reply to 7777.293
Hello Pilou,
the modified one;-) caused by shiftDublicate, but it's possible to replace it by interp here :-) to work with the core version.
Have a nice day
Karsten
7777.295 In reply to 7777.292
Hello Ced,
your mod-UI is independent from the nodeeditor installation, so you don't have to fear about that.
And someone called Gates told us: "Allways have a backup"
By the way, a very untested flow node is present in the modified version:-)
(I hope I get you right)
Have a nice day (from far far away)
Karsten
7777.296
Yeah! I have ORGANIC surfaces, which, if the ARRAY, pattern & Fibonnaci nodes 'FLOW ON SURFACE' would make my dreams come true! I've been trying to make textures & patterns generate in matrix & double reverse matrix with SLIDER SIZING - to seamlessly FIT & WRAP.
That way I can take a sunflower head - a flat one, and flow it onto a complex network curve or lofted surface -
I'm almost caved-in to buy 3d Coat!
M C Humperdinck
7777.297
Dear Karsten
Thank you so much for your generous time in helping me learn more about Nodebundle and for the well-described .nod file. I appreciate your help, especially given I am new around here!
Thank you, Michael, for your note, thanks for making all this possible
Enjoy the rest of your weekend,
Christian
7777.298
I wanted to share a little update, I have been playing with the file Karsten kindly created all afternoon, and found that I was able to begin adjusting the Z-coordinates on a hemisphere. I hope to eventually space the points successfully to a sphere, or other surfaces.
7777.299
Exactly! That's exactly right: Flow to Surface!
To add sliders - or input values into a box would be ideal - what that would do is take Moi3d to a whole new level of parametric - terrazzo modeling which is piss-poor in Rhino!
There are other tools e.g., Armadillo & parametric tools, however they aren't nearly as intuitive as Moi's NODE functionality.
I'm looking into the adding a webinar functionality to this 'Behive Forum' which is without live video broadcast capabilities - sadly.
If possible I may setup a live cam forum for brainstorming & sharing scripts, shortcut keys & nodes, as well as cool tips & tricks within - is this something that the inmates of this auxiliary lunatic asylum would be interested in - participating?
Perhaps, with those added tools increasing the functionality of the foundation Michael has built, together we could add-on creative branches which would take Moi3d in a direction which would carve out a soft 'pattern parametric array glow in surface terrazzo' object - that compliments hard edged CAD.
I may be off topic - if so - I'll begin a new post on this subject: webinars
Cheers,
Bill Gore
7777.300
Hi Friends
It was a long time that I wanted
ask,
I take this opportunity with the post of
Christian ....
It would be nice to have a Voronoi Node
am looking forward to
Have a nice day to all
al
7777.301
Hi Friends
The Elephant goes on.......
I want to share with you
some tests on creating connections
using the tool Subd-
link;
http://www.mediafire.com/file/8ky2awu5amv991v/CP_Joint.rar
best
al
7777.302
A quick follow-up to my previous post.
Using Nodebundle > ArrayGem > Scale Array (thanks, Karsten & Michael!), I was able to produce a Phyllotaxis-like Succulent. Rendered in Keyshot.
At some point, I hope to manipulate the points in 3D (versus 2d point pattern > flow), so they space correctly over a surface as described in the Mathematica article http://blog.wolfram.com/2011/07/28/how-i-made-wine-glasses-from-sunflowers/.
7777.303 In reply to 7777.302
Wonderful rendering Christian !!!
My compliments !!
7777.304
Nice shot Cristian
and nice render....
Could you share with us the nod. file of your creation?
Phyllotaxis is a subject that fascinates me greatly
have a nice day
al
Appetizing vegetal!
7777.306
Thanks very much!
Please see attached .nod, which simply adds the z-Coord's to Karstens original version.
I used ArrayGem to duplicate the leaf to each point, then ScaleArray to gradually increase the size of leaf.
Size: 715.2 KB, Downloaded: 239 times, Dimensions: 1000x611px
7777.307 In reply to 7777.306
Is it possible a clip how to exactly download, install & make this double-reverse helix?
I also would like to know if there is a repository where all, or most of the nodes are available.
I've got my Moi3d modded supremely with commands, scripts, shortcuts & lighting options, not to mention tricked-out the GUI & ICONS, therefore I'm not keen on destroying the beautiful setup I have now. Nevertheless, I'm looking at finding a means to download, install & build what I see nodes are capable of creating - I just don't want to guess at what to download - install - and how to configure.
I find that the general inmate population here wish to prevent Moi3d from becoming super charged, (too) populated with many sweet scripts, shortcuts, nodes, lighting options, interface skins & icons, however isn't there a way to present an install option where one could ENABLE / DISABLE add-ons during installation for those of us who would like those gems?
Why not have a questionnaire - survey ha-ha!
It's interesting understanding how 3d Coat compliments Moi3d, and how it compares to Rocket 3f.
I'm hardcore Rhino 5 & T-Splines - and trying to beef up Moi3d in order to give me every possible advantage as far as the add-ons here. The downside is that it requires a month of reading forum posts in order to
ferret out the latest & greatest complimentary tools which this pool of genius's conjure up!
Ced
7777.308 In reply to 7777.306
It looks great Christian!
7777.309
Hello Cristian
thanks for your file sharing;
Excuse me, but I thought the whole building
It had been carried out using only
Elephant " feature"
thanks again and have a nice day
best
al
Phylloz works with "Classic" Elephant or "Modified" ? ;)
7777.311
Hi Friends
another exercise about building
a mathematical snail
link:http://www.mediafire.com/file/84a9gt81ksrbfe3/CP-Archim.Snail.rar
best
al
7777.312
Hi Friends
Some transformation test and Morph on Surfaces
using isocurves which shows instability in maintaining
the name chosen-
So if you launched the file the result will look different from the one
which you can see in the attached images ,
you have to set the right edges in tool Isocurve -
The second file Morph 3 , and skied with only the result Polygon
because despite many efforts to apply Sub I could not
It closes the program-
Maybe it depends on the power of my computer
al
link:http://www.mediafire.com/file/ln2cit3mi3z1dwy/CP-Mod-Surf-Morph.rar
7777.313
Hi Friends
I want to share with us
this task :
an Helicoidal Staircase -
I hope it can help any of
you, as a start.......
best
al
file ( v.0.93 + Karst/tools)
link:http://www.mediafire.com/file/fsn5p48q33c7cao/CP_Helicoidal_Staircase.rar
Show messages:  1-13  …  234-253  254-273  274-293  294-313  314-333  334-353  354-373  …  1854-1859
