 1-12  …  1813-1832  1833-1852  1853-1859
7777.1853
"ConnectPoints" node
Update: range mode
Address: Curves2/ConnectPoints
7777.1854
An update on "idxSelect" node
Inverse mode added.
7777.1855 In reply to 7777.1854
MO,
Thank you very much for update of "idxSelect" node.
This incremental change will have a profound effect on the usability of NE.
There is another node that could be revised to great effect.
Less incremental change than change to increments.
Please see link below:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.3
There several ways this could be achieved, but perhaps the easiest would be to introduce a RMB option as per image below
What do you think?
7777.1856 In reply to 7777.1855
I'm glad you liked it.
I did take a look at "Knob" node.
It looks a bit scary to be honest! :)
Maybe I can add a "step" property, but not sure.
7777.1857
Unfortunately I couldn't find a decent way to do this, But somehow I managed to reach a result.
I added a "step" property.(Default: 1 But it can be negative too)
It can increment by step number, but the incremental mode works only with mouse wheel.
I post it here in case someone wants to use or improve it.
7777.1858
"ArrayGem" node
Inputs:
Object: Objects + an optional base circle
Path: curve/curves
Surface: To set objects orientation (optional)
Address:
Objects2/ArrayGem
7777.1859
EDITED: 10 Apr 2023 by MO_TE
Show messages:  1-12  …  1793-1812  1813-1832  1833-1852  1853-1859
