 1-8  …  1809-1828  1829-1848  1849-1859
7777.1849
Hello James,
I tried to recreate what you have made here: https://www.instagram.com/p/CbAAG0Xrssv/
However, for me, it doesn't work! I have problems creating an Array with Knob
.nod file is attached.
Could you please help me through it?
7777.1850 In reply to 7777.1849
Psygorn,
The equation that feeds into "Z" input of point node should be:
sqrt(a-pow(sqrt(b),2))*c
Also the cone needs to be beefed up in size, & importantly
have a negative number for "Height" input so it points outwards.
I used "Radius": 15 "Height" : -35
7777.1851 In reply to 7777.1850
Hi James,
Thank you for your reply I am using sqrt(a-pow(sqrt(b),2))*c to feed into "Z" input of the point node now. however, I still don't get your result!
No need to mention I changed cone specifications to what you suggested there appears only one cone!
My question is that I see your "shiftDublicate" node says "numArray" while mine says "In" what am I doing wrong?
7777.1852 In reply to 7777.1851
Psygorn
Not sure why it is not working your end, because your NOD file with
the recommended changes works for me.
You could try replacing "shiftDublicate" node with "Basic/Progression" node.
In this setup, they are effectively the same, and "Progression" node
would be the more obvious choice, however when I built this circuit
I was initially attempting something different from what I ended up with.
Sorry if this created confusion.
EDITED: 14 Mar 2022 by JFH
7777.1853
"ConnectPoints" node
Update: range mode
Address: Curves2/ConnectPoints
7777.1854
An update on "idxSelect" node
Inverse mode added.
7777.1855 In reply to 7777.1854
MO,
Thank you very much for update of "idxSelect" node.
This incremental change will have a profound effect on the usability of NE.
There is another node that could be revised to great effect.
Less incremental change than change to increments.
Please see link below:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.3
There several ways this could be achieved, but perhaps the easiest would be to introduce a RMB option as per image below
What do you think?
7777.1856 In reply to 7777.1855
I'm glad you liked it.
I did take a look at "Knob" node.
It looks a bit scary to be honest! :)
Maybe I can add a "step" property, but not sure.
7777.1857
Unfortunately I couldn't find a decent way to do this, But somehow I managed to reach a result.
I added a "step" property.(Default: 1 But it can be negative too)
It can increment by step number, but the incremental mode works only with mouse wheel.
I post it here in case someone wants to use or improve it.
7777.1858
"ArrayGem" node
Inputs:
Object: Objects + an optional base circle
Path: curve/curves
Surface: To set objects orientation (optional)
Address:
Objects2/ArrayGem
7777.1859
EDITED: 10 Apr 2023 by MO_TE
Show messages:  1-8  …  1789-1808  1809-1828  1829-1848  1849-1859
