 1-7  …  1788-1807  1808-1827  1828-1847  1848-1859
7777.1828 In reply to 7777.1826
the node you need is the concat.
Barry
7777.1829 In reply to 7777.1828
Problem of Nodes system : when you stop for a while you forget all! :)
Even you have made the Library ! ;)
https://moiscript.weebly.com/basic.html#bibeconcat
7777.1830 In reply to 7777.1828
Thank you Barry-H :)
By the way do you know if it is possible to do this (Selecting certain edges of unioned mesh) or not?
7777.1831 In reply to 7777.1829
I understand PILOU :)
Is there a manual to read and learn the functionality of nodes?
in a glance https://moiscript.weebly.com/construct.html#bibeunion I was not able to find out how "select" works for example.
Should I keep digging into above link?
or is there another source for learning that kind of things.
7777.1832 In reply to 7777.1831
You have all nodes here with their explanation so it's not exactly a manual but...
in English...and in French ;)
You have Selected Node
https://moiscript.weebly.com/objects.html#bibeselected
and this shows (2 lines bottom) the action on the Select Node on this page : https://moiscript.weebly.com/node.html
EDITED: 8 May 2021 by PILOU
7777.1833 In reply to 7777.1832
Ok
So, digging it is! :)
7777.1834 In reply to 7777.1833
Bon courage! It's not so evident!
7777.1835 In reply to 7777.1830
Hello guys!
I still have don't know how I could select those edges I had highlighted on the attached photo!
Could anyone help me out here?
7777.1836
Dear all,
I tried to use the OFFSET node to create a bigger version of a closed curve object i.e. a rectangle.
When entering a "Dist" number into the editor of this node, i.e.10, the rectangle gets a 10mm negative offset and is getting smaller. Entering negative numbers is not accepted. Switching the "Both" parameter to "YES" is creating both offset rectangles correctly.
My issue now is that I only want to have the bigger rectangle and not both.
Do I misunderstand the node or do I use it in the wrong way?
Thanks in advance for any ideas or proposals how to get this working.
Joerg
Size: 68.7 KB, Downloaded: 146 times, Dimensions: 707x878px
7777.1837 In reply to 7777.1836
I will investigate your problem :)
Maybe like this ?
7777.1839 In reply to 7777.1838
Thanks Pilou!
The FLIP parameter is doing the difference!
Really strange, I was pretty sure that I tested yesterday all parameter including different permutations but always failed. But maybe I simply did not test this combination or the restart of the computer solved the issue.
But however now it works, thanks again Pilou!
7777.1840
I need to do some calcs in a MATH node. I am looking for a function like integer(), but this one seems not to exist.
Do you know where I can find a summary about available functions that can be used in the MATH node? I know the simple + - * / PI sin cos tan ( ) but I assume that there might be more ;o))
Thanks, Joerg
7777.1841 In reply to 7777.1840
See posts by Max, a few years ago.
Also see nodeeditor code, e.g. in notepad++.
See Javascript functions, Ecmascript 5, for example at W3 site
7777.1842 In reply to 7777.1841
Thanks Brian. Sometimes it's really the easiest to directly look into the code although Java is not a know language for me. But Max did a very good readable code, so it was easy to simply add the ROUND() function to the list of codes.
In line 78 of basic.js the function can be added:
this.properties = { mode:["Long","Long","Short"], f:"a+b", preset:["a+b", "a+b", "a-b", "a*b", "a/b", "sin[a]", "cos[a]", "pow(a,b)", "round(a)"], a:[1], b:[1]};
Works now perfect for me.
7777.1843 In reply to 7777.1842
Thankyou sunspeed for sharing your Javascript (5) solution.
Is bundlePts available anywhere?
Is bundlePts redundant?
Was bundlePts replaced with some combination of array nodes?
As per Karsten, bundlePts combines the 1st point of each input array, then 2nd point of each input array, etc., which seems to be one of the multi process combinations?
Search of +bundlePts only yields 6 mentions.
7777.1845 In reply to 7777.1844
Brian
"Bundle" node in "ArrayExt" menu is multi-modal: Points, as well as Numbers& Objects.
EDITED: 12 Mar 2022 by JFH
7777.1846 In reply to 7777.1845
Thank you James.
So, to clarify my understanding:
The old bundlePts node is redundant, or superceded and replaced.
Instead, under the "ArrayExt" menu, use the "bundleArray" node, in "Points" mode, as a replacement.
bundleArray has three modes, Points, Numbers, or Objects. These correspond to input and output pointarrays, numarrays, or objarrays.
bundleArray grabs the 1st element of each input array, and outputs them sequentially in an array.
Then grabs the 2nd elements, and outputs them.
etcetera, to the ends of all of the input arrays.
If an input has less elements that the other inputs, EDIT: THE GRABS STOP. (=Short)
(slice(s) or cross section(s) of arrays?) (Some explanation by Max in multiprocess mode combinations? Short, NOT Long). (See James next post.)
So if the input array elements are arranged in Rows, the output would be the Column elements, sequentially. Or vice-versa.
For example, isoline u elements could be converted to isoline v elements.
Weft could be converted to Warp(???) EDIT: Well, see next two posts for elaboration.
EDITED: 13 Mar 2022 by BEMFARMER
7777.1847 In reply to 7777.1846
Brian,
quote:
If an input has less elements that the other inputs, it contributes no element for the remaining grabs.
(slice(s) or cross section(s) of arrays?) (Some explanation by Max in multiprocess mode combinations? Long or Long+?)
You have alluded to a flaw in bundle node: effectively it is "Short" list matching only. If you look at the image below,
the final list should, if it did "long" matching, include "4" at the end. This is also the case with ptArrays & collections of objects.
For example, isoline u elements could be converted to isoline v elements. Weft could be converted to Warp.
I'm not clear how bundle node could perform the operation of swapping warp & weft of ptArray, but the means of achieving this would certainly be useful.
See Pilou's post for brief explanation of array matching modes
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=9476.66
EDITED: 13 Mar 2022 by JFH
Show messages:  1-7  …  1768-1787  1788-1807  1808-1827  1828-1847  1848-1859
