 1  …  1762-1781  1782-1801  1802-1821  1822-1841  1842-1859
7777.1802 In reply to 7777.1801
I type "ls" a lot which is lowercase LS
It means "list the files in the current directory".
I'm looking around and it seems like there's a program called TortoiseGit which is popular on windows and it looks easy to use. No typing commands. I'll play around with it and investigate. In the meantime, I've asked Michael what the license permits.
I'll be around in discord to help with step-by-step instructions.
7777.1803 In reply to 7777.1802
ok! And one mystery resolved! :)
7777.1804
Michael is ok with my distributing the source code via .zip file. (Thanks Michael!!)
I recognize this is easier than git. (But still -- git is awesome it's well worth learning even if you're not a programmer!)
https://github.com/nkallen/elephant/releases/tag/v0.1-alpha
You will need to download elephant.zip commands.zip and MainWindowLayout.xml
1. Unzip elephant.zip into AppData.
2. Unzip commands.zip into your main MoI executable folder (replacing the old commands/ folder BUT MAKE A BACKUP)
3. Replace ui/MainWindowLayout.xml with mine. BUT MAKE A BACKUP
This is I hope easier!
7777.1805 In reply to 7777.1804
Hi Nkallen.
Thank you for your plugin, very interesting!
When cloning nodes from the widgets group through the context menu of the node, the program returns an error, the application screen shows which nodes cause the error.
Still, Git is primarily focused on programming, and it's easier for most people to use files in a folder.
Size: 73.3 KB, Downloaded: 154 times, Dimensions: 764x589px
7777.1806
Git resists ...
Size: 81.4 KB, Downloaded: 150 times, Dimensions: 1025x544px
7777.1807 In reply to 7777.1806
so take the install by ZIP! :)
BOTTOM PAGE!!! https://moiscript.weebly.com/install-elephant.html
7777.1808 In reply to 7777.1807
Everything is simple there, with Git there is a desire to understand:)
Size: 717.5 KB, Downloaded: 348 times, Dimensions: 1920x1078px
7777.1809 In reply to 7777.1805
This bug should be fixed. If you're using git, you can execute "git pull origin master" in the AppData/elephant directory. Otherwise, I'll bundle a new zip in a few days
7777.1810 In reply to 7777.1809
I recommend everyone using this to add the following keybindings:
script:moi.ui.getUIPanel("moi://appdata/elephant/index.html").graph.showPreviousHistoryItem();
script:moi.ui.getUIPanel("moi://appdata/elephant/index.html").graph.showNextHistoryItem();
and bind them UpArrow and DownArrow
7777.1811
Hi Nkallen.
When using the Extrude command, the program returns an error.
Size: 221 KB, Downloaded: 146 times, Dimensions: 1714x1005px
7777.1812 In reply to 7777.1809
I was never able to install the patches through Git.
I used the usual file replacement. It's sad.
7777.1813 In reply to 7777.1812
Hey WN -- sorry about not getting git to work. I think I'd need to talk to you 1:1 on discord to see what went wrong.
In any case, I take it you succeeded at doing "git clone" for the AppData folder? That's great because you can update to the latest code by typing "git pull origin master" in that folder.
I think I may have fixed your bug as well, it's pushed to master. I .zip release will come next week
7777.1814 In reply to 7777.1812
Yep guys, join us on discord. Easy to chat and discuss problems and help out :)
https://discord.gg/zNTasYd invite link
7777.1815 In reply to 7777.1813
Hi Nkallen.
Yes, you can talk, since this is done mechanically without understanding the process, in general terms,
I understand that there is a process of changing existing files, they add the necessary commands to certain places,
but this is not enough.
Yes, I managed to clone the repository via Git and I updated it today, and the bug with cloning the widget is fixed, thank you.
But the error from my previous post is not fixed.
7777.1816 In reply to 7777.1813
Hi Nkallen.
You need to create a separate thread on the forum, as these are different plugins.
Here's another mistake, nod "Number" returns an error if the counter is less than the value in the properties.
Where is it more convenient for you to receive error messages?
Size: 80.4 KB, Downloaded: 174 times, Dimensions: 1135x744px
Size: 44.9 KB, Downloaded: 136 times, Dimensions: 1019x621px
7777.1817 In reply to 7777.1816
Report them on the github (https://github.com/nkallen/elephant/issues) if you can or visit us on discord :)
7777.1818 In reply to 7777.1816
Hey -- I'll look at these bugs today. I definitely like discord if that works for you. Here's the invite:
https://discord.com/invite/zNTasYd
SetName.js is a node to re-Name a geometric Object. It is a script which adds the SetName node to the Objects2 menu, and may be placed in the nodeeditor> node>Extensions folder.
The node may be placed just before an Output Node. The desired output name may be typed in the Name field. Saving your node program also saves the modified Name.
It is a minor modification of Karsten's SetStyle node. Rainbow was commented out.
Seems to work OK, but I do not really know what I am doing... Also, only very limited testing was done.
Also, Karsten's BrepNameSubObjects node is throwing an error, in MoI4, when the input is curves, rather than a surface.
It works with a gyroid patch surface to name faces and edges.
(did not try MoI3.)
EDITED: 24 Mar 2021 by BEMFARMER
Any idea for "disapear" the result of the Trimming piece so keep the "big cube" trimed and disapear the little angle!
(or how select the little trimmed piece ...or mke it "invisible" ...)
Beacause TrimObj Node as no parameter included :(
here it's manually move after the node TrimObj
7777.1821 In reply to 7777.1
Hello all,
Well I am new to Nodeeditor in MOI 3D, I am currently using "nodeeditor 1.1 jms"
I have downloaded the attached files. and I see this:
As you can see "Run" is not active! how can I fix it?
I appreciate any help :)
Thank you Karsten for sharing! :)
Show messages:  1  …  1742-1761  1762-1781  1782-1801  1802-1821  1822-1841  1842-1859
