 1-3  …  1744-1763  1764-1783  1784-1803  1804-1823  1824-1843  1844-1859
7777.1784
>I have seen this incredible thing by nkallen ! I believe that is in WIp but...very promising! (Pilou)
Elephant knot editor to automatically create knots when modeling. It would be really very useful for modeling, learning to master MoI, the node editor, etc.
7777.1785
Cool ... will be fine if it's will compatible with the new Max Smirnov NodeEditor for the v4 (if projected)
7777.1787 In reply to 7777.1785
One hour ago youtube by NICKKALLEN:
https://www.youtube.com/watch?v=i-5Oj1zPjpo
Cannot find any sign of a demo program.
Someone should subscribe and ask about the availability of the program?
EDITED: 1 Mar 2021 by BEMFARMER
You can install and try the New Node Editor by Nkallen
Principally record something for parametrize it!
(I am trying to install it... not evident for me! :) even the readme...
https://github.com/nkallen/elephant/blob/master/README.md
https://github.com/nkallen/elephant/tree/master
EDITED: 1 Mar 2021 by PILOU
7777.1789 In reply to 7777.1788
Edit: deleted most of this post to avoid creating confusion.
Good find Pilou,
7777.1790 In reply to 7777.1789
Hi everybody,
This video walks you through how to install it on Windows. I'm encouraging people for now to use git rather than downloading zip files etc. I'll make another video for Mac users tomorrow.
https://www.youtube.com/watch?v=jsTGCHa-pZk&t=1s
Reminder that this is just a preview release. Consider it an alpha.
7777.1792 In reply to 7777.1790
Thank you nkallen.
On Windows 10, got git installed, and did the first two steps done, the git clone... and git checkout...
Hung up on git commands.patch.
Very slow internet here. Cannot watch video until tonight.
Will try again tonight with fast internet, and watching video.
My file explorer directory structure was temporarily messed up, I guess from git am --directory commands...
>>>After a reboot, the directory structure is back to normal. I'll have to follow the video directions for Windows 10.
The other Readme file in elephant-0.1-alpha, refers to a third patch file,
git am --ignore-whitespace elephant.patch
It is confusing.
Will try again tonight...
The second readme also has Win instructions...
7777.1794 In reply to 7777.1793
Hi, I think following the video should be best, I'm still working on the README
7777.1795 In reply to 7777.1794
Fantastic project nkallen, thank you for your hard work!
(I edited my prior posts a bit.)
By following nkallen's video I was able to install the node graph. The program seems to work.
Also I had to put in my email address, and my username.
Unfortunately I did not understand about trial/, so do not have a backup of MoI, just the altered "master". Edit incorrect statement.
I guess I'll have to reinstall MoI4...
MoI4 successfully reinstalled.
Edit, so trial\ refers to MoI 4.0 beta, not to the git "backup".
EDITED: 2 Mar 2021 by BEMFARMER
7777.1797 In reply to 7777.1796
Does the result of this "new" NodeGraph is just modified Folders / FIles ?
So will be fine if we can just copy past these new Folder / Files
because this "Git" is very painful! Not yet success! Too much syntax errors, spaces, / , \ etc... a nightmare!
You lost me at video 3.2 minutes! :)
7777.1798 In reply to 7777.1796
The purpose of git is to keep copies of documents and manage different versions of them.
In the video when we do “git commit -m ‘Initial commit’” we make a backup of your moi folder before any changes are made. You can always go back to your initial commit no matter how many changes you make afterwards.
7777.1799 In reply to 7777.1798
Yep but for old eyes like me it more easy to make something like this :)
for any Folders / Files who are changed by the nodegraph
NodeEditor_oldMax (so will not called by the program)
Nodegraph will called by the prog
and when i have finished I just rename
NodeEditor (so will called by the program
Nodegraph_old_nkallen (so will not called by the program)
that takes 3 seconds and not headaches! and no need to use Git :)
Of course if this sort structure is accepted by your "nodegraph" Folders / Files modified ...
and if you can provide the Folders/ Files modified!
7777.1800 In reply to 7777.1797
I see that this is more painful than anticipated...
In the software industry / in open source/ among hobbyists, we almost always distribute source code using a version control system like git. It allows us to safely keep backups of files, and also easily upgrade to new versions. I would strongly encourage the moi community to consider using Github or something similar rather than passing around .zip files without any version history. There is a learning curve but it is a life-saver - I swear. You can ALSO produce easy-to-install zip archives, but code is happiest (and safest) when its in version control first.
Around 3.20 in the video, what I type is just to go to different folders on your hard drive. You can type:
cd /c
cd "Program Files"
cd "MoI 4.0 trial"
(Presumably you're not using the trial but I don't know the name of the non-trial folder on windows)
I have to ask Michael if I can distribute my changes as a .zip. For example, does the license permit me to distribute a modified version of Fillet.js? So far I'm using a .patch file which allows me to share my changes without ever distributing Moi3d's original source code.
7777.1801 In reply to 7777.1800
I understand your point of view...so wait and see :)
during the video we have on begin Git line "1s" or "ls"... or ...other what is it exactly?
ps No trial is that in no Roaming folder
C:\Program Files\MoI 4.0
7777.1802 In reply to 7777.1801
I type "ls" a lot which is lowercase LS
It means "list the files in the current directory".
I'm looking around and it seems like there's a program called TortoiseGit which is popular on windows and it looks easy to use. No typing commands. I'll play around with it and investigate. In the meantime, I've asked Michael what the license permits.
I'll be around in discord to help with step-by-step instructions.
7777.1803 In reply to 7777.1802
ok! And one mystery resolved! :)
Show messages:  1-3  …  1724-1743  1744-1763  1764-1783  1784-1803  1804-1823  1824-1843  1844-1859
