 1-13  …  1714-1733  1734-1753  1754-1773  1774-1793  1794-1813  …  1854-1859
7777.1754 In reply to 7777.1753
Interesting read that Frenchy, he goes from fonts to tiles...genius.
https://en.m.wikipedia.org/wiki/Truchet_tiles
7777.1755 In reply to 7777.1754
OK! You have also this cool one! ;)
Kite & Dart by Roger Penrose (Periodic, Aperiodic etc...)
7777.1756 In reply to 7777.1755
You might like this or get some node ideas maybe...leads onto "3d tiling".
https://www.cosmic-core.org/free/article-63-number-the-hexad-part-3-tessellations-tilings/
7777.1757 In reply to 7777.1756
Look this post and aespecialy Muqarnas ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1463
Made a helicoid node.
The v curves made with the stock Curve factory to not pass through the helical points.
The convertPts2 node uses MoI's Interpcurve factory so the curves pass through the points.
Max's Curve node has other versions of Interp., but the u and v points are not separated for inputs...
If network does not create the surface, or takes too long, a radial curve may be swept along the inner and outer helical curves.
Javascript cosh(x) and sinh(x) are not part of ecmascript5.
The generalized formula for the monkey saddle surfaces is given here:
https://www.researchgate.net/publication/256808897_Monkey_Starfish_and_Octopus_Saddles
The binomial coefficients (N K) (vertical), for each order N saddle, are given in a row in pascal's triangle, using alternate entries.
For example, the Monkey saddle, with 3 dips, has coefficients 1 and 3.
The Octopus saddle, with 8 arm dips, has coefficients 1, 28, 70, 28, and 1.
Or the binomial coefficients can be easily calculated with factorials.
The formula for each order N, uses the Even values of K = 0, 2, ... (N for even N, N-1 for odd N).
The formula is the sum from K=0 to K=N of the binomial coefficient (N K) * x to the power(N-K) * y to the power(K),
* even powers of i, for a +/- factor.
Note that the .nod files use ConvertPts2 node, which can be downloaded elsewhere on the forum.
Network can be done on the curves, and the surfaces may be trimmed at a +/- z value.
The smelt petal is a trimmed Monkey saddle, with the Monkey saddle z-axis passing through the origin, and (1,1,1)
The z = f(u,v) in MathPoints may be easily done for 4, 6, and 7 arm_leg_tail dip surfaces.
EDITED: 1 Nov 2020 by BEMFARMER
7777.1760 In reply to 7777.1759
Great work! Converting formulas to programs is very challenging.
Wayne
Is there some way to add functions to MathPts node?
For example, perlinnoisefn.js, delaunator.js, and basicFunctions.js have functions used by other programs.
A very simple example would be say ellipticfn.js containing several functions, including
this.cosh = function(a,x)
var y = (a/2) * ( Math.exp(x/a) + Math.exp(-x/a));
return y;
Is there some way to get MathPts f(u,v) to be able to use cosh(a,u) with say elliptic.cosh(a,u)?
(Of course the catenary equation (a/2)* )exp(u/a) + exp(-u/a)) can be used in MathPts directly, but some other
desired functions are very much more complicated, with dozens of lines of code.)
Trying to debug a node program.
Is there some way to add an alert message to a node program?
Example:
function alert( msg )
moi.ui.commandUI.alert( msg );
alert( 'a = \t' + a + '\n\n' + ' b = \t' + b );
7777.1763 In reply to 7777.1762
Hi Brian, try moi.ui.alert( 'msg' );
7777.1764 In reply to 7777.1763
Thank you Michael.
Now the alert works. Each pass through the for loop creates a new alert.
The script probably has minor errors.
Idea:
Include code around and/or in the for loop to show multiple progressive results for each variable.
In a row/column format. One row per variable. Each column is another pass through the for loop.
Say batch 10 alerts into one...
(My other projects have higher priority:-)
https://stackoverflow.com/questions/25320250/convert-multiple-alerts-to-one-alert
My latest script is creating junk points, so did some web exploring.
A math.js library of many additional functions, from 2017 to present.
(complex numbers, hyperbolic, elliptic, Weierstrass, etc.)
May be usable for MoI scripts and Nodes?
Still would need a "link" for MathPts node, somehow?
https://github.com/paulmasson/math
Barely began to explore the library.
Update to CMC6 node, creates Nodoids and Unduloids, in particular their profile curves.
Rebuild, Mirror, Array, and Revolve left to the user.
Place CMC6.js and the helper functions ellipsefn.js file in the nodeeditor>nodes>extension directory.
CMC6_test.nod produces symmetric half of the nodary curve.
The CMC6 node script creates profile curves in the xy plane, including of most interest, the nodary curve and the undulary curve, depending upon the values of mu and lambda.
The Delaunay Constant Mean Curvature (CMC) surfaces consist of the cylinder, sphere, catenoid, unduloid, and nodoid. The surfaces may be produced by revolving their respective profile curves about a revolve axis equal to the rolling (roulette) line, which was used to generate the profiles. The profile curves are the roulettes of line, circle, parabola, ellipse, or hyperbola, along said roulette line.
The roulette axis for the nodary curve passes through the upper vertex of the hyperbola, which the script has not yet found.
There are additional notes in the comments in the script js file.
This node script uses ellipticfn.js for F(phi,k) and E(phi,k) the incompletic elliptic integrals of the first and second kind. It is assumed that "k" in the paper is the same as"k" in the elliptic functions, rather that using "k*k" in the functions.
(Strangely, the y values must be divided by 2 to get the proper sphere and cylinder profiles.)
[See post 1777 for updated CMC files.]
EDITED: 30 Nov 2020 by BEMFARMER
7777.1767 In reply to 7777.1766
The paper also describes using two radii as inputs for mu and lambda, so more work may be done.
Connection to the semi-major and semi-minor axes of ellipse and hyperbola is also a question.
There are several papers using nodulary curves for membrane fusion, squashed bubbles, etc., but their equations did not seem to work...
7777.1768 In reply to 7777.1767
The undulary curves seem to work. The values of mu and lambda are positive, but
must be very small, as per mu constraint.
EDITED: 20 Nov 2020 by BEMFARMER
7777.1769 In reply to 7777.1768
The nodoid and profile are colored coral.
Using Orient Line/Line, the blue unduloid became emerald, and was connected to the Honeysuckle unduloid.
RadiiInputMacros.zip contains two Macros, with inputs RadiusMax and RadiusMin from the symmetry axis line.
Outputs are mu and lambda. (Simple formulas from the paper.)
Nodoid Radii.nod is a front end Macro for producing Nodulary profiles.
Unduloid Radii.nod is a front end Macro for producing Undulary profiles. For minRadius = 0 a quarter arc is supposed to form, (sphere CMC), but
in actuality, one quarter of an ellipse is formed. (So there may be some error somewhere, the paper or the node.)
Place the two Macros in the Nodeeditor Macro folder. Wire in either as input to the CMC4 node. For input to either Macro,
two radius input sliders can be wired in.
The Macro menu in a nodeeditor window does NOT scroll. So space for the number of Macros is limited by the height of the canvas window.
Changing k to k*k had no effect, re elliptic integrals. The quarter ellipse profile remained the same, and did not turn into a quarter arc.
Slider radius inputs for nodoid of 0 to 2 seem nice. Divide by zero and infinity seem to be handled OK by nodeeditor.
Note that revolve axis is parallel to the y axis, in the xy plane. Which line, and the position of the hyperbola and the roulette line is not clear.
The roulette line for the nodulary is to the right of the nodulary curve, focus length from its vertex. (?)
Which I think should be the revolve axis?
See post 1777 for node containing radii macros.
Node to produce the upper curve of a hyperbola, and its focus point.
"a" and "b" are the semi axes. The node uses exponential equations for cosh and sinh.
A tangent from an end point can be built, but there are two of them, which seems wrong.
One tangent passes through the origin, and the y intercept is Not the Conic command apex point.
The second tangent passes through the y axis a bit lower down, and using this apex point,
the MoI conic command can produce the same hyperbola curve visually.
Upon zooming way in, the MoI conic nurbs curve is slightly different, probably due to the limited
number of points used for the node program.
There is probably some formula for calculating the Conic command parameters from a and b...
The new Dimension commands are very useful for labeling the geometry.
Corrected faulty hyperbola node. I wondered why the ends were drooping:-)
(Note that using Michael's Hyperbola script is preferable.)
EDITED: 22 Nov 2020 by BEMFARMER
7777.1772 In reply to 7777.1771
Hi Brian, here are a couple commands for making a Hyperbola and Parabola from foci points.
7777.1773 In reply to 7777.1772
Thank you very much Michael.
Your Hyperbola script works perfectly.
I think I will try to roulette it along a vertex line, with tangents and cplanes, and trace focus,
but will not be able to get all the way to infinity :-)
With var pt = cplane.evaluate( x, y, z ); (Or some such) And unwrap curve...
EDITED: 21 Nov 2020 by BEMFARMER
Show messages:  1-13  …  1694-1713  1714-1733  1734-1753  1754-1773  1774-1793  1794-1813  1814-1833  …  1854-1859
