 1  …  1662-1681  1682-1701  1702-1721  1722-1741  1742-1761  …  1842-1859
7777.1702
A simple fractal for the Node Editor.
Wayne
EDITED: 17 Jan 2021 by WAYNEHILL5202
the ".js" must be \Moi\nodeeditor\nodes\extensions\
Cool !
+ Fat lines by Max Smirnov & Extrude!
http://moi3d.com/forum/index.php?webtag=MOI&msg=7594.31
7777.1704
Here's a node circuit for the generation of a interlinked woven screen.
Be warned that it may take a minute or so for geometry to generate.
Requires most current extension nodes, found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10
7777.1705 In reply to 7777.1704
It's unbelieveble what interesting geometry you can create via nodes.
Excellent!
Mik
7777.1706
Hi :)
New NE core build:
http://moi.maxsm.net/files/nodeeditor/nodeeditor.v.1.1.2020.07.14.zip
Minor interface updates, bugfixes etc.
7777.1707 In reply to 7777.1706
Welcome back Max,
So good to hear from you.
I've downloaded... can't wait to see the changes
Thank you for your continued support of NE
EDITED: 14 Jul 2020 by JFH
Evergreen! :)
7777.1709 In reply to 7777.1707
v.1.1 (14-07-2020)
Changes since v.1.0.rc3 version (03-10-2018):
index.html
added:
- utf-8 support
color.js
added:
- io_text_highlight and io_highlight variables
editor.js
fixed:
- open file dialog error
init.js
added command line parameters: file, step, run, close
examples:
open C:\NE\test.nod file
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html?file=C:\\NE\\test.nod', 'resizeable,defaultWidth:1,defaultHeight:1', moi.ui.mainWindow )
open C:\NE\test.nod file and run it
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html?file=C:\\NE\\test.nod&run=1', 'resizeable,defaultWidth:1,defaultHeight:1', moi.ui.mainWindow )
open C:\NE\test.nod file, run it, close window
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html?file=C:\\NE\\test.nod&close=1', 'resizeable,defaultWidth:1,defaultHeight:1', moi.ui.mainWindow )
lang.js
added:
- minor inprovements
main.js
fixed:
- open macro dialog error
added:
- more node colors
- macro inputs/outputs reorder (hold alt and drag input/output dot)
- select -> same type/color menu
- minor improvements
added ext.nodelist.js
nodes/interface.js
added:
- remapper widget
7777.1710 In reply to 7777.1709
Max,
Thank you for the info.
I have a few suggestion that may be worthy of your consideration.
1) I think it would be operationally consistent with the menu logic for "Output" to be included in the first tier, just as "Input" "Output" & "Close" are in menu within a macro. See image below
This is a small thing; but I do think "output" is distinct from other nodes & deserving of first tier status.
2) I don't believe "Point" node is fittingly part of the "Basic" grouping, as it is a geometry node. It belongs IMHO within "Points" menu. To removed the inevitable confusion, I think, "points" would more appropriately be renamed as "pointArray".
3) Wayne made a minor but significant change to your curve nodes: "Rectangle", "Circle", "Star" & "Polygon" with the addition of a surface output option. I have attached below.
Although generally connecting to "construct2/Planar" node satisfied the requirement of generating surface shapes, it fails in some instances (with complex patterns), & in these cases, incorporating surfacing within the node has been a real improvement.
Please have a think about these suggestions and let me know.
Thanks again for your support,
7777.1711 In reply to 7777.1710
Hi James
1) OK. Done.
2) You're right. I've moved Point node to Points.js and renamed Points to PointArray. Also I updated compatibility.js file. Old projects should work fine.
3) it fails in some instances (with complex patterns)
Could you send me an example?
EDITED: 7 Mar 2022 by SMIRNOV
7777.1712 In reply to 7777.1710
I'm new to Node Editor.
Just curious about the arrangement of items in the menus.
For instance why is there a "Points" item and a "Points2" item but they are not together, one right after the other?
For that matter why are there two menu items related to points as opposed to just one?
Not a big deal at all but was just wondering how things came to be the way they are.
Frederick
P.S. I do try to keep my OC nature under control.
7777.1713 In reply to 7777.1712
If you go there you will see that Points is "Native Nodes" an Points 2 is "Extensions Nodes" ! ;)
7777.1714 In reply to 7777.1713
That seems to be a matter of how the underlying code is structured.
From a user interface point of view that is really of no interest.
Frederick
7777.1715 In reply to 7777.1711
Max,
Thank you for implementing those changes.
"3)....Could you send me an example?"
Regarding the inclusion of a "Srf" output on shape nodes ("Circle", "Rectangle", "Polygon" & "Star"),
the following shows the situation when this need first arose.
From Top down:
1) connecting directly to "circle" node gives the expected result in arrangement of circles & their colouring,
however the desired effect, is lost because the circles are outline only.
2) now connecting the "Construct2/Planar" fails to achieve the desired result because the order is lost.
3) attempting to go via "CloneToPts" does not work at all.
4) using Wayne's "Curves2/Circle2" node "Srf" output work perfectly!
I have since found that I use Wayne's shape nodes all the time. For example "Curve2/Rectangle2" has for me, made Karsten's "SubD/selCenterPane" obsolete. But perhaps the main application is with complex variegated screen images with hundreds of shape elements, where connecting to "Construct2/Planar" node after pattern articulation, will hang the computer for a long time while it calculates all the trimmed surfaces.
It seems to me a small change that would produce no backward compatibility issues & yet is very useful.
Is your resistance to this change because it somewhat invalidates these nodes from being grouped within "curves" menu? I don't see it as a serious contravention of UI logic, but if so perhaps there could be a "Shapes" menu.
I am happy to continue using wayne's versions, but I do think there needs to be a rationalisation of node hierarchies.
Thanks again for you ongoing stewardship of NE
EDITED: 18 Jul 2020 by JFH
7777.1716 In reply to 7777.1712
Hello, Frederick,
maybe I should explain a few things about this. The node editor has not been developed by a large team with a master plan and interface designers, but by a single person - Max Smirnov based on code from litegraph.js. So it is understandable that he can't program all functions by himself. Especially since you don't know and can't capture all aspects and wishes of the individual users. So I and some others ( James, Al, Marco, R3D3, Wayne, Pilou ... )started to support and extend the work of Max through nodes, tests, documentation and discussions. But I am not a programmer and my code is sometimes bad. Furthermore there was a discussion my code not
to mix with Max's. My goal was not to extend the functionality, but to experiment what is possible. From the dialogue with James and Al ( I hope he is doing well - nothing read for a long time of him) I also started to implement functions that were not of direct interest to me. I think the separation from Max development is right, because there were many changes in NE and the extensions in the initial phase
which gave and which caused a lot of confusion in the forum. Compatibility, versions, bugs ...
But it is very easy to redesign the menus and build your own NE as you wish.
Have a nice day
Karsten
7777.1717 In reply to 7777.1716
Hi Karsten,
That information was very helpful in understanding the Node Editor as it exists today.
You said "But it is very easy to redesign the menus and build your own NE as you wish".
Could you point me to something (code, document, articles) that would help me get started? I was a programmer for many years quite some time ago but I think I can still do it.
Thanks much.
Frederick
7777.1718
Bug detected.
Back compatibility function didn't work with macros. Fixed.
James, could you send me the nod-file? I'll try to find a solution.
7777.1719 In reply to 7777.1718
Max,
"could you send me the nod-file? I'll try to find a solution."
I have attached .nod file, but please don't spend any of your precious time
trying to find another solution, I'm happy with existing solution.
While pondering the NE interface design, I had a thought.
I was wondering if the wires between nodes could be different to graphically communicate the nature the data flowing through them. I should preface this by saying that this is not a request, more a question of possibilities.
The image below shows 3 examples of point data: (1) a point, (2) multiple points & (3) ordered point sequence with a ranges of wire types to reflect the particular data type.
Similarly, the wires may vary for single numbers and numArrays, as well as to denote single objects and collections of objects.
Again, I'm not asking for this to be done, but rather wanting to know your thoughts on the future development of NE; whether this was even a possibility.
Perhaps even more useful for debugging node circuits might be a wire type that indicates that indeed no data is flowing through a wire.
UPDATED:
Another suggestion of UI enhancement might be to include set of dots at top right corner of node to indicate that it is a multi-mode node. It is a well established interface convention that requires no explanation. Also there may be some value in grouping the multi-mode nodes under a single heading: "General".
Of course it would appropriate for some multi-mode nodes to reside within other groupings. Several of the "Points" nodes could be folded into the "Transform" nodes, e.g."Move" "Rotate" & "Scale" node could all have modes for "Objects" as well as "Points".
The ability for a single node to operate on a number of different data type is one area where NE is superior to GH (Grasshopper)
Anyway, I am so appreciative that you are working again on NE,
& will be onboard with any direction you choose to take it.
EDITED: 20 Jul 2020 by JFH
7777.1720
Hi, everybody.
New nodes: Box, Box Center, Box3pts.
Size: 354.6 KB, Downloaded: 172 times, Dimensions: 1920x1080px
Size: 309.5 KB, Downloaded: 139 times, Dimensions: 1920x1080px
7777.1721
Hello Karsten,
Hope you are well.
I have been trying over and over to create a recursive pattern with your loop nodes (loopStart & loopEnd), but I can't get my head around how to set it up.
I have search the forum for an example of looping, to no avail.
I would greatly appreciate, when you have a free moment, if you could post a super simple example of the nodes in use, so that I may use as reference, for building something more complex.
Thank you,
All the best,
Show messages:  1  …  1642-1661  1662-1681  1682-1701  1702-1721  1722-1741  1742-1761  1762-1781  …  1842-1859
