 1-8  …  1649-1668  1669-1688  1689-1708  1709-1728  1729-1748  …  1849-1859
7777.1689
Recent NE experiment: Voronoi Pattern with points dynamically attracted to curve.
Stay safe,
EDITED: 9 Aug 2020 by JFH
7777.1690 In reply to 7777.1689
Really cool. Superb!
Little return after a big break - confinemented so some many rusted!
You can of course play with it and improve it!
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/flow_elephant.nod
7777.1692 In reply to 7777.1689
Hi James,
Your art works are super cool :) Like a lot
Wanted to create some parametric designs and learn Grasshopper3D, but thanks God at right time found YOURS art here ^_^
I'm Moi3D user just love this software. So would be super cool to make/create such random parametric forms in Moi.
Could you ... please...um.... would be super uber cool if you could release some gumroad video on how to use node editor and make such cool forms. Or some step by step screen shots. Would buy these. Mine node editor screen does not work. Im V4 Beta Oct-10-2019 Win10
I know only how to use Voronoi. And its cool :)
Thank you :)
7777.1693 In reply to 7777.1692
Use the beta of the Beta V4 of 22 january : Node editor works inside without any problem! ;)
And you can take a look at my Elephant repository where there are some examples of uses differents nodes ;)
French / English
7777.1694 In reply to 7777.1693
Thank you Frenchy Pilou :)
- Konni
Artstation Instagram V4 Beta Win 10
7777.1695 In reply to 7777.1692
Konni,
Thank you for your kind remarks.
I'm not aware of "gumroad", but sometime down the track I may look at making an instructional video, but for now it would be better if you could let me know what result you are trying to achieve and I'll see if I can do a step by step annotated screenshot series to walk you through the process.
If you have a look at my instagram: https://www.instagram.com/nodeology/
most of the post show the node wiring for generating the geometry of posted image (3D form or 2D pattern). I know that these would be bewildering to a novice but once you get your head around the process they will start to make sense.
Also as Pilou says, look at his "Elephant Repository: https://moiscript.weebly.com/biblio-elephant.html to see how individual nodes operate.
Anyway, start with something simple & I'll see if I can talk you through it...
& then if you are still keen, we can tackle something more complex.
Post an image of something akin to what you want to do.
EDITED: 17 May 2020 by JFH
7777.1696
Hi All,
Attached is a node circuit containing a macro for generating geodesic spheres
of variable resolution (0 = icosohedron up to 4 subdivisions*) with all vertices at equal distance from origin. Essentially, it subdivides an icosohedron, then spherizes the result.
* If you want to reduce or increase limit on allowable subdivisions, you can go into macro and change MAX.subDivs node shown in RED. Beware that a number higher than 4 however will likely hang your computer.
EDITED: 1 Mar 2024 by JFH
It's false simplicity! :)
You must click on the middle node for see the entiere Macro! ;)
(no place for put it here! :D
7777.1698 In reply to 7777.1697
Well yes, I only posted the .nod file because I thought the macro within may be of use to others.
It is easy enough to cut & paste the nodes out of the macro and on to the canvas if you so desire.
I did not think that the result was worth posting, only the macro, but here is an image posted to instagram that uses similar node wiring to that found in the macro, and the subsequent images shows the node circuit for generating geometry.
7777.1699 In reply to 7777.1698
Seems there is a little glitch somewhere in the geodsic...
As soon as the up Knob is decreased/ increased there is new a sphere who is drawn inside
and that calculate for a moment...etc ...and that blocks all things! ;)
And i believe it's more prudent to put Curseurs because Knobs are very sensible to the direction of rotation
with the mouse so increase can be not wished and too late for take back in the case above!
EDITED: 19 May 2020 by PILOU
7777.1700 In reply to 7777.1699
It is not really a glitch, it is just an artefact of the multiple steps in processing.
The "new sphere who is drawn inside" is not spherical, but a Catmull–Clark smoothed subdivided icosohedron which persists on the canvas only while the vertices are spherized.
"that calculate for a moment...etc ...and that blocks all things"
To limit the computation time I have restricted the number of subdivisions to 4 despite the numerical "subDivs" input.
Being locked out while calculating occurs generally for tasks that draw heavily on computational resources, and although it can be frustrating it is something that we must live with.
"i believe it's more prudent to put Curseurs because Knobs are very sensible to the direction of rotation"
I've only used a knob, to illustrate that macro will accept a range of numerical inputs (0-4). My purpose of posting the file was solely to distribute the macro within.
EDITED: 19 May 2020 by JFH
7777.1701 In reply to 7777.1700
Many thanks for the infos and bravo for the creativity!
7777.1702
A simple fractal for the Node Editor.
Wayne
EDITED: 17 Jan 2021 by WAYNEHILL5202
the ".js" must be \Moi\nodeeditor\nodes\extensions\
Cool !
+ Fat lines by Max Smirnov & Extrude!
http://moi3d.com/forum/index.php?webtag=MOI&msg=7594.31
7777.1704
Here's a node circuit for the generation of a interlinked woven screen.
Be warned that it may take a minute or so for geometry to generate.
Requires most current extension nodes, found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10
7777.1705 In reply to 7777.1704
It's unbelieveble what interesting geometry you can create via nodes.
Excellent!
Mik
7777.1706
Hi :)
New NE core build:
http://moi.maxsm.net/files/nodeeditor/nodeeditor.v.1.1.2020.07.14.zip
Minor interface updates, bugfixes etc.
7777.1707 In reply to 7777.1706
Welcome back Max,
So good to hear from you.
I've downloaded... can't wait to see the changes
Thank you for your continued support of NE
EDITED: 14 Jul 2020 by JFH
Evergreen! :)
Show messages:  1-8  …  1629-1648  1649-1668  1669-1688  1689-1708  1709-1728  1729-1748  1749-1768  …  1849-1859
