 1-4  …  1585-1604  1605-1624  1625-1644  1645-1664  1665-1684  …  1845-1859
7777.1625 In reply to 7777.1624
Thank you Karsten.
Two additional related questions:
1. Where would a function go in a node? Inside the .prototype.onExecute = function (), or
just before it?
I have not found any examples, as far as I know.
2. Is it necessary to "link" say basicFunctions2.js somewhere? Or is this already set up?
(I have not searched for an example useage of basicFunctions.js yet.)
7777.1626 In reply to 7777.1625
Hello Brian,
you can find examples where to place "normal" functions in vector.js. If you want to create a lib of functions you can place it in the libs folder under extensions. Max has made an autoload for files placed in that folder. So no link.
Have a nice day
Karsten
7777.1627 In reply to 7777.1626
That information is very helpful.
Thank you Karsten.
Maybe this can interest you! :)
https://nodevember.io
7777.1629
Hi All,
Surface Tweening Animations: interpolating z values between 2 point Arrays with randomised z values.
Have a great weekend
EDITED: 9 Aug 2020 by JFH
7777.1630 In reply to 7777.1629
Cool!
Does exist a trick for see if the are Macros or not ?
And i see (1-a)*b how do you enter (1-a) ?
7777.1631 In reply to 7777.1630
>> Does exist a trick for see if the are Macros or not ? <<
Yes, the macros are darker, but there are no macros used in example above.
>> And i see (1-a)*b how do you enter (1-a) ? <<
As well as preset functions, you can type custom functions into Math node's F field.
See image below
>> Cool <<
EDITED: 9 Nov 2019 by JFH
7777.1632 In reply to 7777.1631
I must retry because this F case return me nothing! :)
7777.1633 In reply to 7777.1632
After typing in an equation in the F field, press enter, otherwise the entry goes away.
(Slightly annoying). When typing a more complex equation, save a partly correct entry, then re-edit,
otherwise partial work could be lost.
7777.1634 In reply to 7777.1633
Good to know!
7777.1635
Recursive subdivisions in NE
EDITED: 15 Nov 2019 by JFH
Message 7777.1636 deleted 29 Dec 2019 by JFH
7777.1637 In reply to 7777.1636
WOW! Congrats!
Message 7777.1638 deleted 29 Dec 2019 by JFH
7777.1639
Now with Wayne's latest update to ImgSampler node ( https://moi3d.com/forum/index.php?webtag=MOI&msg=9581.57 ) it's possible to have 3 images of RGB channels (separated in photoshop) output to interleaving dot screens as shown.
EDITED: 29 Dec 2019 by JFH
7777.1640 In reply to 7777.1639
Klaus Nomi ? (but i have not my glasses...
Happy new year!
Message 7777.1641 deleted 20 Jan 2020 by JFH
7777.1642
Alex
In answer to your query :
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.106
please find .nod file for ImgSample to Hex Pattern.
A series of images showing node circuitry can be found here:
https://www.instagram.com/p/B7HZl5NJ_hp/
Let me know if this is not what you meant
EDITED: 10 Jan 2020 by JFH
Size: 89.3 KB, Downloaded: 177 times, Dimensions: 800x852px
7777.1643 In reply to 7777.1642
Intricated! :)
7777.1644
HI James,
WOW! Thats exactly what I meant looks great thanks very much for looking into it for me a great addition to the expanding node list. Will have a play with it and post any outcomes.
Very inspirational work keep it going.
Best regards
Alex.
Show messages:  1-4  …  1565-1584  1585-1604  1605-1624  1625-1644  1645-1664  1665-1684  1685-1704  …  1845-1859
