 1  …  1562-1581  1582-1601  1602-1621  1622-1641  1642-1661  …  1842-1859
7777.1602 In reply to 7777.1601
<< Is there a description for each node?
That's i must make at the beginning of september!
Native Elephant - Extension
French / English ( + inside the node editor itself
that is 75% made for the French part and of course 100% yet made for the English part! ;)
EDITED: 19 Aug 2019 by PILOU
7777.1603
cool :-)
If node.js code were modified so that a regular node could be opened up like a macro, to show its output label as an output slot, than the user could change the output slot label of the node to " " (space) ...
Or else add the ability to change the output label to the information box...
7777.1605 In reply to 7777.1604
Brian,
I don't see much advantage in making the output label editable, after-all the colours indicate the type of data outputted and the nodes themselves have editable titles which could serve any explanatory role. In instances where the outputs require specific labelling, these should most definitely be retained (& IMHO should remain un-editable)
However, I think the idea would have great merit for inputs.
Often I find myself translating equations so that they have alphabetised variables. It can be a quite counterintuitive process of letter substitution. It would be ideal if the "maths" and "mathsPts" nodes allowed editing of the inputs, like shown:
Also adding new inputs ATM is a 2 step process: first RMB clicking "Inputs" then selecting submenu button denoting next letter. This second step could be removed.
Getting back to "Out" labels. Perhaps we could do an experiment. I could post an alternative nodeEditor folder with all unnecessary labels removed, and those that want to trial it could then report back whether or not they thought the removal of labels had an impact on their user experience.
EDITED: 29 Aug 2019 by JFH
7777.1606 In reply to 7777.1604
Brian,
Although as I said before, that the colour of the output dot indicates the data type, there are a few nodes with more than 1 output of a particular datatype. These cases may require labelling to distinguish between them, but often, as in the case of your "Centroid" node, an extra object output is the same as the object input. This output is useful because it means that a "Clone" node can be avoided. However if nodes could have multiple Obj outputs (similar to Num & Pt datatypes), these extra outputs would then be superfluous. The node may then be like this:
I'm not suggesting you alter your "Centroid" node, I'm only reinforcing the point that node title itself often has all the descriptive content needed to explain the nature of outputs.
PS Switch node is a beautifully elegant node that demonstrates that the absence of I/O labelling is not necessarily an impediment to comprehension and usage.....quite the opposite!
Size: 48.4 KB, Downloaded: 112 times, Dimensions: 648x558px
7777.1607
Hi All,
It has been a while since I've posted an experiment in NE here,
though I have been regularly posting them to my instagram gallery of node play.
I thought I might post this, (see below) because it was a real labour of love.
It took hours & hours to finally get it to work.
EDITED: 29 Sep 2019 by JFH
7777.1608 In reply to 7777.1607
Cool result!
Was only minutes in TopMod! ;)
7777.1609 In reply to 7777.1608
Thanks Pilou,
>> only minutes in TopMod. <<
Yes I watched similar youtube video, to work out the procedure to articulate in NE:
https://www.youtube.com/watch?v=8SUjZITJIOw
& although it took a long time to create, once done it is possible to adjust thickness, tapers and
even move the 5 way connectors to the interior, so that 3 way junctions are on the exterior.
Unlimited variation: as is the nature of parametric design.
Thanks again,
EDITED: 24 Sep 2019 by JFH
7777.1610 In reply to 7777.1609
Yes i just seen something about real spiraling Shells : it uses only Scale, Rotation, Twist! :)
7777.1611 In reply to 7777.1610
Math + Nature: what a fantastic source of inspiration !
Big thanks for this info !
regards
O.
Does it possible to have some nodes by default on the screen at start of Elephant like the Output ?
7777.1613 In reply to 7777.1612
For function loadDefaultNodes(), see lines 21 through 26 of the file init.js, located in core subdirectory of nodeeditor.
var node_output = LiteGraph.createNode("Basic/Output");
node_output.pos = [800,100];
graph.add(node_output);
7777.1614 In reply to 7777.1613
Many thanks!
Cool : works like a charm! Will added in few times http://moiscript.weebly.com/node.html#addanodeselected
var node_selected = LiteGraph.createNode("Objects/Selected");
node_selected.pos = [400,100];
graph.add(node_selected);
EDITED: 6 Oct 2019 by PILOU
Ok i haved finished the Section Not Native Construct2 all English ;) Next will be Curve2
http://moiscript.weebly.com/construct2.html
...except these 2 little things where i am sucked! :(
if you have some ideas ?
7777.1616
Hi All,
I am getting an error message when using curveLength node. (see below)
TypeError: undefined is not an object (evaluating 'this.outputs[1].label = len[0].toFixed(2)')
moi://appdata/nodeeditor/nodes/extensions/infonodes.js   line 74
70:               out.addObject(inObj.item(i).clone());
71:               }
72:             }
73:             this.setOutputData(0, out);
74: >>          if(len.length>0) this.outputs[1].label = len[0].toFixed(2);
75:             this.setOutputData(1, len);
76:         }
77:         crv_length.prototype.onPropertyChange = function ()
78:         {
I have attached a simple .nod file. Can someone please run it to see if problem is universal or specific to my setup. I have already tried reloading both my v4beta & nodeEditor folder without fixing this issue.
I would greatly appreciate any assistance
Have a great weekend
You ask a curve's length of a Point ?
7777.1618 In reply to 7777.1616
Hi James,
How did you get a gold output to connect to a green input?
Once detached, I cannot get this incorrect connection to reconnect.
The green output hooked to the green input shows the length as 57.38.
Gold output to an Output node draws the curve.
Its MoI length with unwrap curve script is 57.3800598.
EDITED: 19 Oct 2019 by BEMFARMER
7777.1619 In reply to 7777.1618
Thanks Brian & Pilou,
Is is apparent now that my fiddling with the code is the issue.
I will overwrite with original code.
Thanks again
7777.1620 In reply to 7777.1619
Hi James, also the new v4 beta has the arrowheads that rotate towards the viewer that you were asking about a while ago for showing directions.
They can be created like this:
	var startpt = moi.vectorMath.createPoint(5,5,5);
	var endpt = moi.vectorMath.createPoint(10,10,10);
	var f = moi.command.createFactory( 'arrow3d' );
	f.setInput( 0, startpt );
	f.setInput( 1, endpt );
	var arrow = f.calculate().item(0);
	moi.geometryDatabase.addObject( arrow );
	f.cancel();
That creates a Leader with its plane perpendicular to the arrow direction and sets the .rotateArrowheadPlaneTowardsViewer property on it.
7777.1621 In reply to 7777.1619
@James,
Create a test directory for the Node Editor and call it with a shortcut. This way you keep the original directory and have a test area for playing with nodes.
moi.ui.createDialog( 'moi://appdata/nodeeditortest/index.html?scheme=Light', 'resizeable,defaultWidth:1000,defaultHeight:1000', moi.ui.mainWindow );
The original and test area node editor use the same MOI instance so the nodes are viewable in both the original and test area editors.
You can cut and paste nodes between the node editors and run them separately. How cool is that?
Wayne
EDITED: 2 Oct 2020 by WAYNEHILL5202
Show messages:  1  …  1542-1561  1562-1581  1582-1601  1602-1621  1622-1641  1642-1661  1662-1681  …  1842-1859
