 1-5  …  1486-1505  1506-1525  1526-1545  1546-1565  1566-1585  …  1846-1859
Message 7777.1526 deleted 6 Jun 2019 by JFH
7777.1527 In reply to 7777.1526
Eye pleasant and amazing as usual!!!
You keep very high your bar :)
7777.1528 In reply to 7777.1527
Cheers Marco,
Thanks for your appreciation.
Here is a screen proposal done in NE with randomised curve attractors.
7777.1529 In reply to 7777.1527
An another
7777.1530
Another NE experiment with curve attractor rotating and scaling triangular cutouts
EDITED: 3 Jun 2019 by JFH
7777.1531
Another woven pattern done with NodeEditor
7777.1532 In reply to 7777.1531
Very complex and beautiful!
7777.1533 In reply to 7777.1532
>> Very complex and beautiful! <<
Thanks Marco! I appreciate your appreciation.
The result may look complex, but it you look at the node wiring images on instagram
you will see that it was relatively simple tp define....
...while allowing for infinite manipulation of the resultant weave.
Such is the advantage of this methodology.
Anyway, thanks again
7777.1534 In reply to 7777.1533
It's awesome !
but it is possible to map this texture on my own model and not just a sphere ?
Message 7777.1535 deleted 5 Jun 2019 by JFH
James or the Braidings' Master!
7777.1537 In reply to 7777.1534
Finema,
>> it is possible to map this texture on my own model and not just a sphere ? <<
If your model is a 4 sided patch it will map. See attached. seamless texture on revolved surface.
If your model was a poly-surface it may be possible, however ensure seam map seamlessly may
be difficult.
UPDATED: more complex texture mapped form posted here:
Hope this helps.
NE folder can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
EDITED: 6 Jun 2019 by JFH
7777.1538 In reply to 7777.1537
Yes, it's very interesting. Too bad there are no scripts on your instagram.
7777.1539 In reply to 7777.1538
Finema,
>> Too bad there are no scripts on your instagram <<
I've uploaded .nod file to previous post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1537
7777.1540 In reply to 7777.1537
James this is really A-M-A-Z-I-N-G!!!
Simply...beautiful :)
It could be very very interesting to see some of your creations turned into reality with a 3D-printer or other kind of manufacturing process.
Listen to me, think about it James.
You could build stylish furnishing objects and decorative items for house!
Your creations deserve to be turned into reality!
7777.1541 In reply to 7777.1540
Thank you so much Marco,
>> very interesting to see some of your creations turned into reality with a 3D-printer <<
I have a cheap 3d printer which I have used to print some of these designs, with varying degree of success. I do in the future plan though to send something to Shapeways or similar for quality print.
>> You could build stylish furnishing objects and decorative items for house! <<
I thought I once posted a woven pendant lamp example, but can't find the thread posting. Anyway I have attached another here
There are other examples of my work at www.jameshargraves.com
As it happens, I do plan to do something along these lines with this triaxial weave & the randomised bulbous forms.
Thanks again for your support
EDITED: 14 Jun 2019 by JFH
7777.1542 In reply to 7777.1541
@You: "There are other examples of my work at www.jameshargraves.com"
Wonderful things. Congrats!
7777.1543
Here's an amusing little experiment inspired by the work of Christian Bird (fellow noder)
as shown here: https://www.instagram.com/christianbirdnyc/
Latest NE folder can be found here:
EDITED: 15 Jun 2019 by JFH
7777.1544 In reply to 7777.1543
It is amazing what can be done with MoI and Nodeeditor!
Seed count of a dandelion is on the to do list.
- B
7777.1545 In reply to 7777.1543
In just one word: Poetry.
Hats off!
Show messages:  1-5  …  1466-1485  1486-1505  1506-1525  1526-1545  1546-1565  1566-1585  1586-1605  …  1846-1859
