 1-11  …  112-131  132-151  152-171  172-191  192-211  …  1852-1859
7777.152
Hi Karsten and Friends
a little test with the new Node
SplitPts, which I have used in an intuitive manner,
Do you wonder if you can get me some small example
how to use it
The outputs that you've highlighted in the attached image
What return?
thanks in advance
al
Ps-On this test, Blend is stable.......
try to move the Knob points you'll get a nice performance
of Blend Surf
Size: 332.7 KB, Downloaded: 137 times, Dimensions: 1920x1080px
Size: 252.5 KB, Downloaded: 136 times, Dimensions: 1920x1080px
7777.153 In reply to 7777.152
Hallo Al,
the pointarrays that Max has designed are not so simple as it looks - welcome to the internals. Max choosed so called Euler angles (roll, nick, gear ) and a scale component to describe and transport also frames and scale factors. The node isn't made for the typical work - its more a possibility to make some vector math operations (mathematical surgery). So it is possible to read knots/nodes from fea files (CSV-Files node) and also read a e.g. displacement field of knots. With the split node you can add the components of the displacement to the components of the base knots and display the deformed knots - or maybe something else. I've made it for some test with fea stuff (placing spheres ...).
Have a nice evening
Karsten
Hi everyone.
I have written a new simple and useful node : "PointExt" contained into the file "basicExt.js".
It's almost identical to "Basic/Point" node and the the only difference is that my "PointExt"
exposes also the others PointArray's properties, that is AngleX, AngleY, AngleZ and pSize.
Using the great "Points2/spliPts" node (many thanks to its author) and my "PointExt" node I was able to "mimic" the behavior
of the node of which I spoke in some previous posts, that is, the node "ArrayMathTrasformations" that should do these things :
- Input :
     - PointArray
     - Math formula to apply to "X" values of each array element
     - Math formula to apply to "Y" values of each array element
     - Math formula to apply to "Z" values of each array element
     - Math formula to apply to "AngleX" values of each array element
     - Math formula to apply to "AngleY" values of each array element
     - Math formula to apply to "AngleZ" values of each array element
     - Math formula to apply to "pSize" values of each array element
- Output :
    - The resulting PontArray
With the opportunity to include into every single math formula, a reference to the fields of the PointArray structure.
Here's the new nodeeditor_0_85_mod6 archive : http://take.ms/RfzWH that contains also my new "PointExt" node.
Here's a brief video : http://take.ms/zJDVN
And here's the .nod file : http://take.ms/WHASK
Performances are rather weak but I think that with all job done in one single node (ArrayMathTrasformations) things would improve.
Best,
7777.155 In reply to 7777.154
Hi Marco
Thank you for these new nodes. To familiarise myself with them, I re-did Max's Twist exercise
using spliPts/PointExt. A Dynamic Duo opening up limitless possibility.
Thanks again
-James
UPDATED to run on most recent NE (Jun18)
EDITED: 14 May 2019 by JFH
7777.156 In reply to 7777.155
Hi James.
You're welcome!
You did a very interesting nod file.
I hope that one day, someone more skilled than me in math, want to write the "ArrayMathTrasformations" node that
should pull all these stuff together (Math node + PointExt) into a single and faster node ;)
Have a nice day,
7777.157 In reply to 7777.156
Hi Marco
Cool Node... PointExt ,
well done , clarifies the question which I put to Karsten
best
al
7777.158
By continuing the exercise CP-Catenary , I have another question from ports of;
If you wanted to split the 30 curves obtained
with 10 points each
and then reuse these 30 groups of 10 pt each
to draw as many curves (each of 30 pt)....
see attached picture ( Rhino -Gh)
Is it possible to do it ?
which nodes can I use?
many thanks
al
Size: 417 KB, Downloaded: 107 times, Dimensions: 1920x1080px
Size: 505 KB, Downloaded: 118 times, Dimensions: 1920x1080px
7777.159 In reply to 7777.155
Hi James (again)
Here's a little upgrade of your Twist2 nod file.
Here's the Twist3.nod : http://take.ms/PcK8H
And here's some screenshot : http://take.ms/hUTiL and http://take.ms/FR9oz
I think that would be a good thing if we put at the end of all our posts with nod files this notation :
"These nod files requires <node editor version name> downloadable at <url>"
So...
These nod files requires "nodeeditor_0_85_mod6" that contains also my new "PointExt" node downloadable at http://take.ms/RfzWH
Best,
7777.160 In reply to 7777.159
Hi Marco,
Cool update .nod file.
>>i think that there's a Moi BEFORE Max's contribution and a Moi AFTER Max's contribution.<<
I fully endorse your concept of the "Maxian Calendar" as we enter year 2 AE (Anno Elephantus)
-James
EDITED: 17 Nov 2016 by JFH
7777.161 In reply to 7777.158
Hello Al,
I'm working on that at the moment. We need a multiple pathArray for that. It was clear for me, that you will ask and I agree with you it's a elementary function. But there a 4 problems at the moment: time, the performance of the pathArray, knowledge of JS and knowledge of the elephants internals. Performance:pathArray could be replaced by a node that only gives unoriented points - the rest is still difficult.
Have a nice day
Karsten
7777.162 In reply to 7777.161
Hello Al,
have a look in mPathArray and switch under Infos to "cross"- connect your curves and connect the output to Curves\Curve interpcurve ...
The node is very untested!!!
Have a nice day
Karsten
7777.163 In reply to 7777.162
Hello Karsten
Excellent, it works fine
you are a " Maestro"
many thanks
have a nice afternoon
al
Size: 367.8 KB, Downloaded: 139 times, Dimensions: 1920x1080px
Hi everyone,
As agreed in previous posts, I upload here the file "nodes_V0.85_mod6.xls",
containing an updated version of the infos of all my nodes with the new "Basic/PointExt" (column Authors : Marco (mkdm)).
Here's the file : http://take.ms/2jz7Q
This xls file relates to "nodeeditor_0_85_mod6" downloadable at http://take.ms/RfzWH
P.S. Karsten, when you will consider to be stable the new "mPathArray" node contained into points2.js file
(downloadable at post : http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.162),
please update a new "nodes_V0.85_mod7" version of Project Elephant and create the new "nodes_V0.85_mod7.xls" file.
Thank you.
Best,
7777.165
Hello Friends
It ends another week .....
another test of Boolean Intersect
works fine
Have a happy weekend to all
best
al
Size: 497.5 KB, Downloaded: 166 times, Dimensions: 1920x1080px
Message 7777.166 deleted 18 Nov 2016 by MKDM
Message 7777.167 deleted 14 May 2019 by JFH
7777.168 In reply to 7777.167
Hello James,
the flowObj node have to be changed to multiprocess. At the moment - only one target. The second problem is, that you try to use a rectangle as base surface. Try using SubDiv/selCenterPlane. I will have a look, to change the node to multiprocess in the next days.
Have a nice day
Karsten
7777.169 In reply to 7777.168
Hello James,
very untested!!!
Have a nice day
Karsten
p.s.: Very interesting experiments here - thanks to all!
7777.170 In reply to 7777.169
Hi Karsten,
One day I would like to buy you a beer!
Thanks again
-James
Size: 149 KB, Downloaded: 125 times, Dimensions: 800x646px
Message 7777.171 deleted 14 May 2019 by JFH
Show messages:  1-11  …  92-111  112-131  132-151  152-171  172-191  192-211  212-231  …  1852-1859
