 1-17  …  1478-1497  1498-1517  1518-1537  1538-1557  1558-1577  …  1858-1859
Message 7777.1518 deleted 14 Jun 2019 by JFH
7777.1519
Hi Friends
Reconnecting to James's Fractal file,
I tried to create a Fractal Macro
that could be applied to a Basic Polygon -
to get the iterations, you need to reapply
the Macro at its Out Curve n times ...
Unfortunately I was unable to apply the iterations
to a parameter ...
Perhaps, Karsten, whose recent Tools (Loop) I saw
I have to say, they are still quite mysterious to me
will be able to improve this iterative process
file to this Link:
http://www.mediafire.com/file/440cay7pld8o5xx/M-FRACTAL.zip/file
have a nice day to all
al
Message 7777.1520 deleted 21 Jul 2020 by JFH
Message 7777.1521 deleted 18 Dec 2023 by JFH
7777.1522 In reply to 7777.1521
"BLOBBY FICTION!"
Cool! There is not an artefact on the top ? Like a hole ...
Message 7777.1524 deleted 22 May 2019 by JFH
Message 7777.1525 deleted 18 Dec 2023 by JFH
Message 7777.1526 deleted 6 Jun 2019 by JFH
7777.1527 In reply to 7777.1526
Eye pleasant and amazing as usual!!!
You keep very high your bar :)
7777.1528 In reply to 7777.1527
Cheers Marco,
Thanks for your appreciation.
Here is a screen proposal done in NE with randomised curve attractors.
7777.1529 In reply to 7777.1527
An another
7777.1530
Another NE experiment with curve attractor rotating and scaling triangular cutouts
EDITED: 3 Jun 2019 by JFH
7777.1531
Another woven pattern done with NodeEditor
7777.1532 In reply to 7777.1531
Very complex and beautiful!
7777.1533 In reply to 7777.1532
>> Very complex and beautiful! <<
Thanks Marco! I appreciate your appreciation.
The result may look complex, but it you look at the node wiring images on instagram
you will see that it was relatively simple tp define....
...while allowing for infinite manipulation of the resultant weave.
Such is the advantage of this methodology.
Anyway, thanks again
7777.1534 In reply to 7777.1533
It's awesome !
but it is possible to map this texture on my own model and not just a sphere ?
Message 7777.1535 deleted 5 Jun 2019 by JFH
James or the Braidings' Master!
7777.1537 In reply to 7777.1534
Finema,
>> it is possible to map this texture on my own model and not just a sphere ? <<
If your model is a 4 sided patch it will map. See attached. seamless texture on revolved surface.
If your model was a poly-surface it may be possible, however ensure seam map seamlessly may
be difficult.
UPDATED: more complex texture mapped form posted here:
Hope this helps.
NE folder can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
EDITED: 6 Jun 2019 by JFH
Show messages:  1-17  …  1458-1477  1478-1497  1498-1517  1518-1537  1538-1557  1558-1577  1578-1597  …  1858-1859
