 1-18  …  1439-1458  1459-1478  1479-1498  1499-1518  1519-1538  …  1859
7777.1479
Hi Friends
a striking effect on surfaces.
the file at this link:
http://www.mediafire.com/file/5elcgg2sgios82d/Louvre_Box.zip/file
Happy weekend to all
al
7777.1480 In reply to 7777.1479
Nice Louver, Speedy.
Your Twist node comes up red ("missing" node).
Replacement with Twist node under Transform menu, in my nodeeditor setup, worked.
7777.1481 In reply to 7777.1480
Many thanks, Brian
7777.1482 In reply to 7777.1479
Hi Al,
Your louvred box was inspirational.
I have taken an alternative approach lofting profiles along axes, rotated (rather than twisted) in response to proximity to curve attractor.
It is shown here in an architectural context where it forms facade treatment to fully glazed curtain wall behind.
Keep up the good work
Additional images posted:
NE folder can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
EDITED: 14 May 2019 by JFH
Size: 62.9 KB, Downloaded: 189 times, Dimensions: 760x713px
7777.1483 In reply to 7777.1482
Hi All,
My latest NE experiment
What is the last evolution of a complete folder nodeeditor ?
Message 7777.1485 deleted 6 May 2019 by JFH
7777.1486 In reply to 7777.1485
thx but about the last node editor folder "nodeeditor" itself ?
it's the max one on its site ?
Ps very cool page!
7777.1487 In reply to 7777.1486
OK Pilou,
My NE folder can be found here:
Hope this works for you
EDITED: 6 May 2019 by JFH
7777.1488
I just started learning more about node editor and made some progress where i can see how could i use it in my own workflow.
There is a problem i have and i can't solve it no matter what i do. I can't use Macro at all. Whenever i RMB click in the work area and i click on "Macro" i just get Script Error message (image attached). I have seen someone a while ago having a similar issue, tried suggestions but no success.
Does the latest version on node editor support moi3d v3 or is it for v4 only?
I have also tried to copy the nodeeditor folder in "C:\Users\username\AppData\Roaming\Moi" and when i run the command in Moi i just get the blank window.
Now i have it in "C:\Program Files (x86)\MoI 3.0\ui" and it seems like everything works perfectly fine except that Macro problem.
Does anyone know what could be the problem?
Thank you very much.
Size: 59.4 KB, Downloaded: 80 times, Dimensions: 507x445px
7777.1489 In reply to 7777.1488
Klaudio,
Welcome aboard! You are, I assume the same Klaudio I chatted to on instagram?
Have you tried replacing the nodeeditor folder in "C:\Users\username\AppData\Roaming\Moi"
with one found here: http://moi3d.com/forum/messages.php?webtag=MOI&msg=9358.1
It should work for both, but V4, although technically still in beta stage, is rock solid; so there is no reason not to be using it. I'm on a mac so perhaps its a windows issue.
>> Please keep it up to date whenever you can......
Thank you for your appreciation of "Current NODE EDITOR folder" thread. I wonder if I might ask though if you could delete your post: http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.2 and keep correspondence in this thread, so that the other thread remains a single post of most current file directory.
I hope this helps you get up & running. I look forward to seeing what you get up to.
7777.1490 In reply to 7777.1489
Hi James,
Yes, it's me. And thanks! ;)
>> Have you tried replacing the nodeeditor folder in "C:\Users\username\AppData\Roaming\Moi"...
Yes, just tried your version in both AppData and ProgramFiles folders but i still have the same problem.
Interesting is that i just get blank node editor window when i put it AppData folder. I am using this line bellow as shortcut in Moi which gives me that blank mode editor window. Is it correct?
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
>> I wonder if I might ask though if you could delete your post....
No problem at all! Deleted there.
7777.1491 In reply to 7777.1490
7777.1492 In reply to 7777.1491
Yes, i have tried and sett it of that and i am able to start Node Editor and use it all without any problems so the shortcut command is no a problem.
The only thing is that when i Right mouse button click in the Node editor i can access and create Nodes but when i click on Macro i just get that error instead.
It seems like it might be some bug or something because i did try some of older version of Node Editor, v0.9 i think, and there was no errors. In Node Editor v1+ i am getting that error problem.
7777.1493 In reply to 7777.1488
Hi klaudio, having it in appdata will only work with v4, that's new in v4 that you can have URLs with moi://appdata in them.
The error you're getting for the Macro problem seems to be something about it trying to use a moi://appdata URL there, so I'd guess that the Macro mechanism is only working right now with v4 and not with v3.
I'd recommend trying it with v4 and see if it then works ok for you, you can get v4 at http://moi3d.com/beta.htm .
7777.1494 In reply to 7777.1488
Hi klaudio, maybe it can be fixed for v3 - try editing nodeeditor\core\main.js and find the lines where the error is happening:
	var dir = (moi.filesystem.getAppDataDir)?moi.filesystem.getAppDataDir:moi.filesystem.getProcessDir;
	var path = dir()+document.URL.split(/moi:\/\/appdata\/(.*\/).*/g)[1].replace(/\//g,"\\")+"macros\\";
Maybe this is assuming that it's using a moi://appdata address for this dialog.
Try editing to something like this:
	//var dir = (moi.filesystem.getAppDataDir)?moi.filesystem.getAppDataDir:moi.filesystem.getProcessDir;
	//var path = dir()+document.URL.split(/moi:\/\/appdata\/(.*\/).*/g)[1].replace(/\//g,"\\")+"macros\\";
	var path = 'C:\\Program Files (x86)\\MoI 3.0\\ui\\nodeeditor\\macros\\';
I have not tested it but that might get it working with v3.
7777.1495 In reply to 7777.1494
This actually worked! The Macro is now working properly and everything is ok!
Thank you very much for this! ;)
7777.1496 In reply to 7777.1494
When clicking for Macro in MoI3 nodeeditor, I had the same error message as klaudio, with slightly different line numbers. (Windows 10)
After modifying main.js in MoI3 nodeeditor program, (C:\Program Files x86...) with Michaels mode code, (two comment outs and an added line,),
the Macro menu seems to be working. (very Limited testing).
After backing up the above mentioned main.js file, the modification was done in NotePad++.
The commented out lines were numbers 4481 and 4482, with new line added at line 4483.
To fine the line numbers, the NotePad++ command Ctrl+H (extremely useful) was used with Replace/Find What : "var dir"
I guess that probably the nodeeditor macro "path incompatibility" with MoI 3 was introduced by Max's upgrade last winter/January+/-.
Since I use MoI4 beta now, and rarely MoI3, I had not noticed the error message.
Thanks Michael
@James
Thanks like that is more easy with all the previous and future multiple changements!
Finally!!!
After years of (almost) unheeded requests, someone did it :)
Thanks a lot James for your new POST about Node Editor :)
(https://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1)
Thanks!
Show messages:  1-18  …  1419-1438  1439-1458  1459-1478  1479-1498  1499-1518  1519-1538  1539-1558  …  1859
