 1-5  …  1426-1445  1446-1465  1466-1485  1486-1505  1506-1525  …  1846-1859
Cool start! :)
7777.1467 In reply to 7777.1464
Wonderful job James!!
Congrats!
Message 7777.1468 deleted 25 Apr 2019 by JFH
7777.1469
Hi everyone, and in particular Brian
Attached the file in which the Centroid tool
does not give the expected result ... maybe it will be
the case to consider well what this malfunction derives ...
Logically, when you have time, and if you want to do it
every tool we put at our disposal is a gift ...
"few words to the wise"
file at this link:
http://www.mediafire.com/file/oq4olj4yz9ame4y/FelixCandela.zip/file
have nice day to all
al
7777.1470 In reply to 7777.1469
Hi Speedy,
For the center 16 triangles, the centroid point is being found.
The remaining 32, 4 sided closed curves are not planar. This centroid node works for planar polygons.
(The Planar command does not work on the 32, 4 sided closed curves either.)
The center of mass of half of a solid sphere is at 3/8 of the distance from the sphere's center to the hemisphere's pole, as shown by Max's cVolume2.
For a hollow hemisphere, the distance is 1/2.
https://en.wikipedia.org/wiki/Centroid
The centroid node does not work for hemispheres either.
Wolfram gives a formula for center of mass for spherical caps.
Also Wolfram gives a formula for the centroid of a quadrilateral as the midpoint of the line between the midpoints of the diagonals.
Or "The centroid of the vertices of a quadrilateral occurs at the point of intersection of the bimedians."
http://mathworld.wolfram.com/GeometricCentroid.html
(Usually I find Wolfram math difficult to understand, and do not plan on doing integrals:-)
So the centroid for quadrilaterals, (4 line segments forming a closed quad), planar or non-planar, could be easily calculated.
The closed quads could be tested for planarity (somehow), and the calculation added to the centroid node. (I think.)
Is there a MoI method to test for planarity?
EDITED: 25 Apr 2019 by BEMFARMER
7777.1471
Hi All,
Here's a texture of planar quad facets. It may not look like much, but it is a significant step towards structure that may be fabricated from cnc or laser-cut flat panels from board or sheet material. A multi panel image of node circuitry can be found at: https://www.instagram.com/nodeology/
NE folder can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
nod file found here (Al made minor revision to my file & posted here):
http://www.mediafire.com/file/56jgl6gvgzg5a0m/Rev-DiaPlanarFaces.zip/file
EDITED: 7 May 2019 by JFH
7777.1472
Hi All,
Latest exploration.
A great weekend to all
EDITED: 14 May 2019 by JFH
7777.1473 In reply to 7777.1472
Great things :)
Congrats!!
7777.1474 In reply to 7777.1472
A web search of "dupin cyclide conformal map" brings up interesting papers.
- B
7777.1475
Hi All,
Multiple random Point Attractors determine hexagonal Screen hole radii
Have a great weekend,
EDITED: 9 Aug 2020 by JFH
Message 7777.1476 deleted 14 May 2019 by JFH
7777.1477
Hi all Friends
I was a few days holiday, just now ,
I see the latest news in the Forum _
Brian - Thanks for the clarifications regarding the Centroid tool
James - Congratulations on your latest work;
I found a small inaccuracy in determining the reference surface (Flow tool) in your file (DiaPlanarFaces)
at this link:
the file with the revision
Have a nice day everyone
al
7777.1478
Hi Friends
a nice example, at least I think, of a hypothetical and singular
mechanical clock
file at this link :
http://www.mediafire.com/file/4vm71yg0ad0565d/Mechanical_Clock.zip/file
Have a nice day to all
al
7777.1479
Hi Friends
a striking effect on surfaces.
the file at this link:
http://www.mediafire.com/file/5elcgg2sgios82d/Louvre_Box.zip/file
Happy weekend to all
al
7777.1480 In reply to 7777.1479
Nice Louver, Speedy.
Your Twist node comes up red ("missing" node).
Replacement with Twist node under Transform menu, in my nodeeditor setup, worked.
7777.1481 In reply to 7777.1480
Many thanks, Brian
7777.1482 In reply to 7777.1479
Hi Al,
Your louvred box was inspirational.
I have taken an alternative approach lofting profiles along axes, rotated (rather than twisted) in response to proximity to curve attractor.
It is shown here in an architectural context where it forms facade treatment to fully glazed curtain wall behind.
Keep up the good work
Additional images posted:
Size: 62.9 KB, Downloaded: 189 times, Dimensions: 760x713px
7777.1483 In reply to 7777.1482
Hi All,
My latest NE experiment
What is the last evolution of a complete folder nodeeditor ?
Message 7777.1485 deleted 6 May 2019 by JFH
Show messages:  1-5  …  1406-1425  1426-1445  1446-1465  1466-1485  1486-1505  1506-1525  1526-1545  …  1846-1859
