 1-13  …  1354-1373  1374-1393  1394-1413  1414-1433  1434-1453  …  1854-1859
7777.1394 In reply to 7777.1391
My bad code deleted.
EDITED: 14 Mar 2019 by BEMFARMER
They call this nitpicking:-)
Modified the text of the .html a little bit. ist = is, places = place, imputs = inputs, rebuilt = rebuild, olaces = placed, orientated = are oriented
"placed TO the rails" or "placed TO the first rail" do not sound quite right to me, but may be OK.
alternatives might be "placed on the rails or "placed along the rails..."
Also the AAABBBCCC placement description was not clear to me.
A description of the ABCABCABC placement would also be helpful.
Or even just AABBCC placement?
A specific example, say 4 objects to place, and two rails...(?)
The Sweep node has two options available by the RMB:
  • One Rail
  • Two Rails
One Rail:
Takes one Rail for each Sweep. The number of profiles used for each rail is defined by the whole number of profiles divided by the number of rails. The order in which the profiles are placed to the rail is defined by the switch in the infos panel. AAABBBCCC means the first, second, third, ... profile in the objectlist is placed to the first rail.
Two Rails:
Takes pairs of curves from the rail inputs and places profiles from the profiles input to them. The order in which the profiles are placed to the rail is defined by the switch in the infos panel. AAABBBCCC means the first, second, third, ... profile in the objectlist is placed to the first rail pair.
Info Panel
Options under the Info panel:
  • P Seq - which profiles are placed to which rail/rails
  • Twist - Defines how the profiles are oriented to the rail
  • Pointy ends - defines the form of the start and end of the sweep
  • cap ends - closes the start and end profile of the sweep
  • Profiles -defines the precision how the profiles are processed
  • Num Points - has only an effect if NumPoints is chosen under Profiles. It defines the number of points used to rebuilt the profile curves
  • #### - Brian
7777.1396 In reply to 7777.1395
Hello Brian,
I'm very grateful for your invertigations and improvements. Feel free to change things and send me the improved html, please. There are alot of other nodes to describe.
Thank You very much!
Karsten
7777.1397 In reply to 7777.769
Ralf,
We are looking to rationalise the extension nodes, & with a view to this I have retributed your node contributions into existing submenus. Have a look at attached r2d3.js file, & let me know what you think.
Also, I was having a play with your stream2array node: icosStream.nod attached.
I posted an animation to instagram (it too big to post here, I'm running out of server allowance)
Anyway, I have noticed some anomalous behaviour. Have a look at 2nd instance of stream2array node. It is not connected to an output but rather outputs through the 1st instance of the node. Curious!
Nevertheless, I am enjoying exploring your nodes
NE folder can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
EDITED: 14 May 2019 by JFH
7777.1398 In reply to 7777.1394
Hello Brian,
could you please test this:
 if ( document.URL.indexOf("appdata") > 0 ) { docupath = document.URL.split("index.html")[0]+"nodes\/extensions\/Documentation\/"+lang.LANGUAGE + "\/"; }
					else { docupath = document.URL.split(/moi:\/\/(.*\/).*/g)[1].replace("ui","")+"nodes\/extensions\/Documentation\/"+lang.LANGUAGE + "\/"; }
Thanks in advance!
Karsten
7777.1399 In reply to 7777.1398
Hi Karsten,
This version enables the doc dropdown in both "Light" and "default Dark" versions of nodeeditor. (It looks like you added [0] to your code.)
However it also creates a "mouse scroll/zoom wheel" "Hole" at the top center of the nodeeditor screen, Light or Default version.
7777.1400 In reply to 7777.1399
Hello Brian,
I've changed to split and take the first part by [0].
The scroll wheel issue doesn't happenend here with Windows 7 64bit and MoI Beta V4. I've tested also on Windows 10 - also no Problem!?
Have a nice day
Karsten
7777.1401 In reply to 7777.1400
Hi Karsten,
So far, no one else has reported having the "Hole", so ...?...
7777.1402 In reply to 7777.1401
Hi Karsten,
It seems that snaggit13 was causing the "Hole", so your latest code seems to be just fine, and enables Light and Default Dark nodeeditor, along with the ne doc dropdown.
7777.1403 In reply to 7777.1402
This world is too complicated for an old man like me.
Message 7777.1404 deleted 14 May 2019 by JFH
7777.1405 In reply to 7777.1404
Hi All,
Screen above lofted to fully open pattern to give variable aperture relief, mapped to a surface
7777.1406 In reply to 7777.1405
Amazing James!
Great job!!
Message 7777.1407 deleted 19 Mar 2019 by JFH
7777.1408 In reply to 7777.1405
Much nicer than a recent stucco expanded metal purchase.
7777.1409
Hi James
for what little it is worth ..
amazing result
alberto
7777.1410 In reply to 7777.1409
Thanks Al
It is worth a lot,
After 2 weeks of intermittent coding, study of many nodes, mostly by Karsten, and hundreds of corrections, a node for LineWeb was created.
There are many comments in the code, which could be removed.
In addition to the LineWeb node, a simple demo node program is attached.
Copy the LineWebNode.js file in the nodeeditor Extensions folder.
This will place the LineWeb node in the Construct2 menu.
(Construct2 could also be edited to include the LineWeb node code.) Maybe Karsten or James will do this, after the node is tested?
Testing has been minimal.
Input of other objectlist types has not be tested, nor is there any code to check for other types of objectlists.
EDITED: 23 Mar 2019 by BEMFARMER
For simple curve nodes such as Line, Circle, Star, Polygon, Curve/Interpcurve, ..., wired to an Output node, what color will the curve be drawn in?
If the Output node has "--" set for Style color, the color drawn will be the Style color currently in effect for MoI:
a. when the curve output is Wired to said Output node. And Run.
b. when the curve output is Rewired to said Output node.
c. when the node program is re-Loaded and Run.
If the Output node has a Style color set in it's Info box, that will be the color drawn, at Run, or during Run, over-riding a previously wired MoI Style color.
In the current session, Switching the Output node Style color set in it's Info box back to "--", reverts to the MoI Style color previously in effect, (even if MoI Style was changed, and there was no rewire.) (The previous wired color is "remembered" for the current MoI nodeeditor session.)
Normal Distribution, Bell Curve.
Show messages:  1-13  …  1334-1353  1354-1373  1374-1393  1394-1413  1414-1433  1434-1453  1454-1473  …  1854-1859
