 1-14  …  1315-1334  1335-1354  1355-1374  1375-1394  1395-1414  …  1855-1859
Message 7777.1355 deleted 6 Mar 2019 by JFH
Does it possible to make this sort of thing with Elephant ?
A bridge between 2 faces with a sort of variable adaptaion?
(and of course if the 2 faces are different that will be a must! !)
7777.1357 In reply to 7777.1356
Hello Pilou,
no it's not possible. I've started some subD nodes in the past, but they are all outdated and dosen't work at the moment.
Furthermore the node Editor has not the Level of interaction like such a software.
Have a nice day
Karsten
7777.1358 In reply to 7777.1357
THX for the efforts! ;)
7777.1359
Hello,
a few beginner's questions:
- is there a node bundle that works with latest beta, of February 26. Exactly, I'd like to get fillets. During this weekend I've tried to combine the code of node editor v.1.0.rc3.2018.03.09 which works nicely, together with code from construct2.js files downloaded from this thread, however only with limited success, MoI 4 beta is complaining about minimum fillet radius, sub-object naming node is missing. Obviously I'm doing something wrong, here.
- is it possible to have a node, able to import something directly from hard disk, like 3dm file or new subd from obj file into MoI. If so, we'll have a sort of usable referencing system.
- any plans for commercial version of these nodes - once such system will be enabled to work smoothly, I'd believe it will be able to dramatically improve the strength of MoI.
7777.1360 In reply to 7777.1359
Hi anto,
It may be helpful if you are able to post your .nod program, so that someone proficient may see the areas of concern.
I have not seen much activity in the nodeeditor arena the past few months, what with vacations, the season, and other interests.
But Max did make some much appreciated improvements, a short time ago!
The Objects/ Get-by-style node enables the entry of a .3dm file that is already in MoI, into nodeeditor, by color-style. Set the objects color-style to a unique color,
then open the .nod with the node.
There is also Objects/ Get-by-name.
I do not know how to script, or if it is possible to script, importing and exporting in a node. (???)
Sub-object naming node?
EDITED: 4 Mar 2019 by BEMFARMER
7777.1361 In reply to 7777.1360
Honestly I don't have any usable node tree, yet. I'm just looking for a way to get fillets into node editor in MOI 4, as they are definitively not present into ''official'' version, I suppose that is v.1.0.rc3.2018.03.09 . The rest of node editor is looking really easy to understand for anyone who already played with similar solutions, don't see general problems. I hope I'll find a way for these fillets, eventually.
Thank you for answer!
7777.1362 In reply to 7777.1361
Hello Anto,
here are my last extensions for NE. Put all the files directly under extensions - don't forget the basicfunction file in the libs directory. Fillet is difficult in NE. If you want to fillet a BRep use BrepNameSubObjects from Objects2 and wire it. Run the NE and the Brep will be displayed. Select the edges you want to fillet and use fillet from construct2. Construct2 stores the names given by BrepNameSubObjects. Wire the node. Switch of the visibility in BrepNameSubObjects. Example in the attachment.
@all: New nodes are in vector, objects2, construct2, ponts2, infonodes, curves2
Have a nice day
Karsten
EDITED: 8 Mar 2019 by KMRQUS
7777.1363 In reply to 7777.1362
Thank you Karsten for this update.
Please consider the attached modification of objects:separate, which will pass on to the output objects which are not separable.
I needed such objects to be passed on, for mapping.
Or maybe have two modes? Or a second version"
7777.1364 In reply to 7777.1363
Hello Brian,
I've added the node to objects2. And replaced the attachement extensions.zip in the previous email.
@all: I've placed an old version of the R2D3.js in the previous attachement and forgot the stream.js file. Now I hope everything is up to date.
Sorry for that.
Karsten
p.s.: A good moment to place your Torus node here;-)
EDITED: 5 Mar 2019 by KMRQUS
Message 7777.1365 deleted 5 Mar 2019 by BEMFARMER
Message 7777.1366 was deleted
7777.1367 In reply to 7777.1364
Note, smiley emoji causes deletion of message.
7777.1368 In reply to 7777.1362
Hello Karsten,
Thank you for new extensions.
I notice that your version of Flip is relegated to Curves2 menu,
however the functionality also applies to faces, as seen here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1204
Having said that, I think for the time being it is an acceptable home for the node,
but ideally this node should IMHO be folded into a general "Flip" node, together with Marco's "ArrayFlipper", as well as function for flipping num arrays.
With a view to this, I submit here, for your consideration: "FlipNumArray".
I have posted this before, albeit with a different name "arrayRev"
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1248
Below is an image of its use, which is simply to reverse the order of a num array.
I have also included an "ArraySort" node for sorting num arrays into ascending order,
which may have some application with managing data flows.
Please find attached your arraayExt.js with inclusion of 2 new nodes
PS I wonder if there would be value in initiating a new menu heading: "General"
Within in this category could go all the multiMode nodes
(those that have separate functions for numArrays, ptArrays, curves & surfaces etc).
Apart from a multimode "Flip" node; another example a node that would be at home
in a "General" menu would be a proposed "Extract2" node that would have, at once,
the functionality of Max's "Extract" node with "Numbers" & "Points" modes in addition
to 2 further modes: "ExtractPts" & "ExtractEdges"
Your thoughts?
EDITED: 12 May 2019 by JFH
7777.1369 In reply to 7777.1364
Hello Karsten,
I would also like to submit for your consideration another node: "Extend".
Again this is a node that I have already posted:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1258
However previously I had it in the Construct2 menu but now IMHO, it would be more logically placed in the curves2 menu. Here is an anime of it in use:
Attached is Curves2.js with Extend node included, and nod file for testing.
EDITED: 14 May 2019 by JFH
7777.1370 In reply to 7777.1369
Hello James,
thank you for the review. While making new nodes, I forgot to integrate some of the nodes - especially contributed once and nodes that I wrote for a special request . Maybe it's also a problem that I tried to test nodes with different versions of the NE and picked up then the wrong files - I don't know. I will take your email and pick up all the missing nodes and integrate them in a first step at the known positions in the menu. That will keep the node files working. I think it would be better in the future, that new nodes contributed, go to a special file, but in a given menu, it would be easier to maintain and avoid the lost of nodes.
Nevertheless a bigger review is necessary, but I can't do that, because I don't know how useful some of they are, how they fit in a concept, sometimes what they do - especially for foreign nodes. Some of them have the same or a similar function, you've already shown. So I can answer special questions and solve smaller problems, but I can't maintain a bigger concept. And we should never forget - the thread is not the base for a straight forward commercial product - it's for playing with software, mathematics and ideas - with no restrictions. I think that Max has the same intention only with much better skills and a higher aspiration to the quality of his work. And I think he has also a problem that we all have - time. Max has recognized the problem in an early stage, as he told us, that that he don't want to make all possible functionality - nevertheless, he gave us a very solid and broad base and the right direction.
At the end I've lost the overview;-)
Nevertheless
a nice day to you
and all the node players
Karsten
7777.1371 In reply to 7777.1362
Hi Karsten,
thanks for posting the extensions and I see some new nodes have been added since my last update.
The fillet and blend nodes if applied to 2 open ended curves or lines is it possible to control which ends it is applied to ?
Normally when modelling it depends on the end the pick is made so can the curve start and end points be identified and thus used to denote the ends to be filleted or blended ?
Last question is about the loopinit node have you a basic example how to use it ?
Many thanks
Barry
7777.1372 In reply to 7777.1371
Hello Barry,
at the moment its not possible to control the ends of the curve. It's a question I have to ask Michael. It's an input of the factory which takes a list, but I don't know what kind of type it needs. So the factory takes the closer ends. As a workaround you can trim the curves so you get the closer ends where you want it and use idxSelect to get the right curves - then blend or fillet.
LoopInit - damned it's an unfinished idea, I had a while ago - please remove Basic2.js
Thank's for the reply!
I will remove it in the extensions and place Brians Torus for that:-)
7777.1373 In reply to 7777.1372
Okay - done.
removed the useless Basic2.js
added Brians Torus Mapping
added flip to construct2
added ArrayRev, arraySort, Gate, FlipNumArray to arrayExt
added Extend to curves2
Hopefully everything is right now!
7777.1374 In reply to 7777.1370
Hello Karsten,
>> Nevertheless a bigger review is necessary, but I can't do that....
.....Some of [the nodes] have the same or a similar function, <<
I think you are right that the starting point is to pare down the extensions by removing redundant nodes, before rationalising them into agreed menus.
With a view to that I have a couple of questions:
1) Does new node Points2/PTS2pts perform any functions beyond Objects/ObjtoArray?
2) Are Transform2/FlowObj & Transform2/mFlowObj now fully redundant since Max's version Transform/Flow?
3) Is Objects2/intersectObj now redundant since new Objects2/intersectObjMP?
4) Does Points2/Path_Array do anything not already done by Points2/mPath_Array?
5) Was Construct2/mLoft made redundant by the addition of Construct2/mLoft2?
6) Is Construct2/Project now redundant since new Construct2/ProjectMP?
7) Wasn't Objects2/Concat2 made redundant by Max's updated Basic/Concat?
Generally, I already think I know the answers to all these questions, but I need your verification in case I missed something.
I need also to do some analysis of r2d3 nodes before posing similar questions for Raif (AKA r2d3), but ultimately as part of a rationalisation, we need IMHO to move any of his non-redundant nodes into the relevant menus.
Once that is done, I will post a full listing of node menus for comment, and if agreed upon post new extensions.js
I recognise that this will create issues of backwards compatibility but it is IMHO a necessary step to promote greater adoption of NE
Thank you for your enduring support
EDITED: 6 Mar 2019 by JFH
Show messages:  1-14  …  1295-1314  1315-1334  1335-1354  1355-1374  1375-1394  1395-1414  1415-1434  …  1855-1859
