 1-11  …  1272-1291  1292-1311  1312-1331  1332-1351  1352-1371  …  1852-1859
7777.1312 In reply to 7777.1309
Hello James,
very cool -Reminds me of Richard Deacon.
A nice day to all
Karsten
Message 7777.1313 deleted 6 Mar 2019 by JFH
7777.1314
Hello Friends ,
today an exercise of tension and relaxation of the surfaces, obtained on the faces,
performed in a basic Icosahedron-
Files and images at this link:
http://www.mediafire.com/file/ga1znig2hhg07og/Inflate_Icosahedron.zip/file
Have a nice Week End to all
al
7777.1315
Hi Friends
the repetition of structure with base
arc, rotated and scaled, can produce
an effect of considerable depth ....
files and images at this link :
http://www.mediafire.com/file/7d1jyywj4oxfpkv/VertigoArcs.zip/file
Have a nice evenig to all
al
7777.1316
Hi Friends ,
since I have not installed yet
the last Beta V4 x Moi,
and that the James's Shell command I do not have the possibility
to experiment it, I wondered if it could work
also for jointed Polysurfaces, quite complex
like the one resulting from my exercise squeezer .....
File and images at this link:
http://www.mediafire.com/file/qhu4emqt612vk1g/Squeezer.zip/file
attached a screnshoot of shell and fillet made in Catia (preview result for this modeler) ,
importing the stp file from the Nodeeditor ...
But if any of you can do it,
I'd be curious to know if you can solidify with shell in Nodeeditor
Have nice day
alberto
7777.1317 In reply to 7777.1316
Hello Al,
shell has a bug - I will have a look the next days.
Have a nice day
Karten
7777.1318
Hello Karsten
As usual, very kind and very helpful
thank you
I will wait to see the result...
Have a nice evening
al
7777.1319 In reply to 7777.1318
Hi Al,
Did you try baking out model (clicking "Apply" button on NE Nav Bar)
from your NE setup? It also, cannot be shelled with manual "Shell" tool.
The model as it is constructed, is beyond the limits of Moi's geometry
tolerances for shell function to operate as expected.
It looks cool, though to get it to shell will require alternative approach.
(perhaps slicing into stepped curves for lofting prior to shell operation)
Good Luck!
Hi Karsten,
It would be great if you could have a look at shell node.
It generally works in "Normal" mode, but I could not get "Centerline" &
"flip" options to work, so I abandoned multi-mode, but it would be good
to have the options.
I've attached construct2.js with latest version
Have a nice day
EDITED: 12 May 2019 by JFH
7777.1320 In reply to 7777.1318
Hello Al, Hello James,
please test the following code for the shell command:
    // Shell
function Shell()
	this.addInput("Surfaces","objectlist");
    this.addInput("Thickness","numarray");
	this.addOutput("Out","objectlist");
    this.properties = { mode:["Long","Long","Short"], thickness:[1], direction:["Normal","Normal","Flip","Centerline"] };
Shell.title = "Shell";
Shell.desc = "Shell";
Shell.prototype.onExecute = function()
    var surfaces = this.getInputData(0, moi.geometryDatabase.createObjectList());
	var data = this.processInOut(this.properties.mode[0], this.multiProcess, null, this.properties.thickness);
	this.properties.thickness = data.inputs[1];
	this.setOutputData(0, data.outputs[0]);
Shell.prototype.multiProcess = function(s, t)
	return [factory('shell', s, t, this.properties.direction[0])];
LiteGraph.registerNodeType("Construct2/Shell", Shell);
@James: Please test the code first, correct the construct2.js file and post/replace it. The problem was, that you had a look in the sometimes outdated API-Documentation - it's always a good idea to look also in Michaels code under the command folder.
A nice day to all
Karsten
Documentation:
ArrayExt menu:
"idxSelect" (an on/off switch, or data selector).
This node has a data input and a data output of matching datatype. Said datatype is determined by RMB clicking on the node, and then clicking either "Numbers" for numarray datatype, or "Points" for pointarray datatype (default), or Objects for objectlist datatype. The node also has a controlling numarray input called idx (index). If the value of idx rounds up or down to 0.0 (i.e. -0.5 <= idx < 0.5), then the data input is connected to the data output. (The on-of switch is on.) If idx is 1 (actually if idx <= -0.5, or 0.5 <= idx, then the data input is NOT connected to the data output. (The switch is off).
By varying the value of idx, portions of the data stream wired to the input can be passed on (selected), or blocked.
A rudimentary circle .nod was used to figure out the function.
(I made a few minor changes to the nodeeditor Wiki, which is very out of date and incomplete.)
Current directory of extension nodes is difficult to locate...
Nodeeditor is over 3 years old.
I spent considerable time re-reading the parametric design thread, and nodeeditor thread, to try to learn more of how each node works,
and copied relevant portions to a text file, to distill out some documentation
EDITED: 23 Dec 2018 by BEMFARMER
7777.1322 In reply to 7777.1321
Hello Brian,
that's really good news! Every help is welcome and you are completely right - It's time for an update!
In the past, it was sometimes frustrating and demotivating to be exposed to certain criticism about filing locations, documentation and organization. This criticism is justified and everything could be better - but my time, skills and motivation is limited and I never promised anything. On the other hand, I had to ask myself the question: Who actually uses the thing? And is it even necessary to write a documentation if there are only 5 people who anyway have a better understanding of the possibilities than me? Nevertheless it makes me happy to read about your activities. Let's keep the elephant alive - only one line of code or documentation is better than any discussion about it.
Now I have to dig to my passwort for the wiki.
Some peaceful days to all
Karsten
7777.1323 In reply to 7777.1322
A quick email search located my wiki password. It is well to avoid letting chrome save it, as otherwise the MoI forum password may be overwritten.
Yes, project time is limited. I have a little geometry project in mind, call it a little algorithm, to be done with the node package, but was very unsure of which nodes to use, and how to combine them properly, to get the desired results. Grasping that the three data types are all "arrays"/"lists" of some type, although each
is an array of different types of things, and that the array data "streams" or "flows" along the "wires"/ "tubes"/ "pipes," is helpful. The effective length of all of the wires is essentially zero, and data flow along them is nearly instantaneous. Also it seems like the same English word can be used to describe many different things, so it is harder to describe how everything works. It must be very hard for those whose native language is not English (or French:-). Several different things are called programs. It my be helpful to have a dictionary section defining what words and abbreviations mean. It is very helpful to have little demo node packages, to see how a node works, and LOTS of pictures. Most people have no idea how to program a nodeeditor somenode.js javascript program, myself partly included. Using these graphical nodes is a little easier.
7777.1324 In reply to 7777.1320
Thanks Karsten,
Unfortunately*, I’m away for a month, so am unable to test (no computer)
I’m sure it works perfectly, your coding is always spot on!
I’ll repost the file the moment I return in end of January.
Merry Christmas to you & everyone here,
Speak in the new year
* perhap “Unfortunately‘ is not the word for describing a holiday.
EDITED: 23 Dec 2018 by JFH
7777.1325 In reply to 7777.1324
Hello James!
...but "no computer" is for sure a valid word for describing a holiday :) :)
Merry Christmas and best wishes to everyone :)
7777.1326 In reply to 7777.1325
Marco, that made me laugh!
Have a wonderful Christmas
& we’ll speak in the new year.
EDITED: 24 Dec 2018 by JFH
James' B-HiveGrid Macro prompted investigation of the Polygon node.
7777.1328 In reply to 7777.1327
James has already done 2 versions of Hex Grids macros, which I still do not fully understand.
After a lot of study, here is my version, HexFlatGridAlpha01.nod, which contains the HexFlatGridMacroAlpha01.
The mini Hex nod may be saved in your nod library, and the Macro may be Exported to the nodeeditor macro folder.
I still need to write up my documentation. It was hard to wire up the "math formulas," and the macro is a bit of a wiring "birdnest."
Separate MathPts arrays for the non-indented and indented columns, as the array node did not seem to be amenable to doing them together.
The behavior of the U range, prevented the display of only one column, as maxRange for a single column incremented itself.
Still need to Extract X and Y values.
It took awhile to realize that the unum and vnum are total copies, not incremental values.
After creation, the grid may be MoI Mirrored to the pointy vertices up orientation, with rows and columns swapped.
Perhaps some alteration to the behavior, in nodeeditor, of the Esc button could be done. When 2 or more nodeeditor windows are open,
pressing Esc deletes the currently selected window, and the work done is gone. If only one window is open, (or focus is on the initial window?),
after Esc is pressed, the window reappears by reloading with nodeeditor hotkey, but other windows are gone.
(A habit of pressing Esc button at times, erased some windows, but only a little bit of work was lost...)
(After upgrading office computer from w7 to windows 10, Quickbooks 2018 refused to open, until uninstalled and reinstalled. (MoI 4 beta worked fine.)
Also, for MS Office 2016, (and also Office 365 monthly fee version), the Excel, Word, Publisher, Access, and PowerPoint programs refused to open any files,
and crashed. After some talented Microsoft techs from the Philippines spent 2 or 3 hours+ remote controlling the computer, the problem is
not resolved. Next week is "Level 3" :-) ) [Everything worked fine on home computer.]
>>>Update, took office computer home to fast internet, reinstalled Windows10, and everything works.
Do not install/upgrade to W10 on a slow telephone line internet.
All node programs should have a Title box on the node window...to aid memory of which nodes were just open... (Using an extra Output box works OK)
EDITED: 30 Dec 2018 by BEMFARMER
7777.1329 In reply to 7777.1328
Hi Brian, for the escape key handling, one possibility could be to put in an onunload="" handler which can go on the <body> element, and save work there. There's an example of that in the Options.htm dialog.
Also in v4 it is possible for a dialog to do custom handling of keyboard events and it is possible to override escape key handling. There's an example of dialog keyboard event handling in ShortcutKeyDialog.htm .
Putting in a function like this should prevent the default escape key processing which closes dialogs:
			function OnKeyDownEvent( e )
				if ( e.isEscapeKey )
					e.handled = true;
7777.1330 In reply to 7777.1329
Thank you Michael.
I've recently noticed another "strange" behavior in MoI4Beta, or nodeeditor.
When a nodeeditor window is open, and its upper left section, about 2 inches square, more or less, is overlaying the origin of the MoI screen,
using the mouse scroll wheel in the nodeeditor window, causes the MoI grid to zoom in and out.
(The upper left area of the nodeeditor window does not have to be over the origin.)
p.s. This does not seem to be occuring in MoI3 with the same nodeeditor version 1, rc3.
Nodes activity in this area has the node flying way way off to the Northwest of the node screen...
They can be moved back into viewing range...
EDIT: The above behavior did not occur the next day, with a reboot. But later in the day, the "zooming" is back.
7777.1331 In reply to 7777.1328
I’m sorry if my Hex Grid macros were a source of frustration for you. You’re right that there several incompatible versions. It was more a cobbled-together contraption to perform a given need than a definitive macro for broadcast. So thank you for your work in producing a universal macro for hexagonal grids.
I am, right now, on an island: “Phi Phi” off Thailand, with no means of testing / playing with it, but thank you for your hard work; it is much appreciated. I look forward to seeing your documentation.
Warm regards
EDITED: 31 Dec 2018 by JFH
Show messages:  1-11  …  1252-1271  1272-1291  1292-1311  1312-1331  1332-1351  1352-1371  1372-1391  …  1852-1859
