 1-11  …  1212-1231  1232-1251  1252-1271  1272-1291  1292-1311  …  1852-1859
7777.1252
Hello friends
I want to share this exercise with you
referring to the Brainstorming Confluence Park Pavillon
from the site _ Parametric House.com _
I recreated everything with EI and I added the Flooring ...
The compositions are two enough to properly switch
files and images at this link:
http://www.mediafire.com/file/7e6gshqle7qdrsv/Confluence_Park.zip/file
Have a nice evenig to all
al
Ps- James , nice work with the new Array Ext ,
congratulations.....
7777.1253 In reply to 7777.1250
Hello James.
Thank you for your feedback and your contribution to the common cause.
It's really fun to do.
Vladimir.
7777.1254
Hi All,
Continued experimentation with interwoven patterns on surfaces. (nod file attached)
PS. Michael thanks for the V4 update. Everything is working great!
EDITED: 14 May 2019 by JFH
7777.1255
Knurl on diameter
EDITED: 17 Jan 2021 by WAYNEHILL5202
7777.1256
Hi Friends
a simple umbrella .....
that you can close and open
Those interested find this link:
http://www.mediafire.com/file/rlo8fk7jcy6z69g/Umbrella.zip/file
images and files
Have a great weekend everyone
al
7777.1257
Hi All,
I have included a new "Shell" node in the attached construct2.js
ATM shell offset is parametric but only in normal direction. Flipping the direction is easily achieved by pairing with "Flip" node (also included)
At a later date, I will see if I can add "centreline" mode, but for now it suits my purposes.
By way of demonstration, I applied shelling to nod file previously posted (with coarser pattern and no subd smoothing) . Please also find attached.
A great weekend to all,
UPDATED: another simple example of shell node attached
EDITED: 7 Jun 2019 by JFH
7777.1258 In reply to 7777.1257
Hi All,
I have updated construct2.js to include additional new "Extend" node which performs analogous to "Constuct/Extend" tool: extending a curve to meet a boundary curve or surface.
7777.1259
Good morning James
excellent work with the New Extension Construct2
I have a problem, as you will see from the screnshot , opening your files
shell, I get an error message .......
Does it depend on some awkward setting in my program?
I simply replaced it in the UI / Nodeeditor folder
your new script to replace the existing one
image at this link:
http://www.mediafire.com/file/49654g68o20zgcf/Shell-problem.jpg/file
Thanks in advance
al
7777.1260 In reply to 7777.1259
Hi All,
Al (Speedy 2000) has drawn my attention to the fact that shell node only works in V4.
I will endeavour to fix this issue, but it may be a while.
All the best to everyone,
EDITED: 23 Oct 2018 by JFH
7777.1261 In reply to 7777.1242
Hello James,
please try this code. It seems there is sometimes a timing problem with the copy/paste stuff. Very untested.
// extractPts
 function extractPts()
 this.addInput("In","objectlist");
this.addOutput("ptarray", "pointarray");
 extractPts.title = "extractPts";
 extractPts.desc = "extractPts";
 extractPts.prototype.onExecute = function()
 var inObj = this.getInputData(0, moi.geometryDatabase.createObjectList());
 var output = moi.geometryDatabase.createObjectList();
 var selPts = moi.geometryDatabase.createObjectList();
    var originXYZ = moi.VectorMath.createPoint(0, 0, 0);
var temp = moi.geometryDatabase.createObjectList();
	         var pts = new pointArray(false);
	 moi.geometryDatabase.selectAll();
	var existings=moi.geometryDatabase.getSelectedObjects(); //Locking the database objects
	 moi.geometryDatabase.deselectAll();
	 if (inObj.length > 0 )
 {  var tempname=getUID(6);
for(var i=0;i<inObj.length;i++){temp.addObject(inObj.item(i));temp.item(i).name=tempname;};
moi.geometryDatabase.addObjects(temp);
temp.setProperty('showPoints', 1);
temp.setProperty('selected', 0);
existings.setProperty('selected', 0);
 moi.geometryDatabase.copyToClipboardCommand(temp);
moi.geometryDatabase.pasteFromClipboard();
//setTimeout( doNothing, 500);
 selPts=moi.geometryDatabase.getSelectedObjects();
for(var i=0;i<selPts.length;i++)pts.pushPoint(selPts.item(i).pt);
if(selPts.length>0)output = factory('copy',selPts,originXYZ,originXYZ,true);
 moi.geometryDatabase.selectNamed(tempname);
        temp=moi.geometryDatabase.getSelectedObjects();
        var delfac = moi.command.createFactory( 'delete' );
	delfac.setInput( 0, temp );
	delfac.commit();
	delfac.cancel();
	existings=moi.geometryDatabase.createObjectList();
this.setOutputData(1, pts);
 LiteGraph.registerNodeType("Objects2/extractPts", extractPts);
Have a nice day
Karsten
p.s.: For V4 Michael will give us some new features in the API that will make a lot of things easier.
EDITED: 25 Oct 2018 by KMRQUS
Message 7777.1262 deleted 24 Oct 2018 by JFH
7777.1263 In reply to 7777.1261
Thanks Karsten,
Work perfectly....I wish I had your skills. You're a champion!
Thanks again
EDITED: 25 Oct 2018 by JFH
7777.1264
Hi Karsten
this morning I saw a bit of light at the bottom
to the tunnel ..... I managed to insert your script
extrPts in Object2 -Alleluja
it works great, even with the V3 ,
you are a GREAT , and believe me ,
your "forced" absence has been very heavy
have a nice day
al
Ps:
Courage;
We say ... dead a pope it does another one
7777.1265
Hi All,
I have rewritten "Shell" node for multiprocessing and reattached "construct2.js" to earlier post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1258
Here is an experiment where shelling is varied across an array of hexagon extrudes
in response to proximity of 3 attractors. Although similar could be achieved by offsetting or scaling curves prior to extrude, shelling makes the process much simpler.
Also requires "reRange node" in arraysExt.js to be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1251
EDITED: 17 Feb 2019 by JFH
Nice result!
My Moi French Site My Gallery
7777.1267
Hi All,
I have been trying without success to write a simple node for assign a style to geometry.
See my attempt below:
// SetStyle
function SetStyle()
this.addInput("obj","objectlist");
this.addInput("idx","numarray");
SetStyle.title = "SetStyle";
SetStyle.desc = "SetStyle";
SetStyle.prototype.onExecute = function()
var objects = this.getInputData(0, moi.geometryDatabase.createObjectList());
var index = this.getInputData(1,index);
var output = objects.setProperty('styleIndex', index);
LiteGraph.registerNodeType("Objects2/SetStyle", SetStyle);
The aim here is quite modest, but ideally the node would not just assign existing indexed styles but instead add new styles with RGB inputs prior to assignment.
Any help would be appreciated
7777.1268 In reply to 7777.1267
Hi James, this line looks a little suspicious to me:
That's passing in index which I guess is undefined at that time, and then assigning the return value to index too?
For adding new styles, you can use either:
var style = moi.geometryDatabase.addStyle();
or
var style = moi.geometryDatabase.findStyle( 'name', true /* Create if not found */ );
The second one will return an existing style if there is already one with that name, or create a new one if none of that name currently exist.
Then on a style there are read/write properties for .name and .color and the style's index value is a read only property .index .
Does that help with anything? Let me know if you're still stuck.
7777.1269 In reply to 7777.1267
Hello James,
Have a look to this:
    // SetStyle
 function SetStyle()
	  this.properties = {Style: [0]};
        this.properties.Style = this.getInputData(1, this.properties.Style);
//for(var i=0; i<objects.length; i++)objects.item(i).styleIndex = this.properties.Style[0];
objects.setProperty('styleIndex', this.properties.Style[0]);
 var output = objects;
Have a nice day
Karsten
p.s.: Don't forget - you are working with Arrays!!! It's not like arays in C, where the adress/name points to the first element;-)
EDITED: 12 Nov 2018 by KMRQUS
Message 7777.1270 deleted 12 Nov 2018 by JFH
7777.1271 In reply to 7777.1269
Hi Karsten,
Thanks again for setStyle node.
At the risk of appearing ungrateful (which I'm not at all, quite the opposite), would it be difficult to make this node multiprocessing?
To colour facets in accordance to distance from an attractor, it was necessary to replicate the geometry 8 times & remove those facets with ptDist that have been remapped to range between 0 - 7 and rounded to integers and then tested in series. This approach quickly becomes cumbersome with each additional style attribution.
I have also attached the .nod file, however on running, the colours will appear different to those above because they will instead index default styles.
The ideal solution would be a setColor node that had inputs for Red, Green, & Blue values and handled the indexing automatically. Whether setColor and setStyle nodes should be combined into a single node or separate nodes, I'm not sure which is best....
Your thoughts?
EDITED: 9 Aug 2020 by JFH
Show messages:  1-11  …  1192-1211  1212-1231  1232-1251  1252-1271  1272-1291  1292-1311  1312-1331  …  1852-1859
