 1-3  …  84-103  104-123  124-143  144-163  164-183  …  1844-1859
7777.124 In reply to 7777.122
Hello Al,
thanks for the details. I had to change some internal things of the node to get it to run under that version. Sometimes I have to fight with some sideeffects and it is difficult to test all configurations, in which a node has to work. Some of the bugs took hours to understand them. Some nodes make problems again and again. Anyway ...
I redid the connections, and it works , but creates
the surface Brep source ( why ?)( picture-2) >>> Did you cloned the BrepNameSubObjects? If you do that, both will have the same basename for naming the sub elements. That can cause the problem. You can change it manually or create a new one for that. Moi's API isn't made for that stuff, so it is difficult to create that functionallity. Otherwise I saw also some unselectable ghost-objects while using the node editor - not selectable - like display artefacts - with other nodes. Is this actual problem repeatable?
I saw the new Offset node ....
I forgot to delete the offset node - it isn't finished - it works only in a first step. The flip for the side isn't stable. For test purposes you can show -with the frame output - the decission of the offsetfacory where the offset is placed. Ok - for a flip I have to calculate a frame on the other side of the input. But for a line the point is lying on the curve - typically you decide it with a pointer, but in the node editor isn't any interaction;-) These are the problems ...
Have a nice day
Karsten
7777.125
Hello Friends
starts again week, continue the tests ....
a little exercise with input curves in Moi
and a little test SubD
best
al
Size: 287.8 KB, Downloaded: 172 times, Dimensions: 1920x1080px
7777.126
Hello Friends
another test : Flow with Surface deformation Target
best
al
Size: 280.8 KB, Downloaded: 165 times, Dimensions: 1680x1050px
7777.127 In reply to 7777.126
Hello Al,
(In Italian)
Stai diventando un drago con il NodeEditor!! :)
(In English)
You're becoming a master with NodeEditor!!
Ciao!
7777.128 In reply to 7777.127
(Italian)
Marco amico mio , grazie
ma sono ancora piccole cose, rispetto a quello che si potrebbe fare..
Grazie sopratutto a Karsten, James, te , ed il grande Max per lo sviluppo
del sistema..
speriamo che tutto proceda per i verso giusto...
saluti
al
Ps- ho visto nel Forum , che sei interessato anche da Thinksolid...
Bel Modellatore sto iniziando ad usarlo anch'io
(English)
Mark my friend, thank you
but they are still small things compared to what you could do ..
Thanks especially to Karsten, James, you, and the great Max for development
of the system..
we hope that everything goes the right way ...
best
al
Ps- I saw in the Forum, you are also interested by Thinksolid ...
nice modeler I'm starting to use it too
7777.129 In reply to 7777.128
Hi Al,
Thanks a lot for your kind reply!
> "Ps- ho visto nel Forum , che sei interessato anche da Thinksolid...
Ps- ho visto nel Forum , che sei interessato anche da Thinksolid..."
Hemmm.....how to say it....Sincerely I don't know ThinkSolid :)
Maybe you are referring to a different product or you're getting me mixed up with a different user,
or maybe I'm doing confusion... :)
Anyway...if you are referring to SolidThinking Evolve (SOLIDTHINKING) I can say you a couple of things.
1) I tried the product for about 1 month and I got rid of it without doubt.
Ok, very very good integrated renderer and interesting PolyNURBS tools (similar to T-Spline).
But, TERRIBLE, terrible UI and workflow!!
I can't imagine nothing worst.
2) Very bad forum and very bad support.
See you,
7777.130 In reply to 7777.129
Hi Marco
Yes Mark , I'm sorry for the inaccuracy
I meant precisely SolidThinKingEvolve , and Inspire ,
I agree with you with regard to the interface
somewhat antiquated the WorKflow and also to
the Forum ....
But I find robust enough the Engine "Siemens" unless
mistake a derivative of NX or Parasolid
that responds very well, is also an interesting
variety of proposals surfaces, which when combined with PolyNurbs
in my opinion it makes the product interesting enough-
best , and good Work
al
7777.131
Hello,
caused by the thread Placing spheres on knots/vertices and the very interesting skript fileToShape from libelle (many thanks for that!!!) I have made a draft for some nodes to read coordinate files back. (import/CSV-file - ArraysEXT/idxReplace)
Have a nice day
Karsten
EDITED: 12 Dec 2017 by KMRQUS
Hi everyone.
I repeat here the same message that I wrote in the topic "Placing spheres on knots/vertices",
because this is the right place.
Here's the version v.0.85mod5 of "Project Elephant" : http://take.ms/Pxp6A
It's almost identical to version v.0.85mod4 posted by Karsten, with the addition of the "objectsExt.js" file which includes
the "SelectedObjExt" node that I wrote some times ago.
This node is an updated version of the standard "Selected" node, which allows to specify the order of selected objects : "By Selection" or "By Creation".
It's very useful in order to obtain different elaborations of the same data.
Best,
Hi everyone and good evening.
I'm planning to write a new utility node for the Project Elephant's "pointArray" structure,
but I don't know if already exists something similar within the latest official Max's v.085 version
or within the latest community version v.0.85mod5 (downloadable here http://take.ms/Pxp6A)
So, I tell you what I want to do.
First of all I say that this new node should be based on the great Max's "MathPts" node.
That is, in order to write this new node I will use most of the "MathPts" code, plus some new ad-hoc javascript code.
So, this shoud be the new node : "MathTrasformation" and here's in brief what it should do :
- Input :
     - PointArray
     - Math formula to apply to "X" values of each array element
     - Math formula to apply to "Y" values of each array element
     - Math formula to apply to "Z" values of each array element
     - Math formula to apply to "AngleX" values of each array element
     - Math formula to apply to "AngleY" values of each array element
     - Math formula to apply to "AngleZ" values of each array element
     - Math formula to apply to "pSize" values of each array element
- Output :
    - The resulting PontArray
I repeat, I don't know if already exists something similar, but I think that this "MathTrasformation" node would be a very very powerful tool
in order to do almost infinite kind of PointArray eleborations.
As I said many times in my previous posts, unfortunately my math skills are very very basic,
so in order to write this new node I will leverage only on my "creativity and intuition" :)
If any of you want to write this same node I will be very happy to share the results.
Have a nice day.
Max's Array3D script?
7777.135 In reply to 7777.134
Hi bemfarmer and thanks a lot for the suggestion!!
Yes!!!
I mean definitely something very close to a special version of Array3D script translated into a node,
with the opportunity to include into every single math formula, a reference to the fields of the PointArray structure.
For example, this could be an hypothetical math formula applied to "X" values of each array element : "(sin(ptY) * AngleX)"
Where "ptY" and "AngleX" are special names that refer to "ptx" and "AngleX" field of the PointArray structure.
The node I'd like to try to write should include also the opportunity to use additional input fields like the "Basic->Math" node.
Thanks and have a nice day.
P.S. A little correction : Unlike the "Array3D" script, this new node, probably named "ArrayMathTrasformations",
will not generate an array of pointArray, but simply, given 1 input pointArray it will returns 1 transformed pointArray as output.
EDITED: 14 Nov 2016 by MKDM
Message 7777.136 deleted 15 Nov 2016 by MKDM
Hi everyone and good morning.
(I deleted an recreated this post because I made a mistake in previous xls file)
As agreed in a previous post, I upload here the file "nodes_V0.85_mod5.xls",
containing an updated version of the infos of all my nodes (column Authors : Marco).
I have slightly modified the layout of the previous file "nodes_V0.85_mod4.xls" created by Karsten, in order to get more columns and a better reading.
If you don't like this layout, you can freely change it, as long as you don't remove the additional columns.
This is the file "nodes_V0.85_mod5.xls" : http://take.ms/p25l2
Best,
7777.138
Can someone explain to me this strange behavior
I get , by inserting Interpolated on the Math Node Point? ;
the same interpolated placed on simple Node Point
it is OK......
where am I wrong?
I do not understand
best
al
Size: 303 KB, Downloaded: 148 times, Dimensions: 1920x1080px
7777.139
( italian)
Ciao Marco , ti rivolgo questa domanda , dato che sei il
creatore dei Nodi in questione....
è possibile concatenare in uscita tre gruppi di punti
ad esempio :
Gruppo A - n°30 pt
Gruppo B- n°30 pt
Gruppo C- n°30 pt
ed ottenere un raggruppamento di n° 3 entità , una per gruppo,per
poi collegarli come input ad un Nodo Curve ed avere come risultato finale
n°30 Curve ?
Ti allego un file ed un Immagine dell'operazione eseguita con Rhino e Gh
Credo sia assolutamente necessario per lo sviluppo del sistema
iniziare a pensare a collegamenti " multipli " tra input.....
grazie in anticipo per i chiarimenti
al
(English)
Hi Marco, you address this question, since you're the
creator of the nodes in question ....
Can you concatenate output three groups of points
for instance:
Group A - n° 30 pt
Group B - n° 30 pt
Group C- n° 30 pt
and obtain multiple groupings of entities n ° 3, for a group, for
then connect them as input to a Node Curve and have as a final result
n° 30 Curve?
I am attaching a file and a picture of the operation carried out with Rhino and Gh
I think it is absolutely necessary for the future development of the system
start thinking about "multiple" links between inputs .....
thanks in advance for clarification
al
Size: 328.3 KB, Downloaded: 137 times, Dimensions: 1920x1080px
Size: 436 KB, Downloaded: 177 times, Dimensions: 1920x1080px
7777.140 In reply to 7777.139
Hi Al,
Are you referring to "PatternSelArray" node or "ConcatPts" and "IdxSelect" nodes.
I wrote only the first one.
Unless you are referring to a different "Marco".
I'm "Marco (mkdm)" from Italy.
Let me know.
Ciao!
7777.141
Yes Marco
I refer to PatternSelArray etc. etc.
I saw your name in the karsten's xls file info
al
7777.142 In reply to 7777.139
Hello Al,
Max has already integrated all necessary features (Hats off!!!). Also the node curve is ready for that. The only node is needed, is the union node for that. I have investigated the internal things and I believe that I can make a node for that. A draft with bugs is running. Such a node needs the support of the internals of the pointArray data type. Especially the xlength (number of points for each curve), ylength=1 and zlength (number of points in each array = number of curves)seems to drives the evaluation.
Have a nice evening
Karsten
7777.143 In reply to 7777.139
Hello Al,
please test the node. I hope it fulfill your needs.
Have a nice evening
Karsten
Show messages:  1-3  …  64-83  84-103  104-123  124-143  144-163  164-183  184-203  …  1844-1859
