 1-6  …  1087-1106  1107-1126  1127-1146  1147-1166  1167-1186  …  1847-1859
7777.1127
Hi Karsten
Thanks in advance for your contributions
"Illuminants"
look forward
Good evening
alberto
7777.1128 In reply to 7777.1127
"Hello - is it this you looking for - I can see it in your eyes - I can see it in your smile ..."
Not direct the closest distance, but more general. It is the project curve factory and it works also for points to curves. Please test and study. The direction mode takes the x-axis of the frame input. For closestpt it is not necessary.
        function Project()
	this.addInput("Objects","objectlist");
        this.addInput("Target","objectlist");
	this.addInput("Frame","pointarray");
	this.addOutput("Out","objectlist");
	this.properties = {ProjectMode:["closestpt","closestpt","direction"]};
Project.title = "Project";
Project.desc = "Project";
Project.prototype.onExecute = function()
        var obj = this.getInputData(0, moi.geometryDatabase.createObjectList());
        var target = this.getInputData(1, moi.geometryDatabase.createObjectList());
        var f = this.getInputData(2, new pointArray(true));
        var output = moi.geometryDatabase.createObjectList();
	//0 Object
	//1 Objects
	//2 projectmode
	//3 basePt
	//4 TargetPt
	//5 delete inputs
	//6 plane
	//7
	var frame = f.getFrame();
	var pFac= moi.command.createFactory( 'project' );
	pFac.setInput( 0, obj );
	pFac.setInput( 1, target );
	pFac.setDefaultDirection();
	pFac.setInput( 2,this.properties.ProjectMode[0] );
	pFac.setInput( 3, frame.origin );
	pFac.setInput(4,frame.evaluate( 1, 0, 0 ) );
	pFac.update();
        output = pFac.calculate();
	pFac.cancel();
        this.setOutputData(0, output);
LiteGraph.registerNodeType("Construct2/Project", Project);
A nice day to all
Karsten
7777.1129 In reply to 7777.1128
Hi Karsten,
Well there was hardly any time for impatience, you've done it....and it is just perfect.
Brilliant stuff as always
PS This is an application where reMapRange is useful: allowing greater controls of min/max radii and extrude height.
EDITED: 14 May 2019 by JFH
Size: 46.5 KB, Downloaded: 73 times, Dimensions: 480x469px
7777.1130 In reply to 7777.1128
Karsten,
Your new node is a godsend.....which makes you a....?
Here, a ptArray is deformed with a curve, which makes for a delightfully simple way of generating a parametric surface.
PS Karsten, if you are now open for suggestions; this is a big one: it requires 2 nodes to work in unison. Firstly a image import node and secondly a node that converts greyscale values to numArray (à la Max's heightMap script). These num values may be z value for a ptArray, however they may alternatively be radii of circles (Che) or scale values or whatever............ Could Be Good!
This not even a request, just something to get you excited about. In the meantime there is no end of fun possible with your latest node.
Below image: using circle attractor
Size: 22.8 KB, Downloaded: 71 times, Dimensions: 640x365px
7777.1131
Hi Karsten and James
One thing friends ...
the js file for the NE (Project)
where can I find it...
you've already posted it, and I missed ...
thank you
al
7777.1132 In reply to 7777.1131
Hello Alberto,
>> the js file for the NE (Project)... where can I find it..<<
Copy the code (within grey rectangle) @
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1128
and paste into the bottom, but just above })(); of Construct2.js code.
Directory:
C:\Users\< user name>
\AppData\Roaming\Moi\nodeeditor\nodes\extensions\construct2.js
Hope this helps
PS If you have not already done so, also paste in code for railRevolve and Network.
Code found in posts below:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1085
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1086
EDITED: 27 Jun 2018 by JFH
7777.1133
Hi James
I think I'm wrong
I'm in difficulty with the copy and paste operations
that step by step you showed me .. I think I did not understand well
how and where to paste the script ...
can not you send me (construct2.js) already updated with it
script project inserted in .....
like you did with Network and Rail revolve,
then I'll put it in the usual directory ...
Thank you
alberto
7777.1134 In reply to 7777.1133
Hi Alberto
Please find attached.
Good Luck
EDITED: 12 May 2019 by JFH
7777.1135
Many ,Many Thanks my Friends
have a nice day
al
7777.1136
Hi All,
So here's ya 70's Prog Rock album cover right here
Click on CLICK ME. Click again to get new result......repeat.
7777.1137 In reply to 7777.1136
So cool!!
7777.1138
Hi Karsten,James and all Friends
A gold ring with a decoration Lapislazzuli paint;
a gift, which could be good for any woman,
mother, wife, friend, partner, lover, do you....
Don't make Jokes ....
the file at this link:
http://www.mediafire.com/file/pfrr7tzwz4crozg/Diamond_Ring.zip/file
have a nice day to all
alberto
7777.1139 In reply to 7777.1138
Hello Alberto,
Wow, I was not expecting that...really amazing animation
Keep up the great work
7777.1140
Good Morning James ,
I have to say the same thing for you ,
sincerely the Voxel file is "unsettling"
(in italiano , direi spiazzante)
Bravo, and original .....
have a nice day
ciao
al
7777.1141 In reply to 7777.1129
Hi James,
I have downloaded your remap nod file but getting this error ( ReferenceError: Can't find variable: magnitude)
So not sure if I have all the latest additions to extensions. (I have added the one's posted by Karsten)
Any Idea's what I'm missing.
Barry
7777.1142 In reply to 7777.1141
Hi Barry,
I just reviewed the reMapNode.nod file :
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1114
and there is no recent extension nodes that you might be missing. Though, I have only tried it with MoiV4, perhaps it has backward compatibility issues.
I'm sorry that I cannot more helpful
EDITED: 28 Jun 2018 by JFH
7777.1143 In reply to 7777.1141
Hello Barry,
please check if basicfunctions. js is missing in extensions/libs.
Have a nice day
Karsten
7777.1144 In reply to 7777.1143
Hi Karsten/James,
correct the basicfunctions.js was missing from my node editor version in Moi V4
All's working well again.
Many thanks.
Barry
7777.1145
Hi Friends ,
a Torciglione whose execution
it is entrusted to the Macro Helix, and to the subsequent adaptation
to a reference curve-
As usual, the file at this link:
http://www.mediafire.com/file/s9mz17a6mp9z11x/TORCIGLIONE.rar/file
Have a nice Week-end to all
alberto
Message 7777.1146 deleted 9 Aug 2020 by JFH
Show messages:  1-6  …  1067-1086  1087-1106  1107-1126  1127-1146  1147-1166  1167-1186  1187-1206  …  1847-1859
