 1-9  …  1070-1089  1090-1109  1110-1129  1130-1149  1150-1169  …  1850-1859
7777.1110
Hi Finema
No reply....!!!
Were you able to run the file ..
I hope so
alberto
7777.1111 In reply to 7777.1110
no
script error at run
sorry
7777.1112 In reply to 7777.1106
Hello Finema,
please try to store the file to another Folder/directory - maybe there is a Problem with the path or the Name of file.
Please Show us the file-path.
Which OS and MoI-Version you are using?
Karsten
7777.1113 In reply to 7777.1110
Hello Al,
can you please post the *.nod file to the forum?
Thanks in advance!
Karsten
Message 7777.1114 deleted 14 May 2019 by JFH
Vasarely revival! :)
My Moi French Site My Gallery
7777.1116
Good Morning James
Congratulations , you got the target
cool node, very useful
have a nice day
al
Ps-Peeking on Grasshopper you'll see that there
are, many other nodes to be able to create
or adapt with macro, good work
7777.1117
Hello Finema and Friends
Sorry, I double checked and inside the folder
the nod file was missing
now everything is OK, at least I hope
file at this link:
http://www.mediafire.com/file/lst3pvtl7seesgd/M_Helix.M_mradiiTube.zip/file
sorry again
al
7777.1118 In reply to 7777.1117
yes, it's great :)
7777.1119
Hi Friends
this macro M-HelixfromRef.Curve , completes the Helix tool,
taking a cue from Catia, where this utility is Default,
I thought it could be a great help for the Users to have this tool.
Starting from a reference curve, lying on the plane
xz, with starting point on the x-axis of any height and shape ,
the macro returns the helix whose limit is the curve
of reference...
In the posted example there are some Ref.Curves, just enough
give run
how many interested people find the file at this link:
http://www.mediafire.com/file/qabtdpn99zmj2pl/DM_Helix_from_Ref_Curve.zip/file
Good work everyone
al
7777.1120
Hi All,
Here is an exercise, showing localised distortion of point array from a point at the origin.
EDITED: 14 May 2019 by JFH
7777.1121
Good morning James
your distorsion node is a Gift ...
mathematically very inspired.....
beautiful in its essence .....
Compliments
Have a nice day my friend
al
7777.1122 In reply to 7777.1121
Hi Al,
Thanks for the compliment, but to be honest I could do with your help.
I have been trying to introduce multiply points for repulsion, without success.
Although my method worked well for my intents, it is not extendable
(at least, not as far as I can see).
If you are looking for a project, perhaps you could turn your masterful skill toward this.
7777.1123
Hello James and Friends
I took your words to the letter, I did some small manipulation
to your node and I used the Wire as a starting point to sketch this
Construction ... a pretty original Dome I would say ....
James , your Remap macro , will be very useful -
file at this link;
http://www.mediafire.com/file/rxqxfwcfdyo3xga/DomeDistorsion.zip/file
Good evening
al
7777.1124 In reply to 7777.1123
Good Morning Alberto,
>> a pretty original Dome I would say .... <<
Yes, your architectonic reworking of my distorted field was a delight to wake up to. Great work.
However, the distribution of isoCurves around point of repulsion would, in my original, give a less elegant curvature... in fact, plugging the remapped array into z input of pointExt results in a plateaued form which accords with the isoCurves. It is not as pleasing as your form, but allows the localisation manipulation.(ie ZONE widget) see below:
Rather than upload revised .nod file here, I replaced the one attached to my earlier post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1120
It can be switched between 2d & 3d with red switch node.
To make it bulge in a hemispherical form will require some added formula applied to the x and y as well as the z components. Nevertheless at this stage my interest is more, in having the 2D field distorted at multiple points (ie 2 or more points of repulsion). I don't know if that was clear in my last post. (or this one for that matter) This video will clarify: https://www.youtube.com/watch?v=PY4Byucrcpw
>> Remap macro , will be very useful <<
Yes, so useful in fact, that I believe, it should be part of the core toolkit: ie a node, or even better an option of an enhanced ReMap node that include this, as well as remapping of points as exists in Karsten's node and ideally remapping of surfaces (retopologizing).
Anyway, thank you for your inspirational work.
I look forward, as always, to your next creation
EDITED: 25 Jun 2018 by JFH
7777.1125 In reply to 7777.1124
Hello James, Hello Al,
it's a pleasure to see your works. At the Moment i'm working on the projection node, which can be also used for evaluating the shortest distance of a Point to a curve. So you have to have some patience until I think about a remap/rescale.
Have a nice day
Karsten
Message 7777.1126 deleted 26 Jun 2018 by JFH
7777.1127
Hi Karsten
Thanks in advance for your contributions
"Illuminants"
look forward
Good evening
alberto
7777.1128 In reply to 7777.1127
"Hello - is it this you looking for - I can see it in your eyes - I can see it in your smile ..."
Not direct the closest distance, but more general. It is the project curve factory and it works also for points to curves. Please test and study. The direction mode takes the x-axis of the frame input. For closestpt it is not necessary.
        function Project()
	this.addInput("Objects","objectlist");
        this.addInput("Target","objectlist");
	this.addInput("Frame","pointarray");
	this.properties = {ProjectMode:["closestpt","closestpt","direction"]};
Project.title = "Project";
Project.desc = "Project";
Project.prototype.onExecute = function()
        var obj = this.getInputData(0, moi.geometryDatabase.createObjectList());
        var target = this.getInputData(1, moi.geometryDatabase.createObjectList());
        var f = this.getInputData(2, new pointArray(true));
        var output = moi.geometryDatabase.createObjectList();
	//0 Object
	//1 Objects
	//2 projectmode
	//3 basePt
	//4 TargetPt
	//5 delete inputs
	//6 plane
	//7
	var frame = f.getFrame();
	var pFac= moi.command.createFactory( 'project' );
	pFac.setInput( 0, obj );
	pFac.setInput( 1, target );
	pFac.setDefaultDirection();
	pFac.setInput( 2,this.properties.ProjectMode[0] );
	pFac.setInput( 3, frame.origin );
	pFac.setInput(4,frame.evaluate( 1, 0, 0 ) );
	pFac.update();
        output = pFac.calculate();
	pFac.cancel();
LiteGraph.registerNodeType("Construct2/Project", Project);
A nice day to all
Karsten
7777.1129 In reply to 7777.1128
Hi Karsten,
Well there was hardly any time for impatience, you've done it....and it is just perfect.
Brilliant stuff as always
PS This is an application where reMapRange is useful: allowing greater controls of min/max radii and extrude height.
Size: 46.5 KB, Downloaded: 73 times, Dimensions: 480x469px
Show messages:  1-9  …  1050-1069  1070-1089  1090-1109  1110-1129  1130-1149  1150-1169  1170-1189  …  1850-1859
