 1-3  …  1044-1063  1064-1083  1084-1103  1104-1123  1124-1143  …  1844-1859
7777.1084 In reply to 7777.1083
AMAZING! YOU'RE A MASTER!!
7777.1085 In reply to 7777.1081
Hello Michael,
the problem was that the network factory need curves that are already added to the database - otherwise the factory shows this in the crash report:
.\Init.cpp 501: Moi starting up
Current command = none, Version = Sep-18-2014
7 network V1
5
22 objectlist 8 U curves0
22 objectlist 8 V curves0
21 string 4 Mode6 normal
49 double 16 Custom tolerance3f847ae147ae147b (0.01)
27 int 18 Uniform Num Points10
It reminds me to the 'removeduplicates' factory.
Now I can fix some other problems:-)
Many thanks and
have a nice day
Karsten
p.s.:
@ James - Is railrevolve already distributed?
function RailRevolve()
	this.addInput("Profile","objectlist");
        this.addInput("Rail","objectlist");
	this.addInput("Frame","pointarray");
	this.addOutput("Out","objectlist");
	this.properties = { mode:[/*"Union","Union"*/"Long","Long","Short"], cap_ends:["On","On","Off"]};
RailRevolve.title = "RailRevolve";
RailRevolve.desc = "RailRevolve";
RailRevolve.prototype.onExecute = function()
		var data = this.processInOut(this.properties.mode[0], this.multiProcess,null, null, null );
		this.setOutputData(0, data.outputs[0]);
RailRevolve.prototype.multiProcess = function(prof,rail, f)
	var frame = f.getFrame();
	return [factory ('railrevolve', prof.item(0),rail.item(0), frame.origin, frame.evaluate( 0, 0, 1 ), this.properties.cap_ends[0] === "On")];
LiteGraph.registerNodeType("Construct2/RailRevolve", RailRevolve);
7777.1086
Hello James,
very untested - only some standard test:
function network()
        this.addInput("In", "objectlist");
        this.addOutput("Out", "objectlist");
        this.properties = { mode: ["normal", "normal","lighter", "exact","custom","uniform"], tolerance: [0.01], numPts: [10]};
    network.title = "network";
    network.desc = "network";
    network.prototype.onExecute = function ()
        var inObj = this.getInputData(0, moi.geometryDatabase.createObjectList());
        var output = moi.geometryDatabase.createObjectList();
        var temp = moi.geometryDatabase.createObjectList();
   if (inObj.length > 3) {
            var tempname=getUID(6);
        for(var i=0;i<inObj.length;i++){temp.addObject(inObj.item(i));temp.item(i).name=tempname;};
            moi.geometryDatabase.addObjects(temp);
            var nFac = moi.command.createFactory( 'network');
            nFac.setInput(0, temp);
	   	if ( ! nFac.canDoCoonsPatch && this.properties.mode[0]=== "exact" ){moi.ui.alert("Network option exact not possible! switch back to normal ");this.properties.mode[0]="normal";};
	    nFac.disableUpdate( true );
            nFac.setInput(4,  this.properties.mode[0]);
//            nFac.setInput(4, 'normal');
            nFac.setInput(5, this.properties.tolerance[0]);
            nFac.setInput(6, this.properties.numPts[0]);
//            nFac.update();
            output = nFac.calculate();
//            nFac.commit();
            nFac.cancel();
        moi.geometryDatabase.selectNamed(tempname);
        temp=moi.geometryDatabase.getSelectedObjects();
        var delfac = moi.command.createFactory( 'delete' );
	delfac.setInput( 0, temp );
	delfac.commit();
           this.setOutputData(0, output);
LiteGraph.registerNodeType("Construct2/Network", network);
Please make some experiments and report me about.
A nice day to all
Karsten
EDITED: 14 Jun 2018 by KMRQUS
7777.1087 In reply to 7777.1085
Hi Karsten,
I'm glad you found the problem! This issue of not being able to use "loose" objects that are not in the database with an async factory should be solved in v4. The problem was that previously a newly created object was not assigned a unique id value until it was added to the geometry database, while in v4 this happens right when objects are created.
7777.1088 In reply to 7777.1087
Hello Michael,
thank You for the explanation - now it's making sense to me. And the change in V4 can simplify the code and avoid some workarounds with naming. Top!!!
Karsten
7777.1089 In reply to 7777.1086
Hi Karsten,
What a delightful & unexpected gift to wake up to...and not only that but a bonus node.
I've gone back to my gyroid experiments and replaced the imported element with a base surface
wholly constructed in NE via network node. Works perfectly.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1075
I will continue to play around with it & rail revolve and report any issues.
Thanks again Karsten, you are a champion
7777.1090
Hi All
With new network node it is possible to distort a regular pattern to give it that 60's feel
so that when wrapped around an object there is no relationship between the distortion
and underlying topography. It is a bit of a silly experiment, but I think it hints at real
possibilities for graphic expression
EDITED: 14 May 2019 by JFH
7777.1091 In reply to 7777.1090
Hi James
It will be cool if we could choose and create the pattern (module) and the wrapped object out of Nodeeditor (not with code), just with MoI tools.
Thanks for your good job :)
7777.1092
Hi Friends
I pushed, I believe at the Elephant limit ....
which can handle around 2800 surfaces and smooth them
It is not a brainer ....
Very Very Very Stronge Program ..
In addition, I see that Karsten goes on with new tools
Network. Swept Rail etc. etc.
very, very good , what to say , beyound thath Thanks to those
who make it possible....
For those interested the file is this link :
http://www.mediafire.com/file/utau60u4m66ulel/SpiralLamelleInterwoven.zip/file
It is a Interwoven surface, quite complex
to test the true potential of the program
Happy weekend to everyone
al
7777.1093
Hi All,
Following on from my last post; attached is a .nod file for generating randomised distorted patterns.
4 example outputs below
UPDATED:
Could be used for creating stone paving, by replacing circles with spheres: See additional image below
PS Go easy with increasing intensity slider unless you want a punk pattern.
Size: 35.7 KB, Downloaded: 79 times, Dimensions: 640x477px
7777.1094 In reply to 7777.1093
AMAZING!!!! ...as usual!
Fantastic stuff for all "2D-workflow" related works!
Your creations are of superior quality and I think that they CAN'T be missed by anyone.
You should (if you want) put all your latest/best nodes into a public storage to be accessible by all Moi' guys, without searching (and losing) them here on the "maremagnun" of this forum.
Thanks a lot James!
7777.1095 In reply to 7777.1094
Hi Marco,
Thank you for your kind words. Funnily enough, I was inspired by your 2D workflow work when doing this .nod file. It is very clever the way you have used moi as a vector graphics tool like illustrator. It is something I intend to emulate more in the future. Anything to use Adobe's products less, the better.
As for an archive; I think it is a good idea, but probably best left until after NE is out of beta.
Thanks again
7777.1096 In reply to 7777.1095
Ciao James!
You're welcome. My words simply described the reality. Your work on NE is EXCELLENT!!
(and the experiments of the user "speedy - AL2000")
And about 2D workflow....yeah! I always wanted to find suitable and streamlined ways to use Moi for that kind of purposes, because I wanted to join together the power of Moi's Nurbs with the power of product like Affinity Designer.
Unfortunately, or fortunately :), recently I really have not time at all to put again my hands on keyboard to continue the development of specialized scripts for "2d workflows".
I have many ideas, so many, but not time to develop.
So, your contribution with your nodes is very precious.
Max did a PRICELESS JOB, a "monster" tool, a "milestone" for Moi. but unfortunately, IMHO, the unique real problem is that NE is still a "too fragmented" product, very powerful, but still young.
With the BIG problem of a "scattered" documentation and knowledge base.
And it seems that actually NE has also reached the limit that Moi can do, because Moi was not made to deal with these kind of use-case.
And this is particularly evident with all your latest nodes and also with the excellent nodes made by the user "speedy - AL2000".
Anyway...I really hope that Michael's will continue to improve the Mo's "2d tool set" in order to have an even better product to deal with "2d workflows"
Ciao and have a nice day!
7777.1097
Hi Friends
like children, it is too much happiness to have
this toy with which to finally
realize this cube with rounded corners ...
it's a Dream
file at this link:
http://www.mediafire.com/file/tatdt9fs9f7p1te/Rail_Revolve_Smooth_Cube.nod/file
great Karsten and James ....
thank you
Have a nice day to all
al
Message 7777.1098 deleted 14 May 2019 by JFH
7777.1099
Hi All,
I have returned to woven patterns. My earlier method was very complicated,
however with subsequent versions of NE, this has become quite rudimentary.
UPDATED: The .nod file needs cleaning up, but I will post soon
The .nod file is now attached. Be warned that geometry generation may take 40+ secs.
Hope it is worth it :)
Size: 84.7 KB, Downloaded: 83 times, Dimensions: 700x615px
7777.1100 In reply to 7777.1099
Hello James!
Today I'm going crazy at work :)
...please let me be a little bit ..."fool"
LOL :)
7777.1101 In reply to 7777.1099
Cool weaving James!
Remember the golden age of TopMod! (you can always use it! ; If you don't know try it! it's a true gem!
Maybe the more crazzy geometric prog! (made the French UI some years ago :)
https://www.viz.tamu.edu/faculty/ergun/research/topology/download.html
or more versions
https://code.google.com/archive/p/topmod/downloads
https://issuu.com/frenchy_pilou/docs/topmod : a little album of fun diversion:)
(an another free cool system of album ...of course some publicities...
EDITED: 19 Jun 2018 by PILOU
7777.1103 In reply to 7777.1102
Hello Pilou!
Topmod!! Great (unappreciated) tool.
...lot of nice memories :)
Show messages:  1-3  …  1024-1043  1044-1063  1064-1083  1084-1103  1104-1123  1124-1143  1144-1163  …  1844-1859
