 1-5  …  66-85  86-105  106-125  126-145  146-165  …  1846-1859
7777.106 In reply to 7777.105
Best wishes for all the Italian people to persevere, Marco!
7777.107 In reply to 7777.106
Heartfelt thanks Michael!
See you,
7777.108
Hi Michael and Friends
I endorse the words of Marco
Many thanks to all of you
al
7777.109
Hi Karsten and Friends
an exercise on use of new nodes
Index, Sel Pattern, Flow .....
I had to give up doing the Fillet and Blend
between the two tape forms,
The result was not stable ...
Flow works best with curved input
rather than surfaces
Good work everyone
best
al
Size: 277.4 KB, Downloaded: 172 times, Dimensions: 1920x1080px
7777.110 In reply to 7777.109
Hi AL,
I'm glad to see that you are doing many experiments with the PatternSelArray node.
I hope to find some free time in next few weeks to rewrite my (lost) boolean utility nodes for PointArray.
Best,
7777.111 In reply to 7777.109
Hello Al,
I'm testing also at the moment - here is an update of the structure:-)
I hope we will find a better solution for Fillet and blend some day!
Have a nice evening
Karsten
7777.112 In reply to 7777.109
Hi Al.
I am alway struck by how vast & sparse your wiring diagrams;
you must have one gigantic monitor (or possibly 2) :)
Anyway I find it very instructive to analyse your method.
So keep them coming...
Thank you....& I am glad to hear that you are OK,
but sorry to hear of the devastation to your town & community.
Karsten,
Thank you also for your new .nod file.
I have not had a chance to look at it yet.
FYI, while reworking Al's .nod file I discovered that your
brilliant Concat2 node has a small bug.
Concatenating objects, does not allow them to be joined.
The ouput dot is green rather than yellow.
I was forced to use Max's original Concat node which is fine,
but I thought you may like to know.
I have attached my version of Al's file below
(it of course, requires Al's .3dm file as well)
-James
EDITED: 14 May 2019 by JFH
7777.113 In reply to 7777.112
<< you must have one gigantic monitor (or possibly 2)
In general today a Latop + a Monitor! ;)
As Node's windows is a "flying windows" you can imagine how comfortable that is! :)
7777.114 In reply to 7777.112
Hello James,
thanks for reporting the bug. Is it right, that the bug comes up, when loading a node-file from disk and try to connect or rewire the output? In a continous session it seems, that all works fine?!
Anyway -I've made some changes and now i'm testing the node. If the result is positive, I will post an update.
Have a nice day
Karsten
p.s.: As mentioned - I didn't understand the functions of the nodeeditor at all.
7777.115 In reply to 7777.114
Hi Karsten,
>>Is it right, that the bug comes up, when loading a node-file from disk and try to connect or rewire the output?<<
I'm not sure. I could not repeat the error. I opened the .nod file and replaced concat with concat2 and it worked fine. Weird?>>Anyway -I've made some changes and now i'm testing the node. If the result is positive, I will post an update.<<
Great! What about offset node you mentioned earlier?
I appreciate all your nodes.
-James
7777.116
Hi Friends
You're right , James ... I'm pretty messy....
I hope in the future to improve ...
for the rest....... , thanks of your words and closeness
Karsten I saw your new definition
This weekend I will try to deepen
and see if there is news ... Meanwhile, thanks
Continuing with the tests of fillet on the tapes, which finally
I managed to do
I noticed a strange behavior ..
even if with the Nod. file save the file. 3dm
void in which I am working
and reopen all, the definition made before
no longer has the fillet made ...
This happens even if the only definition Node save,
and I open a new session and load the file Nod
Why.......
As regards Blend, between the two tapes ,
I tried, everything seemed ok , but ultimately without avail
I think there is still work to make
stable these two important features.
best
al
Size: 301.7 KB, Downloaded: 166 times, Dimensions: 1920x1080px
Size: 362.2 KB, Downloaded: 129 times, Dimensions: 1920x1080px
7777.117 In reply to 7777.115
Hello James, Hello Al,
@James: The problem is caused by the onAdded function in the Concat2 node. Reloading a nodefile with a Concat2 node, causes a setup of the output to the default type numarray. It seems that onAdded is responsible for creating new nodes and also for recreation from disk. If a wire exist in the nodefile, the nodeeditor seems not to check it again. But If you delete the wire a reconnection isn't possible for pointarray and Objectlists. I hope the workaround in the node will do the job.
@Al: Could you please post the problematic files with the Fillet node - Fillet is very experimental and I have to investigate where the problem is. I will have a look at it in the next week.
A nice weekend to all
Karsten
7777.118
Hi Karsten
here is the test file of fillet
I hope you will serve to understand the problem
Have a nice weekend
al
7777.119 In reply to 7777.118
Hello Al,
the problems seems to come up with the v.0.85. The edge names will be stored in the node file, but only the first element/edge name will be read back. I found a workaround by placing a leading number, so the node editor don't suppress the reading of the complete array of edge names. Please test the version in the attachements.
Have a nice weekend
Karsten
EDITED: 6 Mar 2019 by KMRQUS
7777.120
Hi Al et el,
I have been playing with patternSelect to generate radial forms.
See attached. It is best to delink extrude when when adjusting input dials
and then reconnecting. Otherwise it will hang for some time.
Hi, Marco
patternSelect is a brilliant node. It would be useful to an open/closed pulldown
so that when "closed" the indices prior to start were added to end of array.
The work around is not difficult, as in my .nod file; but the inclusion would be
productivity enhancement. Also, as I have suggested before, it would be useful
to have a num array input for pattern (it accepts 0s & 1s)
Keep on noding
-James
7777.121 In reply to 7777.120
Hi James,
> "...It would be useful to an open/closed pulldown...it would be useful to have a num array input for pattern..."
I hope to find soon some free time to put my fingers on PatternSelArry in order to work with num array.
See you,
7777.122 In reply to 7777.119
Hi Karsten
I replaced costruction 2 with your last
it seems to run better .....
File opening the output of the second Fillet
it does not work... ( picture-1)
I redid the connections, and it works , but creates
the surface Brep source ( why ?)( picture-2)
Saved, and reopened it's ok....... (picture-3)
I think which you , maybe I should spend a little more time
for the exact functioning of Node Fillet,
which it is really very important-
I saw the new Offset node
I hope functions ,
then we resend-
Good work..Great Karsten
best
al
Size: 246.6 KB, Downloaded: 137 times, Dimensions: 1920x1080px
Size: 279.8 KB, Downloaded: 155 times, Dimensions: 1920x1080px
Size: 264.9 KB, Downloaded: 131 times, Dimensions: 1920x1080px
7777.123
Hello Karsten
with input curve works well ,
with line does not work ......
to be rewritten ????
Or there is something in the connections that do not understand
have a nice day
al
Size: 247 KB, Downloaded: 141 times, Dimensions: 1920x1080px
7777.124 In reply to 7777.122
Hello Al,
thanks for the details. I had to change some internal things of the node to get it to run under that version. Sometimes I have to fight with some sideeffects and it is difficult to test all configurations, in which a node has to work. Some of the bugs took hours to understand them. Some nodes make problems again and again. Anyway ...
the surface Brep source ( why ?)( picture-2) >>> Did you cloned the BrepNameSubObjects? If you do that, both will have the same basename for naming the sub elements. That can cause the problem. You can change it manually or create a new one for that. Moi's API isn't made for that stuff, so it is difficult to create that functionallity. Otherwise I saw also some unselectable ghost-objects while using the node editor - not selectable - like display artefacts - with other nodes. Is this actual problem repeatable?
I saw the new Offset node ....
I forgot to delete the offset node - it isn't finished - it works only in a first step. The flip for the side isn't stable. For test purposes you can show -with the frame output - the decission of the offsetfacory where the offset is placed. Ok - for a flip I have to calculate a frame on the other side of the input. But for a line the point is lying on the curve - typically you decide it with a pointer, but in the node editor isn't any interaction;-) These are the problems ...
Have a nice day
Karsten
7777.125
Hello Friends
starts again week, continue the tests ....
a little exercise with input curves in Moi
and a little test SubD
best
al
Size: 287.8 KB, Downloaded: 172 times, Dimensions: 1920x1080px
Show messages:  1-5  …  46-65  66-85  86-105  106-125  126-145  146-165  166-185  …  1846-1859
