 1-8  …  989-1008  1009-1028  1029-1048  1049-1068  1069-1088  …  1849-1859
7777.1029 In reply to 7777.1026
Hi Finema,
>> error when i want to change the bottle. UNSUPPORTED POLYGON TYPE 15 << .
The issue is the indexing of the surfaces of the bottle.
I have updated my previous post with new nod file
& instructions
7777.1030 In reply to 7777.1029
Hi James
That don't work for me
Nothing happen when i modify the bottle or i have message error
I have change index , quit , reopen but no way
Thanks again for your time
EDITED: 1 Jun 2018 by FINEMA
7777.1031 In reply to 7777.1030
Finema, is the modified bottle named " bottle"?
7777.1032 In reply to 7777.1031
yes
i join the 3dm file with the new bottle
thanks
EDITED: 28 Jul 2018 by FINEMA
7777.1033 In reply to 7777.1032
It works with "surface index" switch set to 0
Did you read instruction on my earlier post?
7777.1034 In reply to 7777.1033
yes i've read it
but i've tested with 2 and 3
it works with 0
thanks a lot James , it's really usefull for me to design pattern on model !!!
7777.1035
Hi Finema
You can Replace the mFlow node that appears in red
with original Flow node, which you find under the Trasform Tool ( Max's Tool)
just make the connections in and out
with the other nodes, as well as for actual mFlow node ...
I hope I was clear, it's easy enough
Have a nice day
alberto
7777.1036 In reply to 7777.1035
Thanks Alberto
it's OK with Flow node now
This node is usefull but i need to draw the module and bottle myself on the scene.
Thanks a lot
7777.1037
Hi Finema
As in the example posted by James you can create the references ,
in this case the bottle and the form you want to apply, then
you have to create two nodes (get by name) and then connect them
to the rest of the nodes of my file, (eliminating the bottle and the form
built with only the nodes ...)
All clear .... I hope so
best
alberto
7777.1038 In reply to 7777.1037
Alberto,
yes it's clear but i don't know what i must exactly put the getbyname node
and also, what i must delete
I'm discovering node editor, sorry
7777.1039
Hi James
I carefully reviewed your last file, and I allowed myself to add
some steps to get a scaling on the faces for the Flow ...
I think it can be useful ---
file to this link:
http://www.mediafire.com/file/rx36d7931u1iuvu/bottleWrap4.nod/file
In any case, I have to ask you some questions;
1- why the progression for isocurve input starts from 0.0001 and not from 0 ....
2- the value 0.0001 is accepted, as ever, in some situations in which I tried to insert it, for other nodes, I could not, the value
it is not accepted .... it depends perhaps on some settings that I do not know .......
3- I saw that the added (info box) to the surface object of the flow,
then splitting the input of the value z, which means .....
grateful for your explanations
Have a nice day and good work
alberto
7777.1040
Hi Finema
a this link:
http://www.mediafire.com/file/kqm1csr5w6b2g0o/31-05-Bottle_SimPanelingTool.zip/file
new file with object referenced
and new Flow node
only run... Good Luck
alberto
7777.1041 In reply to 7777.1040
Thanks Alberto
it's Ok now
I would like to use a solid instead an half surface
7777.1042 In reply to 7777.1041
Thanks a lot James and Alberto
I know it's not as Paneling Tool Rhino but this node is usefull for my work
EDITED: 9 May 2020 by FINEMA
7777.1043 In reply to 7777.1039
Hi Alberto,
In answer to your questions 1& 2. It seems it is no longer necessary to commence progression with 0.001.
This a hang over from an earlier version of isoCrvs, as you can see in image below it now does it automatically,
so that's good to know.
Question 3..the info box node ascertains whether the idxSelected surface has a z dimension.
An output of 0.00 for bottle base translates as boolean false and hence breaking the circuit,
while and other dimension translates as true.
It works better with inclusion of blue nodes in attached
I have only just awoken, so I have not had a look at your file. I'll do that now,
I've had a look: Yes your added nodes could be useful, thanks for that
Have a great weekend
EDITED: 12 May 2019 by JFH
7777.1044 In reply to 7777.1043
Hi
Why the pattern isn't similar to the model (bottle)
See my screenshots
The pattern is not perfectly following the shape of the bottle.
Message 7777.1045 deleted 12 May 2019 by JFH
7777.1046 In reply to 7777.1045
OK
Thanks James :)
7777.1047 In reply to 7777.1046
Finema
The reason "pattern is not perfectly following the shape" is due to the fact that the bottle surface has been rebuilt. It fidelity of the bottle is significant, then there are work arounds. I'll get back to you
See if the attached works for you. Instead of rebuilding the bottle; it has been sliced/diced.
7777.1048 In reply to 7777.1047
It's perfect now !
the script running is slower but it's great !
thanks a lot
Show messages:  1-8  …  969-988  989-1008  1009-1028  1029-1048  1049-1068  1069-1088  1089-1108  …  1849-1859
