 1-12  …  973-992  993-1012  1013-1032  1033-1052  1053-1072  …  1853-1859
7777.1013
Hi James and Friends
First of all , the surfTria.nod ... James is really original ,
above all, the adaptation of polysurfs
to the target surface it's very cool....
I believe, however, that training can be simplified
of surfaces with a Macro (see file), as usual at this link:
http://www.mediafire.com/file/qezy7aq6qgbepb7/SimplifysurfTriaFlow.rar/file
have a nice day to all
alberto
P.S
also the file subsequently posted it's very very cool
compliments
7777.1014 In reply to 7777.1013
Hi Al,
I know my node file is a bit of a mess. It was the result of pure "ad hocery".
I was just playing around to see what unfolded. No plan.
I probably should have gone back and optimised the circuitry before posting.
Thank you for doing this. I look forward to seeing how you have approached it.
UPDATED:
P.S. I have just started to see what you have done. I could not help noticing,
once adding up the nodes inside the expanded macros, that you have
used more than twice as many nodes for a similar result. That is not a criticism;
I know that node reduction does not necessarily reduce the computation load on running,
and in the end it doesn't much matter how many nodes it takes, if lag time between
clicking "RUN" and the generation of geometry is reduced to a minimum.In the end,
really that is all that is important.
UPDATED:
On your prompting, I have now replaced surfTria.nod file in earlier post with simplified
version (Essentially it is the my same method encapsulated in a macro):
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1004
EDITED: 31 May 2018 by JFH
Message 7777.1015 deleted 12 May 2019 by JFH
7777.1016
Hi All,
Having mapped surfaces with hexagon based tiling patterns with "HexTesselation"macro,
I am investigating the manipulation of individual tiles. Below is an experiment along these lines.
UPDATED problem solved (new image & .nod file)
EDITED: 14 May 2019 by JFH
7777.1017
I saw your answer, and I checked the surfTria file again
adjusted by you ..
I must say that the macro ExTasselation does not respond in a timely manner
to the Row and Col inputs as well as the output exagon number
at this link:
http://www.mediafire.com/file/orqpc5jigc8lovh/M_ExGrid.zip/file
you will find the Macro that I have rectified, following
a method different from yours, but that presents an exact answer
between input data and output data ...
I did not have time to see the last files posted
I promise to do it as soon as possible
Have a nice day
alberto
7777.1018 In reply to 7777.1017
Thanks Al,
>> M_ExGrid <<.
I look forward to looking at what you have done.
If it could reduce the generation of geometry of apertureVari3.nod, for example, that would be brilliant.
I am just glad that NE is been given deserved attention again.
EDITED: 30 May 2018 by JFH
7777.1019
Hi All,
Attached is nod file for generating a collar with pattern transition.
As always, be aware that generation of geometry may take half a minute or so.
EDITED: 11 May 2019 by JFH
7777.1020 In reply to 7777.1019
Very interesting !
Do you think it's possible to create a nod to flow a module on a model ? (same as Paneling tool in Rhino)
module and model are create on my scene
At his time, i use Array and Flow command to do that but it's not flexible and parametric
see my example in screenshot
EDITED: 9 May 2020 by FINEMA
Message 7777.1021 deleted 12 May 2019 by JFH
7777.1022 In reply to 7777.1021
waoouu ! Great !
it's a good start !
i have tested with a knurl pattern but the result is not uniform, the modules are streched and overlap
thanks again
7777.1023
Hi Finema and friends
at this link:
http://www.mediafire.com/file/kqm1csr5w6b2g0o/31-05-Bottle_SimPanelingTool.zip/file
you will find the file, to adapt the object to the surface,
as you will see the approach is different from the amount that you have
posted James ... I think this also has its validity
Certainly it is not the paneling that can be achieved with
Paneling Tools- or Rhino's Morph Box (Grasshopper)
but it's always a good start for Moi-
You just have to open the file and then run it,
you will see different parameters, rows, columns, etc etc ...
change them to see how they work-
Have a nice day to all
alberto
7777.1024 In reply to 7777.1022
Hi Finema,
This is an alternative simpler approach:
Click RUN
If nothing happens, click "Surface Index" switch
The target surface should be index either 0 or 1.
In the event nothing still happens, try changing "const" node values to 2 & 3
& if you desire the bottle to be shown, click "switch" to reveal
for .3dm & .nod file see:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1043
EDITED: 1 Jun 2018 by JFH
7777.1025 In reply to 7777.1023
Hi Alberto,
How i can use it ?
Must i name object ?
Thanks a lot.
7777.1026 In reply to 7777.1024
Thanks a lot James
It's very good
But i have an error when i want to change the bottle.
UNSUPPORTED POLYGON TYPE 15
EDITED: 31 May 2018 by FINEMA
7777.1027
Hi Finema
you simply have to open the file
and run ... all the data is in the file, there are not any
referenced objects
best
al
7777.1028 In reply to 7777.1027
Al,
You don't join a 3dm file
I think some .js are missing in my node editor
mflowObj is red
thanks
7777.1029 In reply to 7777.1026
Hi Finema,
>> error when i want to change the bottle. UNSUPPORTED POLYGON TYPE 15 << .
The issue is the indexing of the surfaces of the bottle.
I have updated my previous post with new nod file
& instructions
7777.1030 In reply to 7777.1029
Hi James
That don't work for me
Nothing happen when i modify the bottle or i have message error
I have change index , quit , reopen but no way
Thanks again for your time
EDITED: 1 Jun 2018 by FINEMA
7777.1031 In reply to 7777.1030
Finema, is the modified bottle named " bottle"?
7777.1032 In reply to 7777.1031
yes
i join the 3dm file with the new bottle
thanks
EDITED: 28 Jul 2018 by FINEMA
Show messages:  1-12  …  953-972  973-992  993-1012  1013-1032  1033-1052  1053-1072  1073-1092  …  1853-1859
