 1  …  962-981  982-1001  1002-1021  1022-1041  1042-1061  …  1842-1859
7777.1002 In reply to 7777.1001
Hi Barry
Can you send me the .3dm file so that I may reproduce the error
and perhaps find a work around.
7777.1003 In reply to 7777.1002
Hi James,
I'm using the file I posted(http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.987)
Just added a sphere and trimmed it on it's seam to make a dome surface and named it S8.
From the photo you can see the tangled result of the dome and when S7 was next applied
you can see it is also wrong.
I noticed the surfaces spike to drawing origin.
Barry
Size: 79.2 KB, Downloaded: 139 times, Dimensions: 500x293px
7777.1004
Hi All,
I feel nodeeditor has been neglected, so this weekend I decided I would play around with it.
Below is an unintended result of that play.
The other attachments are also outcomes of the same nod circuit:" surfTria.nod".
Have a great weekend
EDITED: 14 May 2019 by JFH
Size: 116.9 KB, Downloaded: 97 times, Dimensions: 750x600px
7777.1005 In reply to 7777.1004
Hi
How it works ?
7777.1006 In reply to 7777.1005
Hi Finema,
>> How it work <<.
I doubt this will be satisfactory, but the short answer is as follows:
Set up nodes to create base surface tesselation of hexagons, each lofted to a centre point to make triangular tiles and flow to target surface.
The underlying hexagonal pattern is variable in row and column , While the triangles are height variable of ctr.
Hope this helps
EDITED: 27 May 2018 by JFH
7777.1007 In reply to 7777.339
Cool!
7777.1008
Some further development based on previous nod file
7777.1009 In reply to 7777.1008
Hi James
Can you share the 3dm file and the library used in your nod ?
Thanks a lot
7777.1010 In reply to 7777.1009
Hi Finema,
>> Can you share the 3dm file <<.
The nod file works on its own, without input curves or the like.>> .....and the library used in your nod ? <<.
I take it by "library" you mean my "Extensions" folder of node editor. Please find attached.
Also ensure that you are using Max's most recent NE: can be found here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.608
If you mean something else let me know.
Hope this helps
PS I update nod file in my previous post, which should generate quicker, albeit still approx 20 secs.
Message 7777.1011 deleted 14 May 2019 by JFH
7777.1012 In reply to 7777.1011
Thanks a lot James !
It's very interesting.
In fact, my goal is to find how mapping a pattern on an existing model with Nodeeditor.
7777.1013
Hi James and Friends
First of all , the surfTria.nod ... James is really original ,
above all, the adaptation of polysurfs
to the target surface it's very cool....
I believe, however, that training can be simplified
of surfaces with a Macro (see file), as usual at this link:
http://www.mediafire.com/file/qezy7aq6qgbepb7/SimplifysurfTriaFlow.rar/file
have a nice day to all
alberto
P.S
also the file subsequently posted it's very very cool
compliments
7777.1014 In reply to 7777.1013
Hi Al,
I know my node file is a bit of a mess. It was the result of pure "ad hocery".
I was just playing around to see what unfolded. No plan.
I probably should have gone back and optimised the circuitry before posting.
Thank you for doing this. I look forward to seeing how you have approached it.
UPDATED:
P.S. I have just started to see what you have done. I could not help noticing,
once adding up the nodes inside the expanded macros, that you have
used more than twice as many nodes for a similar result. That is not a criticism;
I know that node reduction does not necessarily reduce the computation load on running,
and in the end it doesn't much matter how many nodes it takes, if lag time between
clicking "RUN" and the generation of geometry is reduced to a minimum.In the end,
really that is all that is important.
UPDATED:
On your prompting, I have now replaced surfTria.nod file in earlier post with simplified
version (Essentially it is the my same method encapsulated in a macro):
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1004
EDITED: 31 May 2018 by JFH
Message 7777.1015 deleted 12 May 2019 by JFH
7777.1016
Hi All,
Having mapped surfaces with hexagon based tiling patterns with "HexTesselation"macro,
I am investigating the manipulation of individual tiles. Below is an experiment along these lines.
UPDATED problem solved (new image & .nod file)
7777.1017
I saw your answer, and I checked the surfTria file again
adjusted by you ..
I must say that the macro ExTasselation does not respond in a timely manner
to the Row and Col inputs as well as the output exagon number
at this link:
http://www.mediafire.com/file/orqpc5jigc8lovh/M_ExGrid.zip/file
you will find the Macro that I have rectified, following
a method different from yours, but that presents an exact answer
between input data and output data ...
I did not have time to see the last files posted
I promise to do it as soon as possible
Have a nice day
alberto
7777.1018 In reply to 7777.1017
Thanks Al,
>> M_ExGrid <<.
I look forward to looking at what you have done.
If it could reduce the generation of geometry of apertureVari3.nod, for example, that would be brilliant.
I am just glad that NE is been given deserved attention again.
EDITED: 30 May 2018 by JFH
7777.1019
Hi All,
Attached is nod file for generating a collar with pattern transition.
As always, be aware that generation of geometry may take half a minute or so.
EDITED: 11 May 2019 by JFH
7777.1020 In reply to 7777.1019
Very interesting !
Do you think it's possible to create a nod to flow a module on a model ? (same as Paneling tool in Rhino)
module and model are create on my scene
At his time, i use Array and Flow command to do that but it's not flexible and parametric
see my example in screenshot
EDITED: 9 May 2020 by FINEMA
Message 7777.1021 deleted 12 May 2019 by JFH
Show messages:  1  …  942-961  962-981  982-1001  1002-1021  1022-1041  1042-1061  1062-1081  …  1842-1859
