Pattern generator as guilloché
All  1-3  4-9
I suppose contextfree can do the same :)
http://www.contextfreeart.org/
But you must write ten lines by yourself! ;)
or this one
http://www.hypatiasoft.fr/Folder_KnotsBag/Pages_HTML/KnotsBag_A.html
and of course the last Nodes Editor of MOi! ELEPHANT!
(By Max Smirnov the mad scientist! ;)
Sorry here in French but...very graphic ! Array Circular
You can of course increase the number Max of repetitions! (here 100)
That I love is the ultima simplicty for infinite very complex results! :)
And you can take any thing :3D Point(s), 3D line(s), 3D curve(s), 3D surface(s), 3D volume(s)
EDITED: 14 Dec 2015 by PILOU
7776.5 In reply to 7776.4
Thank you, appreciate ...yes it's exactly the same level of eterations that I need, eccentro goes even further to take a tree out of it and link forms at the top of the tree and affect them with the array you need and also different options through the lines you need.
I will try all and will comeback with some results , wait and see....
Thank you so much.
Bob
7776.6 In reply to 7776.4
Hello Pilou,
http://www.amazon.de/Wenger-Schweizer-Offiziersmesser-Messer-Schatulle/dp/B000R0JDSI
I think we don't Need it anymore:-)
Kind regards
Karsten
7776.7 In reply to 7776.6
Indeed! :)
7776.8
Hello,
If you happen to use CorelDRAW:
http://www.oberonplace.com/products/securidesign/index.htm
It's $15 but it has a trial available to see if it is what you need. I've also found their Curveworks utility to be very useful in cleaning up outlines generated in MoI.
7776.9
Hello,
Also of interest is Inkscape's clone tiling function:
The instructions :
http://tavmjong.free.fr/INKSCAPE/MANUAL/html/Tiles.html
A basic tutorial :
https://www.youtube.com/watch?v=xPGF8rzVKHw
It supports the 17 types of symmetries and you can export to pdf then import into MoI.
Michel
Show messages: All  1-3  4-9
