Slicing at an angle
All  1-9  10-13
7775.10 In reply to 7775.9
Hi Chipp, yup just using 2D curves to boolean with instead of always building surfaces can definitely speed things up!
Internally the booleans will extrude that line into a cutting plane for you, and also it handles making the extruded plane to be a little larger than the base object automatically.
I had many times some failures with only boolean objects + line
Extruding this curve make the trick at any time! :)
7775.12 In reply to 7775.11
If you have a line that goes parallel to the x y or z axis lines, there can be multiple different directions for the automatic extrusion, and the view that you use to select the line in becomes significant.
Possibly that's what you ran into, but I can't be sure without seeing an example file.
7775.13 In reply to 7775.12
Sure, i will send you a file as soon this happen again! :)
Show messages: All  1-9  10-13
