fails difference boolean
All  1-9  10-13
777.10 In reply to 777.8
> Michael. I just reduced the torus to .99 and all worked OK!
Yup, that's another method - it works because it separates that torus seam edge from the other ones so they aren't in that "really closely overlapping" situation anymore.
777.11
Hi Michael. this is a pretty simple case, of course. But one that could benefit from a tool such as Rhino's "Adjust Surface Seam". Any plans for something like that?
jonah
777.12 In reply to 777.11
Hi Jonah, eventually I'd like to add that. I kind of need to find a place in the UI to stash some less frequently used but sometimes useful tools like that. One thing I've thought of is some kind of text menu that might be launchable from an object properties panel, that could hold maybe some "advanced" edit tools.
777.13
Hi all. Just to point out one potential problem - If you do use the scaling method to fix the problem, it would be better to scale a little bigger (1.001) than to scale smaller (.999). Because if you scale smaller you will create some very thin surfaces and edges that might cause problems later for a fillet and when exporting to mesh. The best solution is to fix the original profile circle as Michael mentioned, and then sweep a new toroidal object.
jonah
Show messages: All  1-9  10-13
