Flow a pattern on a non cylindrical surface
All  1-6  7-8
7762.7 In reply to 7762.5
Hi Finema, please post your 3DM model file and that will help me to be able to see if I can suggest anything else.
I guess the part that you don't like is that the objects shrink down when they're around the neck - that will be because the revolved surface tapers down and has a smaller length across it in those areas, so that will correspondingly make the shapes smaller as well.
Like Burr mentions you might try the "Rigid" option for Flow which only rotates objects instead of doing a texture-mapping like approach, or another possibility could be to use the "projective" mode for Flow rather than the regular texture-mapping type mode.
EDITED: 9 Dec 2015 by MICHAEL GIBSON
7762.8
Thanks Michael, thanks Burr
Projective is good but project only on the visible part....
Make a rigid flow on the half part of my model is the solution , i think...
Sorry i can't post any .3dm cause i'm not on my personal computer and i haven't MoI here, but this is only a revolve curve (rebuild) with a simple pattern.
Show messages: All  1-6  7-8
