BOM script
 1-14  15-34  35-41
7759.35 In reply to 7759.34
Yesterday I spent 4 hours testing her "final, absolutely perfect versions". :-) Then I gave up and wrote this post... :-(
7759.36 In reply to 7759.33
Hi MarK,
> Do you think the script could also assemble the parts according to dimensions (regardless of the
> orientation in the model) and round the dimensions to integers as I describe in the attached image?
It would help me understand better if you could make an example file with a small number of parts set up as you describe and an example of the desired output from that.
7759.37 In reply to 7759.36
Sending... Thank you very much. Marek
7759.38 In reply to 7759.37
Hi Marek, thanks for the example files. Can you please give the english translation of these column names in the .csv :
Dílec;materiál;množství;tl.;šíøka;délka
7759.39 In reply to 7759.38
OK, I'd probably rather use Moi terminology:
Dílec - Objects
Material - Styles
Množství - Quantity
Tloušťka - Thickness
šířka - Width
délka - Length
7759.40 In reply to 7759.33
Hi Marek, please try the attached version. It should list the dimensions from smallest to largest and round to whole numbers.
7759.41 In reply to 7759.40
Thank you very much! I will test it and let you know. Mark
Show messages:  1-14  15-34  35-41
