Which threads for information?
All  1-18  19-20
774.19 In reply to 774.18
Hi Pilou, the offset is created by a kind of "tracing" procedure that marches along the curve and displaces a point sampled from the curve by the given distance.
You can do it on a 3D curve, but the displacement direction will happen relative to a plane. It tends to be more predictable when you do it just on planar curves.
774.20 In reply to 774.17
Hi Brian, I don't really have any ideas on how to make it more logical...
I mean right now the basic procedure goes like this:
Step 1 - select a curve:
Step 2 - click on Construct / Offset to launch the offset command.
Step 3 - click a little distance away from the curve to create a parallel one going through the point where your mouse is at:
That's all that you do to create a basic parallel curve... It can get more complex if you want to tweak various options or work with more complex curves, but I can't really think how to get more logical steps than that for the simple basic case...
Is there anything that you can pinpoint here that doesn't seem logical?
Show messages: All  1-18  19-20
