Which threads for information?
All  1-15  16-20
774.16 In reply to 774.15
Hi Brian, just plain scaling does not do the same job except for special cases like a circle.
Here's an example (.3dm also attached):
There isn't any way just through scaling to create a parallel curve a constant distance away from that one, give it a try.
Here's another example:
Here you can see how the lines of the offset are of different proportions with one another. Scaling will not produce this result.
774.17 In reply to 774.16
Thanks Michael. It just seems that there is less "logicallity" in offset.
Well--maybe different illogicallity in both options??
774.18 In reply to 774.16
How are made the offset?
Seems easy in 2D but in 3D?
Extremities control the result for have a sort of perpandicular form between them?
EDITED: 22 Jul 2007 by PILOU
774.19 In reply to 774.18
Hi Pilou, the offset is created by a kind of "tracing" procedure that marches along the curve and displaces a point sampled from the curve by the given distance.
You can do it on a 3D curve, but the displacement direction will happen relative to a plane. It tends to be more predictable when you do it just on planar curves.
774.20 In reply to 774.17
Hi Brian, I don't really have any ideas on how to make it more logical...
I mean right now the basic procedure goes like this:
Step 1 - select a curve:
Step 2 - click on Construct / Offset to launch the offset command.
Step 3 - click a little distance away from the curve to create a parallel one going through the point where your mouse is at:
That's all that you do to create a basic parallel curve... It can get more complex if you want to tweak various options or work with more complex curves, but I can't really think how to get more logical steps than that for the simple basic case...
Is there anything that you can pinpoint here that doesn't seem logical?
Show messages: All  1-15  16-20
