Surface to solid help
7718.1
Hi Everyone
I am having great trouble getting this shape to become a solid, it was a solid before i started messing with it. Is there a method or script which can find the "hole" which prevents it from being made a solid by running the join surfaces command? I can get the original piece back but it would be nice to know how i get out of this problem as i seem to keep coming across it.
Matt
Size: 146.9 KB, Downloaded: 58 times, Dimensions: 512x451px
7718.2 In reply to 7718.1
Hi Matt, to see where the holes are, set up a shortcut key with the script shown here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6051.2
That will highlight any "naked edges" of the model - those are edges that only belong to one surface instead of being joined between 2 surfaces, those are the spots where there are holes in the model preventing it from being watertight.
7718.3 In reply to 7718.1
Hi Matt, so using that script you can find the area that's messed up and in this case you've got one surface that is basically duplicated in that area and sticking out over top of some of the neighboring ones overlapping on top of them. That kind of situation is harder to diagnose than just a regular hole. So that surface needs to be deleted and then there's a hole to be patched up. Once you run the script you can push the "Reset" button at the bottom of the viewport to zoom right to those selected naked edges, then zoom in here and select this face:
That's the one that's overlapping the other pieces - notice the "stippling" or "z-fighting" in the display which is a signal that there is overlapping surfaces happening:
After selecting it, delete it and then you'll be left with this 4 sided hole which you can fill with Network, then select the main part and the new Network surface and use Edit > Join to form a solid:
7718.4
Thanks micheal!!
Perfect explanation as always :-)
Matt
