Parametric design in MoI?
 1-16  …  857-876  877-896  897-912
7713.897 In reply to 7713.895
Is that it:
I used this piece of code for a short key:
script: if ( moi.majorVersionNumber == 3 ) { moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); } else if ( moi.majorVersionNumber == 4 ) { moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); }
Does the above code works by omitting the term "script:" ?
I think it does work with or without it!
EDITED: 6 May 2021 by DRILLBIT
7713.898 In reply to 7713.896
I took it from Pilou's page here: https://moiscript.weebly.com/install-elephant.html
7713.899
Is there a place in which people share their nodes? Or tutorials?
7713.900 In reply to 7713.897
Hi Psygorn,
> Is that it:
Yup, that is what it looks like when it's running. You can right click in there to start adding nodes.
7713.901 In reply to 7713.899
<< Is there a place in which people share their nodes? Or tutorials?
You can find tones here! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1
7713.902 In reply to 7713.901
Tanx PILOU :)
7713.903
Hello all,
Do we have Floor and ceiling functions in Math Node?
I mean this function: https://en.wikipedia.org/wiki/Floor_and_ceiling_functions
7713.904 In reply to 7713.903
Psygorn,
Type into math node as shown
7713.905 In reply to 7713.904
Hello James,
Thank you for your reply,
Could you help me here:
Why does it seem that the floor function doesn't work properly?
I don't think for the value of A = 117 it should display -1!
How can I get 1 for values of A from 0 to 180, and -1 for values of A from 181 to 360?
7713.906 In reply to 7713.905
try using the compare node.
Barry
EDITED: 6 Apr 2022 by BARRY-H
Size: 74.1 KB, Downloaded: 215 times, Dimensions: 400x259px
7713.907 In reply to 7713.905
Psygorn,
It is working properly...given that sin(117) / 2 = -0.34, the floor value will be -1
Firstly, if working with degrees use square brackets : sin[a] because they convert degrees to radians
used by trigonometric functions.
If you imagine a point revolving around a circle, at any point the sine of the angle: sin[a]
equals the y component / radius, so regardless of the radius the result will be 0 on the horizontal axis
and 1 & -1 at top & bottom of the vertical axis respectively, and the points in-between will give a result
ranging from -1 to 1
There is a lot of better explanation of trigonometric functions online, here is the wikipedia page:
https://en.wikipedia.org/wiki/Sine_and_cosine
EDITED: 6 Apr 2022 by JFH
7713.908 In reply to 7713.907
>> It IS working properly...given that sin(117) / 2 = -0.34, the floor value will be -1
Hello James, but I think sin(117) = 0.891 even calculator says that!
I assume the value of sin is not calculated in Degree? (I think it is in Rad)
How can I get 1 for values of A from 0 to 180, and -1 for values of A from 181 to 360? in Degrees.
for example I thought if I use : 1+( 2 * floor function of (sin (a)/2)) I could have 1 for 0<a<180 and -1 for 180 <a<360
.>>If you imagine a point revolving around a circle, at any point the sine of the angle: sin[a]
Luckily, I know about it! and I know if we imagine a circle and divide it by the largest horizontal segment (it's horizontal diameter) then "sin(an angle in the upper semicircle)" would be positive and "sin(an angle in the lower semicircle)" would be negative. :-)
I just don't know how to do it in Nodeeditor, How to turn all positive values of sin to 1 and negative ones to -1.
Edit: Dear James I always had struggle where t use RAD and where to use Degree!
EDITED: 6 Apr 2022 by DRILLBIT
7713.909 In reply to 7713.908
The javascript sin(angle) gives the correct result for angle in radians.
For 117 degrees, multiply by (PI/180) yields 2.042... radians. Javascript sin(2.042...) = .891..., which agrees with your calculator set to DEG.
James is correct, in that javascript sin(117) treats 117 as radians, NOT degrees.
Max is using square brackets [ ] for the trig. The math in Max's node is done using Javascript Math functions. Javascript version ES5, NOT ES6.
(I think sin() is the same as sin[] in the node (???))
7713.910 In reply to 7713.908
Google search often yields responses on stackoverflow, which can be helpful, (if understandable)
See last answer here:
https://stackoverflow.com/questions/13975745/the-fastest-way-to-get-current-quadrant-of-an-angle
The degree angle theta needs to be converted to radians, to use the Javascript Math.sin[radianAngle]. (Max removed the need to use Math. in front of sin)
if sin[theta*PI/180] >= 0 , then output is +1.
if sin[theta*PI/180] < 0 , then output is -1.
So compare does seem to be useful. The Sine provides similar benefit to using modulus of +/- angle. Javascript Modulus (%), of angle could be used instead of Sine...
EDITED: 6 Apr 2022 by BEMFARMER
7713.911 In reply to 7713.909
Thank you Brian,
Now, I got it!
7713.912 In reply to 7713.910
Thank you again, Brian,
Your explanation helped a lot!
I was able to solve the problem and here are the results:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10641.16
I would be happy to know your opinion about it! (I mean could I do it better?)
Show messages:  1-16  …  837-856  857-876  877-896  897-912
