Parametric design in MoI?
 1  …  842-861  862-881  882-901  902-912
7713.882 In reply to 7713.880
Hi Wayne,
> This is an error on the current version of the Node Editor that happens
> when pressing "Load" then "Cancel".
The fix will probably be to modify the code to check the return value from the moi.filesystem.getOpenFileName() function.
If it is an empty string it means the user pushed Cancel and it should not try to go forward with the load.
7713.883 In reply to 7713.880
Hi Wayne,
> This is an error on the current version of the Node Editor that happens when pressing "Load" then "Cancel".
I investigated this some more and it turns out that it is not a bug in the Node Editor, it is a bug in MoI's file dialog handling. The bug crept in with a change a couple of betas ago to remember the last used file dialog directory so the dialog will start out in that directory. It ends up returning that directory name when you cancel when it should be returning an empty string.
The node editor code is already checking for an empty string like it should.
I've got it fixed up for the next v4 beta, thanks for reporting it.
7713.884 In reply to 7713.883
Thank you Michael. I thought it was a Node Editor error and was attempting to fix it on my own with no luck. Was also looking into having the Node Editor prompt a save before exiting.
-w
7713.885 In reply to 7713.642
When I select the “Export” command there is no dialog or options to export as shown in your post.
7713.886 In reply to 7713.885
It's maybe for a MAC user ?
I have not also this...but my Macro is well exported... ;)
7713.887 In reply to 7713.754
I unzipped the Extensions.zip file into the [C:\...\AppData\Roaming\Moi\nodeeditor\nodes\extensions\]
It created another Extensions folder.
But how do I access these?
7713.888
Could someone suggest where I might start as a beginner with the Node Editor.
Website?
Forum Page?
Tim
7713.889 In reply to 7713.888
Hi Tim
http://moi3d.com/wiki/Nodeeditor
Some of the information is not up to date...So recent forum posts may be helpful for install.
Max's site has the latest version.
An it runs just fine on MoI4Beta.
EDITED: 6 Oct 2020 by BEMFARMER
7713.890 In reply to 7713.889
This looks like what I needed, Thanks so much.
Tim
7713.892 In reply to 7713.891
Hi PILOU,
What is the difference between your Elephant & Max's Node editor?
Are they the same?
Your website provides the latest version of it?
Or we should go to Max's webpage?
I get kind of confused what is VF what is VO? and which version works best on MOI V 4.0?
I am using Windows.
7713.893 In reply to 7713.892
Yes Elephant is the name of the Node Editor for Moi by Max Smirnov
It's it that i have on my site!
VO = Original English Version
VF = French Version of the Native Nodes of Elephant (but has also no native nodes but these no native are not translated)
All versions works fine with Moi.4.0
<< Or we should go to Max's webpage?
No Lastest version of Elephant is the Version modifyed by creators of nodes so many more nodes than original Elephant
and managed by James http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10
there you can download a zip NodeEditor !
But maybe Max will made soon a new version after the release of the who knows! :)
EDITED: 6 May 2021 by PILOU
7713.894 In reply to 7713.893
I ended up with an error!
I have downloaded "nodeeditor.zip" from: http://moi3d.com/forum/index.php?webtag=MOI&msg=9949.12 (Post number = 9949.12)
then I extracted the zip file into ...AppData\Roaming\Moi
and then I made a shortcut for it "Alt+N" and added : ​moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
but I ended up with an error!
What should I do?
EDITED: 6 May 2021 by DRILLBIT
7713.895 In reply to 7713.894
Hi Psygorn, that error means you've got some unusual text characters inserted into the shortcut key text. Maybe if you're preparing the text in a word processor that has styles and such applied to it that is carrying along some extra stuff. Try using a plain text editor or set the document type to be plain text.
7713.896 In reply to 7713.894
Did you get that text by selecting and copying from a web page? If so which page, maybe I can fix the page to not have fancy unicode control characters in what is supposed to be plain text for code.
Try this:
script:moi.ui.createDialog("moi://appdata/nodeeditor/index.html","resizeable,defaultWidth:680,defaultHeight:420",moi.ui.mainWindow);
7713.897 In reply to 7713.895
Is that it:
I used this piece of code for a short key:
script: if ( moi.majorVersionNumber == 3 ) { moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); } else if ( moi.majorVersionNumber == 4 ) { moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow ); }
Does the above code works by omitting the term "script:" ?
I think it does work with or without it!
7713.898 In reply to 7713.896
I took it from Pilou's page here: https://moiscript.weebly.com/install-elephant.html
7713.899
Is there a place in which people share their nodes? Or tutorials?
7713.900 In reply to 7713.897
Hi Psygorn,
> Is that it:
Yup, that is what it looks like when it's running. You can right click in there to start adding nodes.
7713.901 In reply to 7713.899
<< Is there a place in which people share their nodes? Or tutorials?
You can find tones here! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1
Show messages:  1  …  822-841  842-861  862-881  882-901  902-912
