Parametric design in MoI?
 1-14  …  835-854  855-874  875-894  895-912
7713.875 In reply to 7713.870
Max
I've been playing around with a customised colour scheme for NE.
Can you tell me if it is possible to have a node border in un-selected state,
similar to border in selected state?
Anyway, how are you going? We've missed you around here
7713.876 In reply to 7713.875
>>Can you tell me if it is possible to have a node border in un-selected state, similar to border in selected state?
Yes. You need to open main.js and replace this code
	if (selected)
		ctx.fillStyle = LiteGraph.NODE_SELECTION;
		ctx.roundRect(-1,no_title ? -1 : -title_height -1, size[0]+2, no_title ? (size[1]+2) : (size[1] + title_height+2), 6);
		ctx.fill();
		ctx.fillStyle = bgcolor || LiteGraph.NODE_DEFAULT_BGCOLOR;
with something like this
	ctx.fillStyle = (selected)?LiteGraph.NODE_SELECTION:LiteGraph.NODE_DEFAULT_COLOR;
	ctx.fill();
You can use any other color instead of LiteGraph.NODE_DEFAULT_COLOR
7713.877 In reply to 7713.876
Max
Thanks for getting back to me so promptly.
I had not expected it, as you have been very quiet of late.
Changed code as instructed, & it works!
So good to hear from you,
Thanks for your help
What would it take to get nodeeditor to compose music, or at least sound?
Does MoI have any sound output?
Have to check out Tone.js...
7713.879 In reply to 7713.878
Hi Brian, MoI does not itself have any sound generation and the web browser engine that is used for the UI does not have the multimedia layer enabled that I think would be needed for playing sounds or videos from HTML.
Probably your best bet would be to call moi.filesystem.shellExecute( 'other_program.exe' ); to execute a separate program that would make the sound.
7713.880
Support,
This is an error on the current version of the Node Editor that happens when pressing "Load" then "Cancel".
Thank you,
Wayne
EDITED: 17 Jan 2021 by WAYNEHILL5202
7713.881 In reply to 7713.880
line 149 for me ;)
7713.882 In reply to 7713.880
Hi Wayne,
The fix will probably be to modify the code to check the return value from the moi.filesystem.getOpenFileName() function.
If it is an empty string it means the user pushed Cancel and it should not try to go forward with the load.
7713.883 In reply to 7713.880
Hi Wayne,
I investigated this some more and it turns out that it is not a bug in the Node Editor, it is a bug in MoI's file dialog handling. The bug crept in with a change a couple of betas ago to remember the last used file dialog directory so the dialog will start out in that directory. It ends up returning that directory name when you cancel when it should be returning an empty string.
The node editor code is already checking for an empty string like it should.
I've got it fixed up for the next v4 beta, thanks for reporting it.
7713.884 In reply to 7713.883
Thank you Michael. I thought it was a Node Editor error and was attempting to fix it on my own with no luck. Was also looking into having the Node Editor prompt a save before exiting.
-w
7713.885 In reply to 7713.642
When I select the “Export” command there is no dialog or options to export as shown in your post.
7713.886 In reply to 7713.885
It's maybe for a MAC user ?
I have not also this...but my Macro is well exported... ;)
7713.887 In reply to 7713.754
I unzipped the Extensions.zip file into the [C:\...\AppData\Roaming\Moi\nodeeditor\nodes\extensions\]
It created another Extensions folder.
But how do I access these?
7713.888
Could someone suggest where I might start as a beginner with the Node Editor.
Website?
Forum Page?
Tim
7713.889 In reply to 7713.888
Hi Tim
http://moi3d.com/wiki/Nodeeditor
Some of the information is not up to date...So recent forum posts may be helpful for install.
Max's site has the latest version.
An it runs just fine on MoI4Beta.
EDITED: 6 Oct 2020 by BEMFARMER
7713.890 In reply to 7713.889
This looks like what I needed, Thanks so much.
Tim
7713.892 In reply to 7713.891
Hi PILOU,
What is the difference between your Elephant & Max's Node editor?
Are they the same?
Your website provides the latest version of it?
Or we should go to Max's webpage?
I get kind of confused what is VF what is VO? and which version works best on MOI V 4.0?
I am using Windows.
7713.893 In reply to 7713.892
Yes Elephant is the name of the Node Editor for Moi by Max Smirnov
It's it that i have on my site!
VO = Original English Version
VF = French Version of the Native Nodes of Elephant (but has also no native nodes but these no native are not translated)
All versions works fine with Moi.4.0
<< Or we should go to Max's webpage?
No Lastest version of Elephant is the Version modifyed by creators of nodes so many more nodes than original Elephant
and managed by James http://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10
there you can download a zip NodeEditor !
But maybe Max will made soon a new version after the release of the who knows! :)
EDITED: 6 May 2021 by PILOU
7713.894 In reply to 7713.893
I ended up with an error!
I have downloaded "nodeeditor.zip" from: http://moi3d.com/forum/index.php?webtag=MOI&msg=9949.12 (Post number = 9949.12)
then I extracted the zip file into ...AppData\Roaming\Moi
and then I made a shortcut for it "Alt+N" and added : ​moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
but I ended up with an error!
What should I do?
EDITED: 6 May 2021 by DRILLBIT
Show messages:  1-14  …  815-834  835-854  855-874  875-894  895-912
