Parametric design in MoI?
 1-15  …  796-815  816-835  836-855  856-875  876-895  896-912
7713.836 In reply to 7713.833
Hi Max,
>> I'll try to write this node today evening. Thank you for a good idea!
Did it turn out to be too hard?
I'm worried that I may have asked too much with my latter post and it made the task insurmountable.
If that is the case, please return to the minimum functionality of applying easing to a numArray as per http://moi3d.com/forum/messages.php?webtag=MOI&msg=7713.833
Thank you
EDITED: 12 Aug 2018 by JFH
7713.837 In reply to 7713.836
Hi James!
Sorry, I was in business trip last week :)
I wrote this node two weeks ago, but I need more time to make it work as I planned it.
In fact it's really hard. :)
You can use it, but I certainly will change it later.
EDITED: 7 Mar 2022 by SMIRNOV
7713.838 In reply to 7713.837
Thanks Max,
Remapper node is a brilliant start.
Please know that I am eternally grateful.
I'm sure you know full well what needs to be done for it to function correctly,
but by way of helping to clarify things I prepared the attached NE file.
At the moment the node only works within the range of input array.
So it first needs to remap the array to within new range.
The math to do this is very simple, as shown.
Ideally this functionality would be incorporated into the node.
In the event that no new range is input into the node,
the output array would remain within existing range.
I hope this accords with your intentions.
Have a great weekend
& thanks again
P.S. I know the remapping does not correlate perfectly with the curve,
(for instance a diagonal straight line does not result with no change to
array as expected), nevertheless it is still workable.
Although perfecting this is desirable, it is less urgent IMHO
than the remapping to new range as outlined above.
EDITED: 14 May 2019 by JFH
Message 7713.839 deleted 8 Aug 2020 by JFH
7713.840 In reply to 7713.839
Amazing stuff!!!
I said this so long ago but now I repeat it: "I think there's a Moi BEFORE Max's contribution and a Moi after Max's contribution"
Moi is the EXCELLENT, TOP-NOTCH, basement, and Max's stuff is what makes Moi jump to the NEXT level!!!!
7713.841 In reply to 7713.839
Hi James,
can you post the remapper nod I tried to repeat it but something not right.
Also I can't get the fillet node to work so not sure if I'm missing something.
Barry
7713.842 In reply to 7713.841
Hi Barry
The reason remapped.nod failed to work may have been due to not updating interface.js
The attached file needs to replace the existing version at:
C:\Users\<user name>\AppData\Roaming\Moi\nodeeditor\nodes\interface.js
Hope this helps
7713.843 In reply to 7713.842
Hi James,
works fine I had interp node where yours as progression node.
My Interface.js was Ok.
Ps with regards to my fillet issue can you post a simple example.
Many thanks
Barry.
7713.844 In reply to 7713.843
Hi Barry,
It will work with both means of creating a num series, but
it is necessary that the input range is identical.
I am hoping that Max's fixes this so any range can be input
thereby deprecating my reMapRange macro.
>> Fillet
Fillet is a bit different from most nodes in that it requires manual
interaction mid-process. Refer to Karsten's instructions here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.941
Hope this helps
Message 7713.845 deleted 21 Aug 2018 by JFH
Message 7713.846 deleted 15 Oct 2018 by JFH
7713.847
Is there a way to autocenter the canvas, or have a mini zoomed-out preview of the canvas? Not having a middle mouse button has made canvas interaction a bit difficult, it would also be nice to allow easy remap of those buttons (sorry if that is already a possibility) and using +/- for zoom would be great as well!
7713.848 In reply to 7713.847
Hi FDP
>> Is there a way to autocenter the canvas, or have a mini zoomed-out preview of the canvas? <<
2 finger double tap on trackpad will zoom to mid-range, however it does not center the canvas.
Max is aware of this and says he'll will revise for next version.
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.808
Hope this helps
7713.849 In reply to 7713.630
The editor is a plugin for MoI. MoI has a VERY ACTIVE community, with the owner/programmer answering any questions you have in the forum. It's hugely more easy to use than any other solids modelers and has one of the best if not the best NURBS to POLYS converter I've ever seen.
4 will be beta any day now, but you have to own 3 to be able to download it. It will probably take a year to go golden, so you're best off just purchasing 3 now.
It's a stunning app, perfect for solid design and concepts. IMO, one needs both a poly modeler AND a NURBS modeler (and a topology modeler). I still enjoy using both SketchUp and MoI and go between them often. I also really like 3D Coat for topology.
You won't go wrong trying MoI. It's that good.
https://discord.software/ https://downloader.vip/adobe-reader/ https://downloader.vip/itunes/
EDITED: 27 Sep 2018 by BIMALOY30
7713.850 In reply to 7713.837
Hi Max,
Remapper node: >> but I need more time to make it work ... it's really hard. :) <<
I found this website http://cubic-bezier.com/
& wondered if it might offer you some direction.
(http://cubic-bezier.com/cubic-bezier.js)
All the best
EDITED: 3 Oct 2018 by JFH
Size: 24.4 KB, Downloaded: 246 times, Dimensions: 640x385px
7713.851 In reply to 7713.850
Very interesting experiment...
Thanks James!
7713.852
Hi Max,
I have another small suggestion that would be a big improvement for NE.
At the moment all selected geometry, whether byName, byStyle or manually selected, ceases to be responsive to change, which generally is fine.
However there are cases where it would be beneficial if changes to selected geometry was reflected in NE in real time. One example is the use of attractor points: in this way interactivity could be achieved through direct manipulation of point on ground plane rather than abstracting the attractor as x & y slider inputs or to the dot on the Slider2d widget.
I'm proposing that the selection nodes are manually updated as the default setting but have the option of automatic updating at a given frequency (n times per sec) or alternatively if you prefer, at a given interval (in milliseconds).
I recognise that this will greatly increase the computational load, when set to Automatic; but it could be reduced by halting the data stream when there is no change (above a certain threshold), so that when there is no alteration to base geometry the computation load is similar to Manual setting.
Please let me know what you think
Image shows selected curve with control points on in red, & post-adjusted cPts & curve in Black. Ideally the 2 would be in accordance: which is to say, that adjustments to original cPts would be reflected in NE and hence the generated curve would correspond to the manually manipulated curve.
UPDATED:
PS Rather than have 2 options (manual & Automatic) it could simply be that the is just a "Freq/sec" field with 0 as the default setting, which would in essence, amount to the same thing.
EDITED: 11 Oct 2018 by JFH
Message 7713.853 deleted 20 Nov 2019 by JFH
7713.854 In reply to 7713.853
Hi James!
Sorry, I have no plans (and I have no time) to write any math or geometry nodes for NE this year.
I certainly will continue development of node editor (January or February, I don't know..)
7713.855 In reply to 7713.839
Could this be used for guitar curves like arch tops?
Show messages:  1-15  …  776-795  796-815  816-835  836-855  856-875  876-895  896-912
