Parametric design in MoI?
 1-15  …  776-795  796-815  816-835  836-855  856-875  …  896-912
7713.816 In reply to 7713.815
Hi James,
I didn't write a line of code since 1.0 rc3 release. Sorry, have no time at all.
>>I have a proposal for an extension to switch node
Good idea. I'll add it to Switch node.
7713.817 In reply to 7713.816
Hi Max,
Thanks for building this awesome tool!
I'm having a problem with node editor v 1.0 (rc3). It appears that Macros aren't working for me at all (either in MoI 3 or 4 beta). The following error pops up if I select Macro (the error looks identical in 3 and 4 beta, although I can only cut and paste the error in 4 beta):
Script error
TypeError: undefined is not an object (evaluating 'document.URL.split(/moi:\/\/appdata\/(.*\/).*/g)[1].replace')
moi://ui/nodeeditorv10rc3/core/main.js line 4404
4400: var entries = {};
4401: for(i=0; i<values.length; i++) { if ( values[i] ) entries[i] = { value: ">"+values[i], content: lang.getTranslation(values[i]), is_menu: false }; }
4402:
4403: var dir = (moi.filesystem.getAppDataDir)?moi.filesystem.getAppDataDir:moi.filesystem.getProcessDir;
4404: >> var path = dir()+document.URL.split(/moi:\/\/appdata\/(.*\/).*/g)[1].replace(/\//g,"\\")+"macros\\";
4405:
4406: if ( moi.filesystem.dirExists(path) )
4407: {
4408: var files = getFiles(path);
Any ideas on what I am doing wrong?
-FDP
7713.818 In reply to 7713.817
Hi FDP,
I'll check it this weekend. I have no idea at the moment.
7713.819 In reply to 7713.818
Hi Max,
Any chance to look into that error? I'm sorry to be bugging you with this - understand if you are super busy!
-FDP
7713.820 In reply to 7713.819
Hello FDP,
could you make a zip of your nodeeditor Folder and post it - maybe something is wrong with it. As a Workaround I would Switch back to an older Version. Worth a try.
Have a nice day
Karsten
7713.821 In reply to 7713.820
Thanks!
Attached the zip. This is from my: 'Program Files/MoI 4.0 beta Jun-6-2018/ui' folder (64bit).
7713.822 In reply to 7713.821
Hi FDP,
not sure if this is your problem but you are missing the basicfunctions.js
I have attached a copy that you need to put in the libs folder that is within the node extensions folder.
Hope this helps.
Barry
7713.823 In reply to 7713.821
Hello FDP,
it seems that an Installation und /ui/ Folder doesn't work. I think you have to install under appdata/Roaming/moi/.
Have a link to this post: http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.767
Maybe Max can help hopefully.
Have a nice day
Karsten
7713.824
Hi Max/Karsten & others who may be interested.
There is a component (widget) in grasshopper called "GraphMapper" that remaps a numerical array to values under a user defined curve. see below
I imagine that coding for such a node would be quite difficult, however I propose a more limited node that may be more achievable (below image)
In essence it would take a linear progression of number (say point distances from an attractor) and shift them to ease in and out.
Your thoughts?
P.S. a NE widget equivalent of GraphMapper would nevertheless still be the ideal... one day; See attached image below
EDITED: 24 Jul 2018 by JFH
Size: 70 KB, Downloaded: 230 times, Dimensions: 1254x458px
7713.825 In reply to 7713.824
The FrenetKTCurve script scans a curve for values of x and y.
7713.826
Hi James and Friends
it is strange and curious, as though distant miles of Kilometers
our thoughts are so close ....
Just a few days ago I thought about how it would be useful
to be able to insert something similar to Graph Mapper ...
of our beloved Grasshopper, in Elephant
For this purpose, I tried to use the available tools
to recreate something similar .......
The result I have to say was better than I thought ...
But it certainly would be very useful to be able to implement it
Our gurù (max and Karsten) have material to focus on
I'd say....
We hope for good news
the file and some images at this link:
http://www.mediafire.com/file/ots3p0n6dboq42w/-Similar_Graph_Mapper.zip/file
Have a nice day to all
al
Message 7713.827 deleted 28 Jul 2018 by JFH
7713.828
Hi All,
I have knocked up a simple macro for applying easing to a num array.
It achieves the result by physically emulating what graph mapper does with code,
by actually projected on to a user defined curve, not elegant but it works.
To see easing in action, I have included in my latest .nod file:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1182
EDITED: 14 May 2019 by JFH
7713.829 In reply to 7713.828
Hi All,
To better illustrate how easing macro works
please find attached animation.
In this example, the new array is input into x component of Point node,
but it could alternatively be circle/polygon radii, angles, star ratios etc.
See small image and multiEasing.nod attached
Size: 15.1 KB, Downloaded: 205 times, Dimensions: 480x563px
7713.830 In reply to 7713.818
Hi Max
I had a look in the nodeeditor directory to see if there was a css file that I may alter so that the nodes showed input and output colours by default rather than only when being connected to. I believe it would be better if the nodes communicated what they "needed" from the outset. (perhaps when they were being connected to, they could high-light in white? OR alternatively dot coloured from the outset & labels coloured only when being connected)
Also in most cases it seems redundant to label outputs, but even more so, if they are coloured.
Maybe you are not in agreement with this proposal, but please give it some consideration.
Have a great weekend
PS I found css stuff, in index.html. I'll see if I can modify.
EDITED: 30 Jul 2018 by JFH
Size: 25.5 KB, Downloaded: 357 times, Dimensions: 300x544px
7713.831 In reply to 7713.830
Hi James,
you can't change it with css.
NE have a hidden feature which highlights inputs and outputs titles. Alt+Left click on Info button (left upper corner).
In the next version I'll add an ability to switch it using a color scheme settings (colors.js)
I need to think about it. We can't hide all output titles.
UPD:
http://moi.maxsm.net/files/nodeeditor/ne.colored.dots.and.titles.zip
1. replace colors.js and main.js with this files
2. set "io_text_highlight" and "io_highlight" parameters in colors.js
EDITED: 29 Jul 2018 by SMIRNOV
7713.832 In reply to 7713.831
Hi Max,
Thanks for getting back to me, & thanks for the update: it's perfect! Great Stuff.
>> 2. set "io_text_highlight" and "io_highlight" parameters in colors.js <<.
I think it is best with "io_text_highlight" set to "false"
Did you happen to see my earlier post regarding a graphical num array re-mapper:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.824
Is this something that would be capable to achieve in canvas?
I do think it would have wide ranging application.
But I don't want you to think I am not satisfied with your recent update;
I could not be more grateful
Thank you
P.S. Some thoughts on Remapper widget:
By input a new range as well as the array to be remapped will increase widgets utility, so curve may be a straight line if all that is desired is to remap an array to within new range with easing; replacing my macro:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1114
EDITED: 29 Jul 2018 by JFH
7713.833 In reply to 7713.832
Hi James,
In my opinion it looks better with both "io_text_highlight" and "io_highlight" switched off :)
I'll try to write this node today evening. Thank you for a good idea!
EDITED: 7 Mar 2022 by SMIRNOV
7713.834 In reply to 7713.833
Hi Max,
Wow, this is exciting, Thank you so much...I can't wait.
>> Some...[MORE]...thoughts on Remapper widget
Grasshopper's Graph mapper has 10+ curve types, however several would have limited application.
Instead of emulating their approach, it would IMHO be better to have an anchor point at each end
and a pulldown menu in info panel for the number of control points (0,1,2,3 or 4). In that way, 0 control
points would give a linear remapping of numArray to new range and 1 or 2 control points provide easing.
3 or 4 control points could be used for defining geometry: say you have a linear progression (0,1,2,3,4,5)
wired into z input of Point node (x=0, y=0), as well as into Remapper node with curve as shown below.
The new series output is wired into radius input of Circle node & the Point node is wired into the Center input.
Loft the circles and you have a parametrically defined lathed form. This is a very simple example, but
imagine if multiple Remapper nodes were used together, say affecting rails and profiles of sweeps & rail-revolves,
or multiple curves Lofted or Networked to surfaces.
I imagine you are too far down the track for taking on suggestions, and if the new node allows num array
remapping by S-curve only, it will still be a huge advance for NE
I look forward to seeing what you have done
P.S.
For future releases, then, have them both set to false and I will reset "io_highlight" to true myself.
EDITED: 31 Jul 2018 by JFH
7713.835
Max , James and Friend
reconnect to the Graph Mapper or Remapper , or speech in any
another way we want to call it,
I unlike James, I would leave some types of curves by default :
Linear
Bezier
Sine
Cosine
Cubic
CatmulRom
and , add a Free Curve with n ° (to be defined) pt ... that govern the curve;
I believe that this way, I will be a more flexible instrument ..._
In addition, I would also like to explore the possibility of improving the tool
2D Slider, also including the possibility of multi-input
so that it becomes a sort of viewer of the curve to be obtained,
without having to pedanticly add more Slider2d ...
What do you think ?
In any case, however you decide, it will be a substantial improvement
good work
al
Show messages:  1-15  …  756-775  776-795  796-815  816-835  836-855  856-875  876-895  896-912
