Parametric design in MoI?
 1-8  …  769-788  789-808  809-828  829-848  849-868  …  909-912
7713.809
nodeeditor.v.1.0.rc3 (I hope this one will be last before v1.0 release)
http://moi.maxsm.net/files/nodeeditor/nodeeditor.v.1.0.rc3.2018.03.09.zip
Fixed a couple of bugs.
Also I clean all waste from NE files.
Updated translation file.
Pilou, I removed french translations of all obsolete and unofficial nodes. Later I will help you to make an extension for unofficial nodes.
Right now I need your help with translation. Could you check an attached file, and add translations for all words marked with "?"
EDITED: 7 Mar 2022 by SMIRNOV
7713.810 In reply to 7713.809
sure! ;)
My Moi French Site My Gallery
7713.811 In reply to 7713.809
Hi Max.
This version works with V4 only or also with V3 ?
Thank you very much :)
7713.812 In reply to 7713.809
Done ;)
Of course must be tested in action! :)
(i change the name of the file for avoid some erase on my rustic Web site)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/nodeeditortranslation_fr1_10_03_2018.xlsx
Some Lines are empty in column D ?
EDITED: 9 Mar 2018 by PILOU
7713.813
Marco,
I forgot to test this version with V3, but it should work fine.
Frenchy Pilou
Thank you!
You may leave it empty when French and English words are same.
7713.814 In reply to 7713.813
@You : "...I forgot to test this version with V3, but it should work fine..."
Ok! Thanks.
7713.815 In reply to 7713.809
Hi Max,
How are you going with finalisation of NE v1.0 release?
I have a proposal for an extension to switch node
that you might consider including.
It is pretty self explanatory; allowing branching between 2 paths.
& would be useful for checking outputs and readings at various
critical points for debugging purposes.
I know that there is a work around with split + 0-1 knob,
or alternatively, split + switch + 2x const, but they're cumbersome.
All the best,
Keep up the good work
EDITED: 31 May 2018 by JFH
7713.816 In reply to 7713.815
Hi James,
I didn't write a line of code since 1.0 rc3 release. Sorry, have no time at all.
Good idea. I'll add it to Switch node.
7713.817 In reply to 7713.816
Hi Max,
Thanks for building this awesome tool!
I'm having a problem with node editor v 1.0 (rc3). It appears that Macros aren't working for me at all (either in MoI 3 or 4 beta). The following error pops up if I select Macro (the error looks identical in 3 and 4 beta, although I can only cut and paste the error in 4 beta):
Script error
TypeError: undefined is not an object (evaluating 'document.URL.split(/moi:\/\/appdata\/(.*\/).*/g)[1].replace')
moi://ui/nodeeditorv10rc3/core/main.js line 4404
4400: var entries = {};
4401: for(i=0; i<values.length; i++) { if ( values[i] ) entries[i] = { value: ">"+values[i], content: lang.getTranslation(values[i]), is_menu: false }; }
4402:
4403: var dir = (moi.filesystem.getAppDataDir)?moi.filesystem.getAppDataDir:moi.filesystem.getProcessDir;
4404: >> var path = dir()+document.URL.split(/moi:\/\/appdata\/(.*\/).*/g)[1].replace(/\//g,"\\")+"macros\\";
4405:
4406: if ( moi.filesystem.dirExists(path) )
4407: {
4408: var files = getFiles(path);
Any ideas on what I am doing wrong?
-FDP
7713.818 In reply to 7713.817
Hi FDP,
I'll check it this weekend. I have no idea at the moment.
7713.819 In reply to 7713.818
Hi Max,
Any chance to look into that error? I'm sorry to be bugging you with this - understand if you are super busy!
-FDP
7713.820 In reply to 7713.819
Hello FDP,
could you make a zip of your nodeeditor Folder and post it - maybe something is wrong with it. As a Workaround I would Switch back to an older Version. Worth a try.
Have a nice day
Karsten
7713.821 In reply to 7713.820
Thanks!
Attached the zip. This is from my: 'Program Files/MoI 4.0 beta Jun-6-2018/ui' folder (64bit).
7713.822 In reply to 7713.821
Hi FDP,
not sure if this is your problem but you are missing the basicfunctions.js
I have attached a copy that you need to put in the libs folder that is within the node extensions folder.
Hope this helps.
Barry
7713.823 In reply to 7713.821
Hello FDP,
it seems that an Installation und /ui/ Folder doesn't work. I think you have to install under appdata/Roaming/moi/.
Have a link to this post: http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.767
Maybe Max can help hopefully.
Have a nice day
Karsten
7713.824
Hi Max/Karsten & others who may be interested.
There is a component (widget) in grasshopper called "GraphMapper" that remaps a numerical array to values under a user defined curve. see below
I imagine that coding for such a node would be quite difficult, however I propose a more limited node that may be more achievable (below image)
In essence it would take a linear progression of number (say point distances from an attractor) and shift them to ease in and out.
Your thoughts?
P.S. a NE widget equivalent of GraphMapper would nevertheless still be the ideal... one day; See attached image below
EDITED: 24 Jul 2018 by JFH
Size: 70 KB, Downloaded: 230 times, Dimensions: 1254x458px
7713.825 In reply to 7713.824
The FrenetKTCurve script scans a curve for values of x and y.
7713.826
Hi James and Friends
it is strange and curious, as though distant miles of Kilometers
our thoughts are so close ....
Just a few days ago I thought about how it would be useful
to be able to insert something similar to Graph Mapper ...
of our beloved Grasshopper, in Elephant
For this purpose, I tried to use the available tools
to recreate something similar .......
The result I have to say was better than I thought ...
But it certainly would be very useful to be able to implement it
Our gurĂ¹ (max and Karsten) have material to focus on
I'd say....
We hope for good news
the file and some images at this link:
http://www.mediafire.com/file/ots3p0n6dboq42w/-Similar_Graph_Mapper.zip/file
Have a nice day to all
al
Message 7713.827 deleted 28 Jul 2018 by JFH
7713.828
Hi All,
I have knocked up a simple macro for applying easing to a num array.
It achieves the result by physically emulating what graph mapper does with code,
by actually projected on to a user defined curve, not elegant but it works.
To see easing in action, I have included in my latest .nod file:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7777.1182
EDITED: 14 May 2019 by JFH
Show messages:  1-8  …  749-768  769-788  789-808  809-828  829-848  849-868  869-888  …  909-912
