Parametric design in MoI?
 1-15  …  756-775  776-795  796-815  816-835  836-855  …  896-912
7713.796 In reply to 7713.793
Great stuff Max,
Zoom functions much better now with trackpad.
Thanks for your continued development
P.S. Double tap to zoom to extents is the last piece in the puzzle
EDITED: 9 Feb 2018 by JFH
7713.797 In reply to 7713.796
Hi James,
As Michael wrote above, he will add a trackpad gestures support to the next MoI beta.
Then I'll add pinch/zoom, two-finger scroll, double tap gestures to Nodeeditor.
7713.798
Hi Max,
I'm getting this type of display on my Surface Pro 4 of latest nodeeditor.
I don't think this is correct and maybe a resolution issue ?
Barry
7713.799 In reply to 7713.798
Hi Barry
Yes, it's HiDPI mode issue.
Yesterday I also noticed this bug when I run MoI v4+Win7 on my Mac using a virtualization software. So I can reproduce it.
In the same time it works good on Win10.
About the second button for the nodeeditor ?
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.794
My Moi French Site My Gallery
7713.801 In reply to 7713.800
press Alt button on keyboard and click on "New"/"Nouveau" button on screen (upper left corner of NE window)
7713.802 In reply to 7713.801
Perfect! Works like a charm!
Bravo!
7713.803 In reply to 7713.798
Hi Barry
I fixed this bug. Here is updated version: http://moi.maxsm.net/nodeeditor/nodeeditor.v.1.0.rc2b.2018.02.11.zip
About the "Second Window"
I am wrong or seems we can Open any number of new windows of the NE ?
7713.805
Another small update:
Added: mac trackpad gestures support
Added: macros directory (put often-used macros to this directory)
http://moi.maxsm.net/nodeeditor/nodeeditor.v.1.0.rc2c.2018.02.11.zip
EDITED: 7 Mar 2022 by SMIRNOV
7713.806 In reply to 7713.803
Hi Max,
thanks works great.
Barry
7713.807 In reply to 7713.805
Hi Max
Thank you for the update:
Pinching to zoom works just as it should! Great work.
However double finger, double tap does not "zoom to extents" as expected.
Rather it zooms to mid-size, but does not centre on the canvas.
Nevertheless it is a vast improvement
Thanks again
7713.808 In reply to 7713.807
Hi James
I'll change the double-tap zoom logic in the next release.
7713.809
nodeeditor.v.1.0.rc3 (I hope this one will be last before v1.0 release)
http://moi.maxsm.net/files/nodeeditor/nodeeditor.v.1.0.rc3.2018.03.09.zip
Fixed a couple of bugs.
Also I clean all waste from NE files.
Updated translation file.
Pilou, I removed french translations of all obsolete and unofficial nodes. Later I will help you to make an extension for unofficial nodes.
Right now I need your help with translation. Could you check an attached file, and add translations for all words marked with "?"
7713.810 In reply to 7713.809
sure! ;)
7713.811 In reply to 7713.809
Hi Max.
This version works with V4 only or also with V3 ?
Thank you very much :)
7713.812 In reply to 7713.809
Done ;)
Of course must be tested in action! :)
(i change the name of the file for avoid some erase on my rustic Web site)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/nodeeditortranslation_fr1_10_03_2018.xlsx
Some Lines are empty in column D ?
EDITED: 9 Mar 2018 by PILOU
7713.813
Marco,
I forgot to test this version with V3, but it should work fine.
Frenchy Pilou
Thank you!
You may leave it empty when French and English words are same.
7713.814 In reply to 7713.813
@You : "...I forgot to test this version with V3, but it should work fine..."
Ok! Thanks.
7713.815 In reply to 7713.809
Hi Max,
How are you going with finalisation of NE v1.0 release?
I have a proposal for an extension to switch node
that you might consider including.
It is pretty self explanatory; allowing branching between 2 paths.
& would be useful for checking outputs and readings at various
critical points for debugging purposes.
I know that there is a work around with split + 0-1 knob,
or alternatively, split + switch + 2x const, but they're cumbersome.
All the best,
Keep up the good work
EDITED: 31 May 2018 by JFH
Show messages:  1-15  …  736-755  756-775  776-795  796-815  816-835  836-855  856-875  …  896-912
