Parametric design in MoI?
 1-17  …  38-57  58-77  78-97  98-117  118-137  …  898-912
7713.78 In reply to 7713.77
EDITED: 5 Dec 2015 by BEMFARMER
7713.79 In reply to 7713.78
Have you an idea of the use of Node "Loft" ?
7713.80
Hi Karsten,
check this manual
http://moi.maxsm.net/api/#_CoordinateFrame
If you want to use frames as input data you can use this code:
function Line()
	this.addInput("Start","frame");
	this.addInput("End","frame");
	this.addOutput("Out","objectlist");
Line.title = "Line";
Line.desc = "Line";
Line.prototype.onExecute = function()
	var start = this.getInputData(0, moi.VectorMath.createFrame());
	var end = this.getInputData(1, moi.VectorMath.createFrame());
	var factory = moi.command.createFactory( 'line' );
	factory.setInput(0, start.origin);
	factory.setInput(1, end.origin);
	var output = factory.calculate();
	this.setOutputData(0, output);
	factory.cancel();
LiteGraph.registerNodeType("Factories/Line", Line);
but it will be better if you use points instead of frames
function Line()
	this.addInput("Start","point");
	this.addInput("End","point");
Line.desc = "Line";
	var start = this.getInputData(0, moi.VectorMath.createPoint());
	var end = this.getInputData(1, moi.VectorMath.createPoint());
	factory.setInput(0, start);
	factory.setInput(1, end);
	factory.cancel();
7713.81
Frenchy Pilou
EDITED: 7 Mar 2022 by SMIRNOV
7713.82 In reply to 7713.80
Hello Max,
thank You very much - I didn't know about ".origin" in the construct. But now everything makes sense.
Have a nice day
Karsten
7713.83 In reply to 7713.81
@ Max
Aaaaaaaaaaaaaaah! In all my trys I put "Loft" on start and not at the end! That was the trick! :)
Very cool that we can reload the entiere set of nodes!
That is parametric indeed! Bravo!
Just something curious all nodes titles are not translated !
I will investigate (i have not yet dowloaded your last version !)
EDITED: 4 Dec 2015 by PILOU
@Max
Even with your last version v 0.23Alpha
Reloading the "loft.nod" file don't make appear translated French Tittles of the Nodes!
Internal lines are translated!
So Little Glitch;
French version is present as you can see!
7713.85 In reply to 7713.84
It's not a glitch. When you create a node with English/French/Russian name it will be saved in a nod-file. When you load this file all names will be loaded as they stored.
7713.86 In reply to 7713.85
@Max
But this persists when I resave it from my "French" version! ;)
So I must rename first all titles that is some painfull! :)
Or there is a little trick ?
NOT A PRIORITY PROBLEM !!! :)
EDITED: 5 Dec 2015 by PILOU
7713.87
But why translate it
7713.88 In reply to 7713.87
< Why ...
For the beauty of the perfection! ;)
I am agree that is nothing but when it's "default" buttons that is better to see them in their local language! :)
Sure that is more coding at the start but ...that is not priority one! :)
I prefere have more functions than this very very little annoyous trouble! :)
7713.89
Hello,
here is another try to implement a new node - unfortunately with a bug in the menudisplay - I hope Max can help again:-)
Here is the code:
//Curve
function Curve()
this.addInput("In","objectlist");
Line.title = "Curve";
Line.desc = "Curve";
Curve.prototype.onExecute = function()
var inObj = this.getInputData(0, moi.geometryDatabase.createObjectList());
var factory = moi.command.createFactory( 'interpcurve' );
// factory.createInput('point');
for ( var n = 0; n < inObj.length; ++n )
{ factory.createInput('point');
factory.setInput(n,inObj.item(n).pt);
factory.cancel();
LiteGraph.registerNodeType("Factories/Curve", Curve);
I hope it's useful and Max or someone else see my bug:-)
Kind regards
and a nice weekend to all!
Karsten
EDITED: 18 Dec 2017 by KMRQUS
7713.90 In reply to 7713.89
Hi Karsten
Finally found the simple error.
Line needs to be replaced with Curve, twice
ICurve.title = "ICurve";
ICurve.desc = "ICurve";
I renamed it ICurve, because ControlPoint curves are also possible.
Now I will try the simple Catenary to feed into ICurve.
7713.91 In reply to 7713.90
Here is a version of factories.js with Line and InterpCurve nodes.
(This is NOT approved by Max)
7713.92
I have a plans to change point and frame formats. I'll make a common data type.
It will support points, frames, point arrays e.t.c.
Brian, thank you!
I'll check it tomorrow :)
7713.93 In reply to 7713.91
thank You very much! Are there some other new nodes?
Kind regards
Karsten
7713.94 In reply to 7713.93
Hi Karsten,
I have not made any nodes, so you are way ahead of me:-)
But your and Max's examples have shown the way.
7713.95 In reply to 7713.94
Hello,
I've playing around with a very simple node. It only invert values - but I think it can be useful:-)
I've put the following line in the index.html: <script type="text/javascript" src="nodes/math.js"></script>
and put the following file in the nodes directory.
Maybe interesting for someone.
Kind regards
Karsten
7713.96 In reply to 7713.95
I believe that you must open a thread for collect the Nodes function created!
Else it will be difficult to find something!
7713.97 In reply to 7713.96
please, only a last one;-)
It's only for playing around:-)
Thank's Max again - I don't understand that stuff - but I love it!
Kind regards
Karsten
Show messages:  1-17  18-37  38-57  58-77  78-97  98-117  118-137  138-157  …  898-912
