Parametric design in MoI?
 1-13  …  734-753  754-773  774-793  794-813  814-833  …  894-912
@Max
file lang.js with French translations of official and "deviant" nodes! ;) (1.0 Canddidate)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang_21_01_18_vf.zip
7713.775 In reply to 7713.767
Hi Max,
I've just returned from 6 weeks away, and are attempting to update nodeeditor.
I've attached the code: "moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );" to NE icon in custom UI
and extracted archive into folder directory as per your instructions (?)
But alas, it opens a blank window.
Please let me know if I done something wrong (I'm still a bit jet-lagged)
Thanks James
EDITED: 30 Jan 2018 by JFH
7713.776 In reply to 7713.775
<< Blank window
Sure not : take a look at the right column of the Core Folder! ;)
There is a vertical list!
All is present! :)
7713.777 In reply to 7713.775
Hi James, which version of MoI are you running it on?
7713.778 In reply to 7713.777
>> which version of MoI are you running it on? <<
MoI v4 beta Dec-11-2017
UPDATED: I've updated to MoI v4 beta Dec-12-2017
but again blank window
7713.779 In reply to 7713.775
Hi James, taking a closer look at your directories there, it looks like the problem is you've got it in the root /Library instead of your user one.
Put it just as you have done except under /Users/[your user name]/Library/Application Support/Moi - you should find a Moi directory there already which has your moi.ini file in it.
Hopefully that should get you going!
7713.780 In reply to 7713.779
Thank you Michael,
I had forgotten that Apple hides the User Library files by default
(tip for Mac users: Cmd Shift . [period] will unhide hidden system files)
So all good now.
While I've got you: there is a bug with interacting with NE interface via MacBook trackpad,
which Max is unable to reproduce because he doesn't have access to these devices (macbook or mac trackpad).
I've not experience any similar issue with Moi v4 interfacing, so it is likely to be specific to Max's
code, but is there something within the rewriting of v4 that has altered the handling of trackpad events
that may have follow on effects? I understand that NE operation is outside your principle concern, but if
there is something obvious to you that may cause this issue, perhaps you could steer Max right.
Either way, thanks again for your help
7713.781 In reply to 7713.780
Hi James, well the MoI viewport trackpad handling is done through C++ code responding to Qt events, it's not handled by any script processing. The node editor is running through script and webkit events and yeah there have been quite a few changes in the newer webkit version that MoI v4 is now using.
I do have a macbook here with a trackpad so I can test it over here. I know you've reported it previously but can you please describe the problem again? And do you mean that it used to work ok in MoI v3?
7713.782 In reply to 7713.781
RE: trackpad interfacing with NE
>> And do you mean that it used to work ok in MoI v3? <<
The issue only occurs with v4.
All NE updates up to 0.99 work as expected in Moi v3.1
I have not tried "Nodeeditor 1.0 rc1" with v3 but experiences the issue with v4
as has all earlier versions of NE.
.>> please describe the problem again <<
The problem is principally with two finger interactions:
At times panning becomes locked on, so that having changed to single finger movement
it continue to behave as if using two fingers.
At other times attempted panning fails to do anything;
or alternatively will unintentionally select a node and move it.
Similarly with zooming, at time it fails and instead a marque is drawn on screen,
or nothing will happen except for detail info next to each node appearing & disappearing.
As I said before, these issues do not occur with Moi v3.1, only v4 beta and with every iteration of NE
unto and including most recent.
Please let me know if you cannot repeat my problems on your MacBook.
EDITED: 31 Jan 2018 by JFH
7713.783 In reply to 7713.782
Hi James yes I can see there is some difference in behavior between MoI v3 and v4 , maybe v4 is sending events in some unexpected order. I'll see if I can find out what.
But part of the problem is it's based only on mouse oriented behavior - 2 fingers just lightly touching doesn't do panning at all right, it's only 2 fingers _clicked_ down and dragged that does panning. That it keeps panning until you remove both fingers from the click doesn't seem like a bug.
2 fingers lightly touching doesn't do any panning over here, only a mousewheel type zoom if you move up and down.
For a trackpad it's probably better for panning to work by 2 finger movement and zooming with pinching.
I see that in main.js there are some event handlers set up for touch events, but in the handler it's just translating these into mouse events and not handling them as drag/pinch gestures. It could be possible that MoI v3 being based on a older Webkit version did not fire these touch events and MoI v4 does and that's why there is different behavior.
Please give this a try - in the file main.js line 2738 where it sets up the multitouch event handlers, which looks like this:
	//touch events
	this._touchpad_callback = this.bindFunction(this.touchHandler, this);
	//if( 'touchstart' in document.documentElement ) {
	canvas.addEventListener("touchstart", this._touchpad_callback, true);
	canvas.addEventListener("touchmove", this._touchpad_callback, true);
	canvas.addEventListener("touchend", this._touchpad_callback, true);
	canvas.addEventListener("touchcancel", this._touchpad_callback, true);
Comment out that whole block by adding /* */ around it so it looks like this:
	//touch events
Then give that a try and see if you now have the same behavior in MoI v4 as v3 had.
Qt will automatically synthesize mouse events for touches if not already done, so it shouldn't be necessary to have an additional touch handler in HTML that just generates mouse events, that's probably making most of the odd behavior.
If that part is straightened out then maybe it's possible to add different handling for touch gestures to make it behave more trackpad like, like 2 fingers panning and pinching for zooming.
7713.784 In reply to 7713.783
Thank you so much...It works perfectly now.
>> For a trackpad it's probably better for panning to work by 2 finger movement and zooming with pinching. <<
Yes zooming by pinching would be a welcome addition, but for now I'm just happy that NE with v4 works just as with v3
Thanks again, much appreciated!
7713.785 In reply to 7713.784
Hi James, I'm glad that worked. I also looked through the old Webkit version v3 used and did confirm that it did not support touch events so that's definitely why there was a behavior difference between v3 and v4.
After looking through the node editor a bit more I also saw that there are some removeEventListener() for the touch events that should probably be taken out as well if the addEventListener() calls are removed.
I'll also see if I can add a way for a dialog to opt-in to receive some trackpad specific events so it can differentiate between a trackpad scroll (used for panning) versus a mouse wheel scroll (used for zooming) without having to do low level touch event handling.
7713.786
thank you very much for your help. I'll add a version check in the next NE release.
if (moi.majorVersionNumber<4) {
7713.787 In reply to 7713.786
Hi Max,
You're welcome - that version check should work fine although I think the older Webkit in MoI v3 doesn't support those touch events anyway.
7713.788 In reply to 7713.784
Hi James & Max - for the next beta I've added a ontrackpadgesture HTML event so the node editor can use it to do zoom/pan navigation with a Mac trackpad.
I've got pinch to zoom working, and it could also be possible to use the 2 fingers scroll gesture to do panning instead of mousewheel like zoom (where only up/down motions with the 2 fingers are used), but one complication with doing panning like that is it looks like some nodes respond to onmousewheel themselves to do their own actions. One way to work with that is that if the mouse is over a node like that, then it could send a mousewheel to that node instead of panning. But that would mean that while you were panning around your panning would suddenly stop if you happened to position one of those wheel-responsive nodes under the mouse. Maybe another possibility is to do the mousewheel type scroll if you hold down the Ctrl key. Any thoughts?
7713.789 In reply to 7713.788
Hi Michael & Max,
>> Maybe another possibility is to do the mousewheel type scroll if you hold down the Ctrl key. <<
This would be a good ideal regardless. The addition of node interaction using the identical gesture to zooming is problematic. Or rather can be...if a node circuitry is such that it takes several seconds to draw result to screen, then accidentally dialling of a variable when intending to zoom, can frustratingly breakup work flow.
So yes, to distinguish the 2 types of interaction, the additional requirement of holding down Ctrl key would be ideal.
.>> I've got pinch to zoom working <<
Pinching would indeed be a more natural way for trackpad users to zoom in NE.
As well a "zoom extents" would be the icing on the cake.
Thanks to both of you for your continued development
EDITED: 3 Feb 2018 by JFH
7713.790 In reply to 7713.789
Hi James,
Sounds good.
Is there any existing functionality in the node editor for that? I've got the gesture event set up for that with a 2 finger double tap ("Smart Zoom") but I haven't looked around yet to see if there's an already made node editor function that I can call.
7713.791 In reply to 7713.789
Hi James & Max - here's how to enable Mac trackpad multi-touch navigation in the node editor when the next MoI beta is out. These are all in the file main.js
Inside LGraphCanvas.prototype.bindEvents add this:
	this._trackpadgesture_callback = this.bindFunction(this.trackpadHandler, this);
	canvas.addEventListener("trackpadgesture", this._trackpadgesture_callback, true);
Inside LGraphCanvas.prototype.unbindEvents add this:
	this.canvas.removeEventListener("trackpadggesture", this.trackpadHandler );
Then add this function:
LGraphCanvas.prototype.trackpadHandler = function(e)
	if(!this.graph || !this.allow_dragcanvas || this.selection_mode) return;
	if ( e.gestureType == 'Zoom' )
		// Pinch gesture.
		var speed = 2.0;
		var factor = 1.0 + (e.scaleFactor * speed);
		var newscale = this.scale * factor;
		if ( newscale > 0.0 )
			this.adjustMouseEvent(e);
			this.setZoom( newscale, [ e.localX, e.localY ] );
			this.graph.sendActionToCanvas("setDirty",[true,true]);
	else if ( e.gestureType == 'Scroll' )
		// 2 fingers scroll gesture.
		// If Ctrl is down, return without calling event.preventDefault() so
		// a mouse wheel event will be triggered.
		if ( e.ctrlKey )
			return;
		var speed = 1.0;
		this.offset[0] += (e.deltaX * speed) / this.scale;
		this.offset[1] += (e.deltaY * speed) / this.scale;
		// Note: don't set this.canvas_moved = true; like right mouse drag uses because
		// it's used to disable context menus if the right mouse was dragged instead
		// of clicked. If we set it here it makes context menus hard to launch.
	else if ( e.gestureType == 'SmartZoom' )
		// 2 finger double tap, use for zoom extents / reset view.
		// TODO
	e.preventDefault();
7713.792 In reply to 7713.791
thank you! I'll add this code to the next version of Nodeeditor.
P.S. Today I bought a trackpad, so I will add full support of multitouch navigation.
7713.793
Nodeeditor 1.0 release candidate 2
Added: Multiple start parameters support (example: moi://appdata/nodeeditor/index.html?scheme=Light&somethingelse=123)
Added: You can open second Nodeeditor window by pressing Alt + New button
Added: Nodeeditor doesn't flush clipboard data on window close
Added: Initial Trackpad support (New zoom engine should work fine with all v3/v4 MoI versions. Also I made changes in Knob and Slider nodes. Let's hope I didn't break anything ;))
Added: Some visual improvements
http://moi.maxsm.net/nodeeditor/
Show messages:  1-13  …  714-733  734-753  754-773  774-793  794-813  814-833  834-853  …  894-912
