Parametric design in MoI?
 1-6  …  727-746  747-766  767-786  787-806  807-826  …  907-912
7713.767 In reply to 7713.766
Hi Alberto
Windows: extract archive to C:\Users\<username>\AppData\Roaming\Moi\nodeeditor
Mac: extract archive to /Users/<username>/Library/Application Support/Moi/nodeeditor
Run this command to open Nodeeditor window:
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
7713.768
Few weeks ago I bought a 4k monitor, and as a result, Nodeeditor is fully compatible with HiDPI displays. :)
Mac version looks great (check the attached file), but i still have a problems with Windows version. (I will ask Michael about it)
EDITED: 7 Mar 2022 by SMIRNOV
7713.769
Thanks Max for the detailed information
Happy New Year and Good Job
Thanks again
best
alberto
7713.770
Nodeeditor 1.0 release candidate 1
added: HiDPI/Retina screen support. Now NE interface depends on system dpi settings and system UI scale. Should work good with all MoI versions: v3/v4 Win/Mac. Please test it.
removed: css files. I removed all waste from css files, and moved css data to index.html.
changed: context menu and info panel design
added: alt+double click - reset viewport
changed: alignToGrid function (now you can't create two nodes with same coordinates)
http://moi.maxsm.net/nodeeditor/
7713.771 In reply to 7713.770
Seems new translations (if new nodes or other goodies)
and
Updates French site in perspective! :) Site Fr - Done : http://moiscript.weebly.com/elephant-systegraveme-nodal.html
EDITED: 20 Jan 2018 by PILOU
7713.772 In reply to 7713.770
Great work Max, almost at 1.0 !
7713.773 In reply to 7713.770
Wanderful!!!! Thanks Max!!
@Max
file lang.js with French translations of official and "deviant" nodes! ;) (1.0 Canddidate)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang_21_01_18_vf.zip
7713.775 In reply to 7713.767
Hi Max,
I've just returned from 6 weeks away, and are attempting to update nodeeditor.
I've attached the code: "moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );" to NE icon in custom UI
and extracted archive into folder directory as per your instructions (?)
But alas, it opens a blank window.
Please let me know if I done something wrong (I'm still a bit jet-lagged)
Thanks James
EDITED: 30 Jan 2018 by JFH
7713.776 In reply to 7713.775
<< Blank window
Sure not : take a look at the right column of the Core Folder! ;)
There is a vertical list!
All is present! :)
7713.777 In reply to 7713.775
Hi James, which version of MoI are you running it on?
7713.778 In reply to 7713.777
>> which version of MoI are you running it on? <<
MoI v4 beta Dec-11-2017
UPDATED: I've updated to MoI v4 beta Dec-12-2017
but again blank window
7713.779 In reply to 7713.775
Hi James, taking a closer look at your directories there, it looks like the problem is you've got it in the root /Library instead of your user one.
Put it just as you have done except under /Users/[your user name]/Library/Application Support/Moi - you should find a Moi directory there already which has your moi.ini file in it.
Hopefully that should get you going!
7713.780 In reply to 7713.779
Thank you Michael,
I had forgotten that Apple hides the User Library files by default
(tip for Mac users: Cmd Shift . [period] will unhide hidden system files)
So all good now.
While I've got you: there is a bug with interacting with NE interface via MacBook trackpad,
which Max is unable to reproduce because he doesn't have access to these devices (macbook or mac trackpad).
I've not experience any similar issue with Moi v4 interfacing, so it is likely to be specific to Max's
code, but is there something within the rewriting of v4 that has altered the handling of trackpad events
that may have follow on effects? I understand that NE operation is outside your principle concern, but if
there is something obvious to you that may cause this issue, perhaps you could steer Max right.
Either way, thanks again for your help
7713.781 In reply to 7713.780
Hi James, well the MoI viewport trackpad handling is done through C++ code responding to Qt events, it's not handled by any script processing. The node editor is running through script and webkit events and yeah there have been quite a few changes in the newer webkit version that MoI v4 is now using.
I do have a macbook here with a trackpad so I can test it over here. I know you've reported it previously but can you please describe the problem again? And do you mean that it used to work ok in MoI v3?
7713.782 In reply to 7713.781
RE: trackpad interfacing with NE
>> And do you mean that it used to work ok in MoI v3? <<
The issue only occurs with v4.
All NE updates up to 0.99 work as expected in Moi v3.1
I have not tried "Nodeeditor 1.0 rc1" with v3 but experiences the issue with v4
as has all earlier versions of NE.
.>> please describe the problem again <<
The problem is principally with two finger interactions:
At times panning becomes locked on, so that having changed to single finger movement
it continue to behave as if using two fingers.
At other times attempted panning fails to do anything;
or alternatively will unintentionally select a node and move it.
Similarly with zooming, at time it fails and instead a marque is drawn on screen,
or nothing will happen except for detail info next to each node appearing & disappearing.
As I said before, these issues do not occur with Moi v3.1, only v4 beta and with every iteration of NE
unto and including most recent.
Please let me know if you cannot repeat my problems on your MacBook.
EDITED: 31 Jan 2018 by JFH
7713.783 In reply to 7713.782
Hi James yes I can see there is some difference in behavior between MoI v3 and v4 , maybe v4 is sending events in some unexpected order. I'll see if I can find out what.
But part of the problem is it's based only on mouse oriented behavior - 2 fingers just lightly touching doesn't do panning at all right, it's only 2 fingers _clicked_ down and dragged that does panning. That it keeps panning until you remove both fingers from the click doesn't seem like a bug.
2 fingers lightly touching doesn't do any panning over here, only a mousewheel type zoom if you move up and down.
For a trackpad it's probably better for panning to work by 2 finger movement and zooming with pinching.
I see that in main.js there are some event handlers set up for touch events, but in the handler it's just translating these into mouse events and not handling them as drag/pinch gestures. It could be possible that MoI v3 being based on a older Webkit version did not fire these touch events and MoI v4 does and that's why there is different behavior.
Please give this a try - in the file main.js line 2738 where it sets up the multitouch event handlers, which looks like this:
	//touch events
	this._touchpad_callback = this.bindFunction(this.touchHandler, this);
	//if( 'touchstart' in document.documentElement ) {
	canvas.addEventListener("touchstart", this._touchpad_callback, true);
	canvas.addEventListener("touchmove", this._touchpad_callback, true);
	canvas.addEventListener("touchend", this._touchpad_callback, true);
	canvas.addEventListener("touchcancel", this._touchpad_callback, true);
Comment out that whole block by adding /* */ around it so it looks like this:
	//touch events
Then give that a try and see if you now have the same behavior in MoI v4 as v3 had.
Qt will automatically synthesize mouse events for touches if not already done, so it shouldn't be necessary to have an additional touch handler in HTML that just generates mouse events, that's probably making most of the odd behavior.
If that part is straightened out then maybe it's possible to add different handling for touch gestures to make it behave more trackpad like, like 2 fingers panning and pinching for zooming.
7713.784 In reply to 7713.783
Thank you so much...It works perfectly now.
>> For a trackpad it's probably better for panning to work by 2 finger movement and zooming with pinching. <<
Yes zooming by pinching would be a welcome addition, but for now I'm just happy that NE with v4 works just as with v3
Thanks again, much appreciated!
7713.785 In reply to 7713.784
Hi James, I'm glad that worked. I also looked through the old Webkit version v3 used and did confirm that it did not support touch events so that's definitely why there was a behavior difference between v3 and v4.
After looking through the node editor a bit more I also saw that there are some removeEventListener() for the touch events that should probably be taken out as well if the addEventListener() calls are removed.
I'll also see if I can add a way for a dialog to opt-in to receive some trackpad specific events so it can differentiate between a trackpad scroll (used for panning) versus a mouse wheel scroll (used for zooming) without having to do low level touch event handling.
7713.786
thank you very much for your help. I'll add a version check in the next NE release.
if (moi.majorVersionNumber<4) {
Show messages:  1-6  …  707-726  727-746  747-766  767-786  787-806  807-826  827-846  …  907-912
