Parametric design in MoI?
 1-2  …  683-702  703-722  723-742  743-762  763-782  …  903-912
7713.723
v.0.99
Added Transform/Twist node
Added Transform/Flow node
Added Basic/Concat
Removed Objects/Concat
Removed Points/ConcatPts
Fixed JitterPts bug
Added JitterPts Update function
http://moi.maxsm.net/nodeeditor
New node Basic/Concat supports all data types.
Objects/Concat and Points/ConcatPts are obsolete. I removed them from nodeeditor.
Don't worry if you use this nodes in your nod-projects. I added compatibility records to core/compatibility.js.
Old nodes will be replaced with the new one automatically.
7713.724 In reply to 7713.723
Hello Max!
@You : "...Don't worry if you use this nodes in your nod-projects. I added compatibility records to core/compatibility.js.
Old nodes will be replaced with the new one automatically..."
That's great!!
Thanks a lot.
Ciao!
For Max : the French lang.js update for the 0.99 nodeeditor
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.zip
7713.726
v0.99
Changed link disconnection method (please test it)
Fixed Quartz output bug (v0.96-v0.99)
Updated french localization
http://moi.maxsm.net/nodeeditor/
Near the 1.0 ! :)
7713.728
nodeeditor.v.0.99.2017.12.18
added: nodeeditor can be started from appdata directory
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
fixed: knob/slider trackpad scroll error
fixed: small visual glitch
added: switch/button node
fixed: pointArray.concat function
fixed: JitterPts node (dS bug)
added: initial node icons support
EDITED: 7 Mar 2022 by SMIRNOV
7713.729 In reply to 7713.728
Seems node Octane is not include in this last Opus !
Must we add something from a previous post from the "deviant thread"?
Else new lang.js for French Update ;)
OK i have the Octane point in extensions from the previous "deviant" post but not the "logo" Octane on the node!
EDITED: 17 Dec 2017 by PILOU
7713.730 In reply to 7713.728
Hello Max!
Thanks a lot for this new update!
I moved NE to my "appdata\Roaming\Moi" and all works fine (on Windows 10 Pro)
@You : "...added: initial node icons support..."
Wow! Much appreciated :)
But...how can I display the icon ? Where the icon files must be placed ? is there a naming convention for the icon files ?
7713.731 In reply to 7713.728
Hi Max,
>> fixed: knob/slider trackpad scroll error <<
I got so excited reading this, because I assumed that you must have tested interfacing with a trackpad.
But the same interfacing issues persist: Zooming & panning in NE interface work only intermittently.
And other odd behaviours where panning is misinterpreted as attempt to move a node's location.
NE on V3.1 all works perfectly.
7713.732
Frenchy Pilou
As I wrote earlier the Octane node is extension. I have no plans to include it in the main nodeeditor pack.
At the moment it works with MoIv4 only.
Marco
The icon should be specified inside a node file as a base64 encoded string parameter.
Check this file: http://moi.maxsm.net/nodeeditor/extensions/octane.js
Unfortunately I still have no idea how to emulate a trackpad. I tried programs like mobilemouse, but those programs can't emulate a touchpad events.
>>But the same interfacing issues persist: Zooming & panning in NE interface work only intermittently. And other odd behaviours where panning is misinterpreted as attempt to move a node's location.
I remember about it.
Could you add a line to main.js?
Find this code (line 4525):
LGraphCanvas.prototype.touchHandler = function(event)
    var touches = event.changedTouches, first = touches[0], type = "";
	switch(event.type)
change it to:
    if ( touches.length > 1 ) return;
	switch(event.type)
7713.733 In reply to 7713.732
<<OK i have the Octane point in extensions from the previous "deviant" post but not the "logo" Octane on the node!
<< At the moment it works with MoIv4 only.
"not the logo" on title's node : so it's a personnal variation not include on your extension published?
7713.734 In reply to 7713.732
Hi Max!
@You : "...The icon should be specified inside a node file as a base64 encoded string parameter.
Check this file: http://moi.maxsm.net/nodeeditor/extensions/octane.js"
Thanks a lot for the info.
Last question...
Which size and format the icon should be ? Png 24 bit (8red,8gree,8blue with transparent background) as we talked about months ago ?
Ciao.
7713.735 In reply to 7713.734
Hi Marco,
> Which size and format the icon should be ? Png 24 bit (8red,8gree,8blue with transparent background) as we talked about months > ago ?
If you decode the string it will give you (for his Octane Logo) a 24bit .png with a transparent background, 32x32 pixels in size.
7713.736 In reply to 7713.734
Hi Marco
If I remember clearly, we decided to use 64x64x24 bit icons :)
This octane 32x32 icon is just a test.
7713.737 In reply to 7713.734
Thanks Stefan for the tip.
Have a nice day.
7713.738 In reply to 7713.736
Hi Max.
Perfect! I think 64x64 is perfect for any kind of display monitor (both SD/HD/Retina)
One question...
Is there a way to attach and display the icons also for the "categories" end the "nodes"displayed into the scrollable toolbar on the left and int the RMB pupoup menu ?
This would be a great and nice UI improvements.
For example i never use the RMB manu but only the left toolbar that is much more user freindly for me, and having the chance to display icons and/or colored icons into that toolbar would be very useful.
I stay tuned. Thanks.
7713.739 In reply to 7713.738
So how do you put this little title logo ? :)
You must enter in the code?
7713.740 In reply to 7713.739
if you mean the little Octane logo you have to use a base64 encoder/decoder in cmd.exe and run on a little png image
"base64 -e image.png > output.txt" and then copy the text from the output file in a string, like shown in Max's code example.
7713.741 In reply to 7713.732
Hi Max
>> Could you add a line to main.js? <<
Yes. Although the line of code change did not fix the problem outright,
it has, at least, made NE on v4 useable, so thank you.
7713.742 In reply to 7713.740
This is super handy : https://www.base64-image.de/
Marco (mkdm)
Show messages:  1-2  …  663-682  683-702  703-722  723-742  743-762  763-782  783-802  …  903-912
