Parametric design in MoI?
 1-7  …  28-47  48-67  68-87  88-107  108-127  …  908-912
7713.68 In reply to 7713.67
That's what I have, and here is my shortcut:
Michael T.
7713.69 In reply to 7713.68
Hi Michael T
Your shortcut looks good. I pasted Max's shortcut to Ctrl+P, and it worked fine.
Well, a look at your path shows a problem, you have an alpha name for the nodeeditor subdirectory, not nodeeditor.
Rename subdirectory nodeeditor.v.0.22.alpha to nodeeditor.
Max's update directory structure could be slightly different to avoid the potential problem?
EDITED: 3 Dec 2015 by BEMFARMER
7713.70 In reply to 7713.69
Thanks Brian! The renaming did the trick!
Michael T.
7713.71
Hi Max
just a question ;
I extract folder ( Node 2015.12.01 zip) into Moi -ui , but in my window
does not appear added Rotate Function
Whi ?
Where is my mistake
many tnx-
al
Size: 621.8 KB, Downloaded: 195 times, Dimensions: 2192x1648px
Size: 251.1 KB, Downloaded: 197 times, Dimensions: 2192x1648px
7713.72 In reply to 7713.70
I guess Max could, say for nodeeditor.v.0.22.alpha, include subdirectory nodeeditor below the alpha directory.
Of course nodeeditor would contain the core, css, nodes, etc subsubdirectories and file contents.
Then to update, the subdirectory nodeeditor (with its contents) could be copied to /ui, rather than unzipping and copying core, css, nodes, etc, to ui/nodeeditor.
I had to think which updated directories to copy :-)
7713.73 In reply to 7713.71
Hi speedy
Absence of rotate happened to me, the very first time only. May be a file buffer issue?
Maybe close and re-open Moi. (pressing F5 once, helps with the file buffer?)
7713.74
many tnx bemfarmer.. for the info...
but ,I have resolved the problem....
I extract the content of folder ( node 2015.12.01)
and then copy and paste into the initial folder (nodes)
in Mou-ui , replacing the old file.js so-
Now it's work very well...
tnx
al
Size: 240 KB, Downloaded: 202 times, Dimensions: 2192x1648px
7713.75
Oh, my fault %)
I noticed that mess with the folders yesterday. I repacked an archive, but then I reuploaded the first one. :) Sorry guys.
EDITED: 7 Mar 2022 by SMIRNOV
7713.76
>>Lancer --> Stop --> Run !!!
Pilou, thank you for report. Fixed.
Also I fixed a critical bug, which cause errors on wire disconnection.
7713.77 In reply to 7713.76
Hi Max,
I have made some experiments with your code and have some problems with the frames. The following code fragment works, but with frames not. Have you any idea what I'm doing wrong?
// Line
function Line()
// this.size = [60,20];
// this.addInput("Start","frame"); //<------
// this.addInput("End","frame"); //<------
this.addInput("x1","number");
this.addInput("y1","number");
this.addInput("z1","number");
this.addInput("x2","number");
this.addInput("y2","number");
this.addInput("z2","number");
this.addOutput("Out","objectlist");
// this.properties = { radius:0 };
Line.title = "Line";
Line.desc = "Line";
Line.prototype.onExecute = function()
// var start = this.getInputData(0, moi.VectorMath.createFrame()); //<--------
// var end = this.getInputData(1, moi.VectorMath.createFrame()); //<-------
this.properties.x1 = this.getInputData(0, this.properties.x1);
this.properties.y1 = this.getInputData(1, this.properties.y1);
this.properties.z1 = this.getInputData(2, this.properties.z1);
this.properties.x2 = this.getInputData(3, this.properties.x1);
this.properties.y2 = this.getInputData(4, this.properties.y2);
this.properties.z2 = this.getInputData(5, this.properties.z2);
var start = moi.vectorMath.createPoint();
var end = moi.vectorMath.createPoint();
start.x = this.properties.x1;
start.y = this.properties.y1;
start.z = this.properties.z1;
end.x = this.properties.x2;
end.y = this.properties.y2;
end.z = this.properties.z2;
var factory = moi.command.createFactory( 'line' );
factory.setInput(0, start);
factory.setInput(1, end);
var output = factory.calculate();
// factory.update();
// LineFactory.commit();
this.setOutputData(0, output);
factory.cancel();
LiteGraph.registerNodeType("Factories/Line", Line);
Please, keep on coding:-)
Thanks a lot!
Karsten
7713.78 In reply to 7713.77
EDITED: 5 Dec 2015 by BEMFARMER
7713.79 In reply to 7713.78
Have you an idea of the use of Node "Loft" ?
7713.80
Hi Karsten,
check this manual
http://moi.maxsm.net/api/#_CoordinateFrame
If you want to use frames as input data you can use this code:
function Line()
Line.desc = "Line";
	factory.setInput(0, start.origin);
	factory.setInput(1, end.origin);
	factory.cancel();
but it will be better if you use points instead of frames
function Line()
	this.addInput("Start","point");
	this.addInput("End","point");
Line.desc = "Line";
	var start = this.getInputData(0, moi.VectorMath.createPoint());
	var end = this.getInputData(1, moi.VectorMath.createPoint());
	factory.cancel();
7713.81
Frenchy Pilou
7713.82 In reply to 7713.80
Hello Max,
thank You very much - I didn't know about ".origin" in the construct. But now everything makes sense.
Have a nice day
Karsten
7713.83 In reply to 7713.81
@ Max
Aaaaaaaaaaaaaaah! In all my trys I put "Loft" on start and not at the end! That was the trick! :)
Very cool that we can reload the entiere set of nodes!
That is parametric indeed! Bravo!
Just something curious all nodes titles are not translated !
I will investigate (i have not yet dowloaded your last version !)
EDITED: 4 Dec 2015 by PILOU
@Max
Even with your last version v 0.23Alpha
Reloading the "loft.nod" file don't make appear translated French Tittles of the Nodes!
Internal lines are translated!
So Little Glitch;
French version is present as you can see!
7713.85 In reply to 7713.84
It's not a glitch. When you create a node with English/French/Russian name it will be saved in a nod-file. When you load this file all names will be loaded as they stored.
7713.86 In reply to 7713.85
@Max
But this persists when I resave it from my "French" version! ;)
So I must rename first all titles that is some painfull! :)
Or there is a little trick ?
NOT A PRIORITY PROBLEM !!! :)
EDITED: 5 Dec 2015 by PILOU
7713.87
But why translate it
Show messages:  1-7  8-27  28-47  48-67  68-87  88-107  108-127  128-147  …  908-912
